查看: 4632|回复: 1
面域转多段线
发表于 2012-10-20 20:09:29 | 显示全部楼层 |阅读模式
面域转多段线,只支持直线和圆弧构成的面域转多段线,主要是圆弧的那个地方还是有点模糊,希望高手指点。
另外提个问题,圆弧的标注如何控制标注在圆弧内。
private Polyline RegionToPolyline(Region reg)
            DBObjectCollection segments = new DBObjectCollection();
            reg.Explode(segments);
            Polyline pl = new Polyline();
            DBObject Fristobj = segments[0];
            Curve FristCurve = (Curve)Fristobj;
            Point3d FristPoint = FristCurve.StartPoint;
            Point3d TmpPoint = FristCurve.EndPoint;
            switch (FristCurve.GetType().Name)
                case "Line":
                    Line line = (Line)FristCurve;
                    pl.AddVertexAt(0, new Point2d(line.StartPoint.X, line.StartPoint.Y), 0, 0, 0);
                    //TmpPoint = line.EndPoint;
                    break;
                case "Arc":
                    Arc arc = (Arc) FristCurve;
                    double dltAng = arc.EndAngle - arc.StartAngle;
                    if (dltAng < 0.0) dltAng += Math.PI * 2; //圆弧的结束角比开始角大时
                    double bulge =Math.Tan(dltAng/4.0);
                    pl.AddVertexAt(0, new Autodesk.AutoCAD.Geometry.Point2d(arc.StartPoint.X, arc.StartPoint.Y), bulge,0, 0);
                    //TmpPoint = arc.EndPoint;
                    break;
            var j = 1;
            while (!TmpPoint.Equals(FristPoint))
                for (int i = 1; i <= segments.Count-1; i++)
                    DBObject obj = segments[i];
                    Curve thisCurve = (Curve)obj;
                    switch (thisCurve.GetType().Name)
                        case "Line":
                                Line line = (Line)obj;
                                if (line.StartPoint.Equals(TmpPoint))
                                    pl.AddVertexAt(j, new Point2d(line.StartPoint.X, line.StartPoint.Y), 0, 0, 0);
                                    break;
                                if (line.EndPoint.Equals(TmpPoint))
                                    pl.AddVertexAt(j, new Point2d(line.EndPoint.X, line.EndPoint.Y), 0, 0, 0);
                                    TmpPoint = line.StartPoint;
                                    break;
                            break;
                        case "Arc":
                            Arc arc = (Arc)obj;
                            if (arc.StartPoint.Equals(TmpPoint))
                                double bulge = Math.Tan(dltAng / 4.0);
                                pl.AddVertexAt(0,
                                               bulge, 0, 0);
                                j = j + 1;
                                pl.AddVertexAt(1, new Autodesk.AutoCAD.Geometry.Point2d(arc.EndPoint.X, arc.EndPoint.Y),
                                               0, 0, 0);
                                break;
                            if (arc.EndPoint.Equals(TmpPoint))
                                double dltAng = -1*(arc.EndAngle - arc.StartAngle);
                                // if (dltAng < 0.0) dltAng += Math.PI * 2; //圆弧的结束角比开始角大时
                                double bulge = dltAng; //Math.Tan(dltAng / 4.0);
                                pl.AddVertexAt(0,new Autodesk.AutoCAD.Geometry.Point2d(arc.EndPoint.X, arc.EndPoint.Y),
                                               bulge, 0, 0);
                                j = j + 1;
                                pl.AddVertexAt(1, new Autodesk.AutoCAD.Geometry.Point2d(arc.StartPoint.X, arc.StartPoint.Y),
                                               0, 0, 0);
                                TmpPoint = arc.StartPoint;
                                break;
                            break;
            pl.Closed = true;
            return pl;
发表于 2013-6-2 15:52:55 | 显示全部楼层
我也很关心这个问题,不知楼主解决了没有。另有没有解决这个问题的lisp程序
GMT+8, 2025-5-2 19:14 , Processed in 0.371807 second(s), 24 queries , Gzip On.
