楼主: hehoubin
跪求一个命令做好建立指定块名的块、重新建立定块名的块,重复插入块的功能
 楼主| 发表于 2012-10-1 21:08:05 | 显示全部楼层
能写个全的吗
 楼主| 发表于 2012-10-1 21:14:35 | 显示全部楼层
Y轴第二点Y轴的正数方向,X轴的90度角
x轴第二点x轴的负数数方向,y轴的90度角
 楼主| 发表于 2012-10-1 21:22:36 | 显示全部楼层
老师这样能写吗
发表于 2012-10-1 21:40:30 | 显示全部楼层
看来您得琢磨琢磨 Mirror 命令
弄通了才知命令列需要什么样的回应值
(程序也是接手人的回应而已)
 楼主| 发表于 2012-10-1 22:03:17 | 显示全部楼层
例如这个Y轴镜像不是平行Y 轴的正数方向的另一个点就可以可以镜像吗
 楼主| 发表于 2012-10-1 22:08:54 | 显示全部楼层
我发个附件您
 楼主| 发表于 2012-10-1 22:48:09 | 显示全部楼层
http://www.mjtd.com/forum.php?mod=attachment&aid=NzA3Nzh8YTEyYmI2ZjRjNDcwYzFjYWIzNTA2ZWJiNjFjOGMzNDV8MTc0NjI2NDkyOQ%3D%3D&request=yes&_f=.rar
 楼主| 发表于 2012-10-1 22:58:19 | 显示全部楼层
 楼主| 发表于 2012-10-1 23:02:57 | 显示全部楼层
老师按文件的那样可以写了吗
发表于 2012-10-2 08:55:00 | 显示全部楼层
镜像处理只部份理解 ...
  1. (defun jk1 (msg blk)
  2.   (princ msg)
  3.   (setq ss (ssget)
  4.         pt (getpoint "\nBase point: ")
  5.   )
  6.   (command "_block" blk "non" pt ss "")
  7.   (command "_insert" blk "non" pt "" "" "")
  8. )
  9. (defun jk2(msg blk)
  10.   (princ msg)
  11.   (setq ss (ssget)
  12.         pt (getpoint "\nBase point: ")
  13.   )
  14.   (command "_block" blk "y" "non" pt ss "")
  15.   (command "_insert" blk "non" pt "" "" "")
  16. )
  17. (defun c:c1 ();/ pt ss)
  18.   (if (tblsearch "block" "C1")
  19.     (progn
  20.       (initget 1 "C")
  21.       ;; 提示((C)重新建C1块)的可选项
  22.       (setq pt (getpoint "\nInsert point or (C)重新建C1块: "))
  23.       (cond
  24.        ((= pt "C") (jk2 "重新建C1块: " "C1"))
  25.        (T
  26.         ;; 添加一个将 (“C1块”镜像后插入)的可选项
  27.         (initget "No Yes")
  28.         (setq ans (GetKword "\n “C1块”要镜像吗?: <No> / Yes: "))
  29.         (command "_insert" "C1" "non" pt "" "" "")
  30.         ;; Mirror
  31.         (cond
  32.          ((= ans "Yes")
  33.           ;; 此处仍得探讨
  34.           (command "Mirror" (entlast) "" "non" pt)
  35.           (while (= (logand (getvar "CmdActive") 1) 1) (command pause))
  36.      )))))
  37.      (jk1 "\n请选择创建块C1的图元: " "C1")
  38.    )
  39.    (princ)
  40. )
GMT+8, 2025-5-3 17:35 , Processed in 0.295837 second(s), 18 queries , Gzip On.
