楼主: 泉(Ango)
AutoCAD VBA判断指定图层是否存在,如不存在则新建.
发表于 2012-11-15 22:35:47 | 显示全部楼层
  1. Option Explicit
  2. Dim oldLayer As AcadLayer
  3. Dim NewLayer As AcadLayer
  4. Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
  5.    Debug.Print CommandName
  6.    Select Case CommandName
  7.    Case "DIMLINEAR", "DIMALIGNED", "DIMARC", "DIMORDINATE", "DIMRADIUS", "DIMJOGGED", "DIMDIAMETER", "DIMANGULAR", "QDIM", "DIMBASELINE", "DIMCONTINUE", "QLEADER"
  8.        Set oldLayer = ThisDrawing.ActiveLayer
  9.
  10.       On Error Resume Next
  11.        Set NewLayer = ThisDrawing.Layers("DIM")
  12.        If Err Then
  13.           Err.Clear
  14.           Set NewLayer = ThisDrawing.Layers.Add("DIM")
  15.        End If
  16.        ThisDrawing.ActiveLayer = ThisDrawing.Layers.Item("DIM")
  17.    End Select
  18. End Sub
  19. Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
  20.     Select Case CommandName
  21.     Case "DIMLINEAR", "DIMALIGNED", "DIMARC", "DIMORDINATE", "DIMRADIUS", "DIMJOGGED", "DIMDIAMETER", "DIMANGULAR", "QDIM", "DIMBASELINE", "DIMCONTINUE", "QLEADER"
  22.         ThisDrawing.ActiveLayer = oldLayer
  23.     End Select
  24. End Sub
 楼主| 发表于 2012-11-18 15:15:40 | 显示全部楼层
谢谢大家的帮助......
发表于 2014-11-16 21:25:18 | 显示全部楼层
好像不管是否存在Dim图层,直接新建Dim图层并置为当前图层也不会出问题吧
像这样:
ThisDrawing.ActiveLayer = ThisDrawing.Layers.Add("Dim")
GMT+8, 2025-5-28 02:49 , Processed in 0.173287 second(s), 17 queries , Gzip On.
