查看: 1650|回复: 0
【求助】使用c#在CAD中批量创建图层
发表于 2012-11-12 15:46:10 | 显示全部楼层 |阅读模式
小弟最近在做的一个小项目,想从excel文档中批量读取数据到CAD创建图层。
采用将excel中的数据存入不同的数组,再在创建CAD图层的时候应用这些数组的方法。
现在对于图层名字,颜色和线型的设置都没有问题。
对于线宽:acLineWeights = LineWeight.LineWeight005;acLyrTblRec.LineWeight = acLineWeights ;可以创建单一的图层线宽。
但是想要将批量创建图层线宽就发生了问题。
我的想法是,
string u = LineWeight005;
acLyrTblRec.LineWeight = LineWeight.(u)
只要这种参数化的设置线宽可以实现,那么就可以实现批量导入。
望有人赐教,不甚感激!(附代码)
如有表达不清,请追加~谢谢~~
  1. using System;using System.Collections.Generic;using System.Linq;using System.Text;using Autodesk.AutoCAD.ApplicationServices;using Autodesk.AutoCAD.Runtime;using Autodesk.AutoCAD.Geometry;using Autodesk.AutoCAD.EditorInput;using Autodesk.AutoCAD.DatabaseServices;using Autodesk.AutoCAD.Colors;using System.Reflection;using System.IO;using Microsoft.Office.Core;using Excel = Microsoft.Office.Interop.Excel;[assembly: CommandClass(typeof(MyFirstProject1.Class1))]namespace MyFirstProject1{     public class Class1    {        [CommandMethod("SetLayer")]        public static void SetLayer()        {            int p = 7;                        Excel.Application xlsApp = new Excel.Application();            if (xlsApp == null)            {                return;            }                        xlsApp.Visible = true;            Excel.Workbook xlsBook =                xlsApp.Workbooks.Open(@"D:\test.xls", Missing.Value, Missing.Value, Missing.Value, Missing.Value, Missing.Value, Missing.Value, Missing.Value, Missing.Value, Missing.Value, Missing.Value, Missing.Value, Missing.Value);            Excel.Worksheet xlsSheet = (Excel.Worksheet)xlsBook.Sheets[1];                        int i;                        short []    excelcolor    = new short [p];            double[] excelweight   = new double[p];            string[] excelname     = new string[p];            string[] excellinetype = new string[p];            for (i = 1; i <= p; i++)            {                Excel.Range range1 = (Excel.Range)xlsSheet.Cells[i, 3];                excelcolor[i - 1] = Convert.ToInt16(range1.Value);            }            for (i = 1; i <= p; i++)            {                Excel.Range range2 = (Excel.Range)xlsSheet.Cells[i, 4];                excelweight[i - 1] = Convert.ToDouble(range2.Value);            }            for (i = 1; i <= p; i++)            {                Excel.Range range3 = (Excel.Range)xlsSheet.Cells[i, 1];                excelname[i - 1] = Convert.ToString(range3.Value);            }            for (i = 1; i <= p; i++)            {                Excel.Range range4 = (Excel.Range)xlsSheet.Cells[i, 5];                excellinetype[i - 1] = Convert.ToString(range4.Value);            }                                           // 获得当前文档和数据库   Get the current document and database            Document acDoc = Application.DocumentManager.MdiActiveDocument;            Database acCurDb = acDoc.Database;            // 启动一个事务  Start a transaction            using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())            {                // 以只读方式打开图层表   Open the Layer table for read                LayerTable acLyrTbl;                acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId,                                             OpenMode.ForRead) as LayerTable;                                // Define an array of layer names                string[] sLayerNames = new string[p];                for (i = 1; i <= p; i++)                {                    sLayerNames[i-1] = excelname[i-1];                }                                // Define an array of colors for the layers                Color[] acColors = new Color[p];                for (i = 1; i <= p; i++)                {                    acColors[i-1] = Color.FromColorIndex(ColorMethod.ByAci, excelcolor[i - 1]);                }                                LineWeight[] acLineWeights = new LineWeight[p];                acLineWeights[0] = LineWeight.LineWeight005;                acLineWeights[1] = LineWeight.LineWeight009;                acLineWeights[2] = LineWeight.LineWeight013;                acLineWeights[3] = LineWeight.LineWeight005;                acLineWeights[4] = LineWeight.LineWeight009;                acLineWeights[5] = LineWeight.LineWeight013;                acLineWeights[6] = LineWeight.LineWeight070;                               string[] Linetypes = new string[p];                for (i = 1; i <= p; i++)                {                    Linetypes[i-1] = excellinetype[i-1];                                   }                               int nCnt = 0;                // Add or change each layer in the drawing                foreach (string sLayerName in sLayerNames)                {                    LayerTableRecord acLyrTblRec;                    if (acLyrTbl.Has(sLayerName) == false)                    {                        acLyrTblRec = new LayerTableRecord();                        // Assign the layer a name                        acLyrTblRec.Name = sLayerName;                        // Upgrade the Layer table for write                        if (acLyrTbl.IsWriteEnabled == false) acLyrTbl.UpgradeOpen();                        // Append the new layer to the Layer table and the transaction                        acLyrTbl.Add(acLyrTblRec);                        acTrans.AddNewlyCreatedDBObject(acLyrTblRec, true);                    }                    else                    {                        // Open the layer if it already exists for write                        acLyrTblRec = acTrans.GetObject(acLyrTbl[sLayerName],                                                        OpenMode.ForWrite) as LayerTableRecord;                    }                    // Set the color of the layer                    acLyrTblRec.Color = acColors[nCnt];                    // 设置图层线宽                    acLyrTblRec.LineWeight = acLineWeights[nCnt];                    // 以只读方式打开图层表   Open the Layer table for read                    LinetypeTable acLinTbl;                    acLinTbl = acTrans.GetObject(acCurDb.LinetypeTableId,                                                 OpenMode.ForRead) as LinetypeTable;                    if (acLinTbl.Has(Linetypes[nCnt]) == true)                    {                        // Upgrade the Layer Table Record for write                        acLyrTblRec.UpgradeOpen();                        // Set the linetype for the layer                        acLyrTblRec.LinetypeObjectId = acLinTbl[Linetypes[nCnt]];                    }                    nCnt = nCnt + 1;                }                // Save the changes and dispose of the transaction                acTrans.Commit();            }        }    }}
GMT+8, 2025-5-2 15:04 , Processed in 0.163898 second(s), 25 queries , Gzip On.
