查看: 1874|回复: 4
图框生成程序移植到R2000时,图框内框与外框重叠,为何如此?请高手指点
发表于 2003-8-26 18:43:00 | 显示全部楼层 |阅读模式
我将原在R12下编制的图框生成程序移植到R14获得成功,但移植到R2000时,产生奇怪的现象,生成的图框内框与外框重叠,查询内、外框4点的变量却又不相等,所以从理论上说不应重叠。那位大虾能指点一下迷津。
发表于 2003-8-26 18:49:00 | 显示全部楼层
osmode
 楼主| 发表于 2003-9-5 22:33:00 | 显示全部楼层
windows平台
发表于 2004-7-17 19:24:00 | 显示全部楼层
图框生成程序移植到R2000时,图框内框与外框重迭,为何如此?请高手指点
我将原在R12下编制的图框生成程序移植到R14获得成功,但移植到R2000时,产生奇怪的现象,生成的图框内框与外框重迭,查询内、外框4点的变量却又不相等,所以从理论上说不应重迭。那位大虾能指点一下迷津。 源代码:(defun dwgboxset()
(dwgblset)
(pointset)
(lineset)
(defun dwgblset()
(if bbx
(if (/= bbx 0.0)
(setq bbl bbx)
(setq bbx 0.0)
(setq pp (mapcar (quote +) basept (mapcar (quote *) pp (list bbl bbl))))
) (defun pointset()
(command "limits" basept pp)
(command "zoom" "a")
) (defun drawbz (pt / aa pp1 pp2 pp3 pp4)
(setq aa (* 0.020000 (getvar "VIEWSIZE")))
(setq pp1 (mapcar (quote +) pt (list aa aa)))
(setq pp2 (mapcar (quote -) pt (list aa aa)))
(setq pp3 (mapcar (quote +) pt (list aa (- aa))))
(setq pp4 (mapcar (quote -) pt (list aa (- aa))))
(grdraw pp1 pp2 -1)
(grdraw pp3 pp4 -1)
) (defun lineset ()
(command "layer" "m" "tk" "c" "cyan" "" "")
(command "linetype" "s" "bylayer" "")
(command "color" "bylayer") (drabox basept pp 0)
(if (= box "1")
(setq pt3 (mapcar (quote +) basept (list (* 25 bbl) (* 10 bbl))))
(setq pt4 (mapcar (quote -) pp (list (* 10 bbl) (* 10 bbl))))
(setq pt3 (mapcar (quote +) basept (list (* 25 bbl) (* 5 bbl))))
(setq pt4 (mapcar (quote -) pp (list (* 5 bbl) (* 5 bbl))))
(drabox pt3 pt4 (* 0.700000 bbl))
(setq pt5 (list (car pt4) (last pt3)))
(setq pt6 (list (car pt3) (last pt4)))
(if (= box "1")
(command "insert" "tb" pt5 bbl bbl 0)
(command "insert" "hq" pt6 bbl bbl 0)
(command "insert" "tb1" pt5 bbl bbl 0)
(command "layer" "s" "0" "")
(quote nil)
) (defun drabox (p1 p2 wh / p3 p4)
(setq p3 (list (car p2) (cadr p1)))
(setq p4 (list (car p1) (cadr p2)))
(command "pline" p1 "w" wh wh p3 p2 p4 "c")
) (defun c:dwgbox (/ basept basept1 pp nx ny bbl bbx box fd fdd)
(setvar "cmdecho" 0)
(setvar "blipmode" 0)
(setq fd T fdd nil)
(setq dcl_id (load_dialog "dwgbox.dcl"))
(new_dialog "dwgbox" dcl_id)
(if (not dcl_id) (exit))
(action_tile "a0" "(setq pp '(1189 841))")
(action_tile "a1" "(setq pp '(841 594))")
(action_tile "a2" "(setq pp '(594 420))")
(action_tile "a3" "(setq pp '(420 297))")
(action_tile "a4" "(setq pp '(210 297))")
(action_tile "tw" "(setq nx (atof (get_tile \"tw\")))")
(action_tile "th" "(setq ny (atof (get_tile \"th\")))")
(action_tile "bl1" "(setq bbl 200)")
(action_tile "bl2" "(setq bbl 100)")
(action_tile "bl3" "(setq bbl 50)")
(action_tile "bl4" "(setq bbl 20)")
(action_tile "bl5" "(setq bbl 10)")
(action_tile "bl6" "(setq bbl 1)")
(action_tile "blx" "(setq bbx (atof (get_tile \"blx\")))")
(action_tile "tb1" "(setq box (get_tile \"tb1\"))")
(action_tile "cancel" "(setq fd nil)")
(action_tile "accept" "(done_dialog)") (start_dialog)
(unload_dialog dcl_id)
(if (and nx ny)
(if (and (/= nx 0.0) (/= ny 0.0))
(setq pp (list nx ny))
(setq nx nil ny nil)
(if (and pp (and (null nx) (null ny))) (setq fdd T))
(if (and (and pp fd) (or bbx bbl) fdd)
(initget 8)
(setq basept (mapcar (quote +) (getvar "LIMMIN") (quote (0.000000 0.000000))))
(setq basept1 (getpoint "\n请拾取图框左下角点位置:"))
(if (NULL basept1)
(drawbz basept)
(setq basept basept1)
(drawbz basept)
(dwgboxset)
(if (not fd) (princ "\n*Cancel*\n") (princ "\n参数选择错误!"))
发表于 2005-4-20 21:59:00 | 显示全部楼层
已经解决了.
GMT+8, 2025-5-11 08:20 , Processed in 0.164831 second(s), 24 queries , Gzip On.
