查看: 1742|回复: 2
求助 已知CAD两点坐标 有没有一个VBA命令可以复制这两个对角点内所有内容
发表于 2013-1-3 21:13:16 | 显示全部楼层 |阅读模式
发表于 2013-1-4 14:02:22 | 显示全部楼层
object.SelectAtPoint Point, FilterType, FilterData
Object
SelectionSet
The object this method applies to.
Point
Variant (three-element array of doubles); input-only
The 3D UCS coordinates specifying the point to use for the selection.
FilterType
Integer; input-only; optional
A DXF group code specifying the type of filter to use.
FilterData
Variant; input-only; optional
The value to filter on.
发表于 2013-1-11 08:37:51 | 显示全部楼层
        Dim sel1 As AcadSelectionSet    '定义选择集对象
        Mode = 5 '选择模式
        Set sel1 = ThisDrawing.SelectionSets.Add("sel4") '添加选择集子项
        Call sel1.Select(Mode, 点1, 点2)
        sel1.Highlight (True) '显示已经选中对象
GMT+8, 2025-5-26 13:05 , Processed in 0.172680 second(s), 24 queries , Gzip On.
