查看: 2279|回复: 2
c#停靠面板上的按钮,再多次按下时,崩溃
发表于 2012-11-14 15:08:36 | 显示全部楼层 |阅读模式
如果不选择实体,重复多次点同一个按钮,cad崩溃,如何释放??求教。。。
Dim strNum As String
        Dim text1 As DBText
        'Dim BReference As BlockReference
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim documentLock As DocumentLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument()
        Using trans As Transaction = db.TransactionManager.StartTransaction
            Dim opt As New PromptEntityOptions("请选择界址线" + vbCrLf)
            Dim res As PromptEntityResult = ed.GetEntity(opt)
            If res.Status <> PromptStatus.OK Then
                Exit Function
            End If
            Dim ent As Entity = trans.GetObject(res.ObjectId, OpenMode.ForWrite)
            If ent.GetType().Name.ToString() <> "Polyline" Then
                Application.ShowAlertDialog("选择的实体类型不对!")
                Exit Function
            End If
            'Dim pt As Point3d = BReference.Position
            Dim reg As RegAppTable = trans.GetObject(db.RegAppTableId, OpenMode.ForWrite)
            If Not reg.Has("界址线类别") Then
                Dim app As New RegAppTableRecord
                app.Name = "界址线类别"
                reg.Add(app)
                trans.AddNewlyCreatedDBObject(app, True)
            End If
            Dim rb As New ResultBuffer( _
            New TypedValue(DxfCode.ExtendedDataRegAppName, "界址线类别"), _
            New TypedValue(DxfCode.ExtendedDataAsciiString, str))
            ent.XData = rb
            trans.Commit()
            ed.WriteMessage("添加成功!" + vbCrLf)
        End Using
        documentLock.Dispose()
发表于 2012-11-14 17:02:32 | 显示全部楼层
trans.Dispose()
                Exit Function
            End If
 楼主| 发表于 2012-11-15 22:45:20 | 显示全部楼层
sieben 发表于 2012-11-14 17:02
If res.Status  PromptStatus.OK Then
trans.Dispose()
多谢 多谢。
GMT+8, 2025-5-18 06:06 , Processed in 0.160372 second(s), 25 queries , Gzip On.
