查看: 1176|回复: 1
cad.net可以让某个要素居中显示 谁实现过?
发表于 2012-12-24 17:21:24 | 显示全部楼层 |阅读模式
cad.net可以让某个要素居中显示,控制显示比例。  谁实现过?给段代码
发表于 2012-12-25 11:36:23 | 显示全部楼层
  1. ''' <summary>
  2.     ''' 按对象进行缩放
  3.     ''' </summary>
  4.     ''' <param name="ID"></param>
  5.     ''' <param name="ZoomScale">此数为正数,表示放大倍率(如果此数小于等于 0 则自动调整为1)</param>
  6.     ''' <remarks></remarks>
  7.     Public Sub ZoomO(ByVal ID As ObjectId, Optional ByVal ZoomScale As Double = 1.0)
  8.         Dim MinPt As Point3d = Nothing, MaxPt As Point3d = Nothing
  9.         Using Trans As Transaction = DB.TransactionManager.StartTransaction
  10.             Dim obj As DBObject = ID.GetObject(OpenMode.ForRead)
  11.             If TypeOf obj Is Entity = False Then
  12.                 Trans.Commit()
  13.                 Exit Sub
  14.             End If
  15.             Dim Ent As Entity = obj
  16.             MinPt = Ent.GeometricExtents.MinPoint : MaxPt = Ent.GeometricExtents.MaxPoint
  17.             Trans.Commit()
  18.         End Using
  19.         Dim Ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
  20.         Dim VTabRec As New ViewTableRecord
  21.         VTabRec.CenterPoint = New Point2d((MaxPt.X + MinPt.X) / 2.0, (MaxPt.Y + MinPt.Y) / 2.0)
  22.         If ZoomScale <= 0 Then
  23.             ZoomScale = 1.0
  24.         End If
  25.         VTabRec.Height = (MaxPt.Y - MinPt.Y) / ZoomScale
  26.         Ed.SetCurrentView(VTabRec)
  27.         Ed.UpdateScreen()
  28.     End Sub
此方法将对象居中于当前视图(同时可以设置放大倍率)
GMT+8, 2025-5-31 09:52 , Processed in 0.179584 second(s), 23 queries , Gzip On.
