查看: 3450|回复: 10
如何整齐划一
发表于 2012-9-22 21:50:56 | 显示全部楼层 |阅读模式
请问如何 把图形里面重复的线删掉,变成单一的一条线,封闭的图形?谢谢!
发表于 2012-9-23 09:16:38 | 显示全部楼层
  1. (defun c:sccf(/ dxf tang chg_ent on_ent undup os 2pi sline sarc scircle n ss ent pmt)
  2.      (setvar "cmdecho" 0)
  3.   (defun dxf(ent i)
  4.     (cdr (assoc i (entget ent)))
  5.   )
  6.   (defun tang(ang sty)
  7.     (rem (+ 2pi ang) sty)
  8.   )
  9.   (defun chg_ent(ent i pt / en)
  10.     (setq en (entget ent) en (subst (cons i pt) (assoc i en) en))
  11.     (entmod en)
  12.   )
  13.   (defun on_ent(a a1 a2 sty)
  14.     (if (= sty "直线")
  15.       (equal (+ (distance a1 a) (distance a a2)) (distance a1 a2) 0.01)
  16.       (if (> a2 a1) (>= a2 a a1) (or (<= a a2) (>= a a1)))
  17.     )
  18.   )
  19.   (defun undup(s sty / nm m ss ent1 spt1 ept1 cpt1 r1 ent2 spt2 ept2 cpt2 r2)
  20.     (setq n -1 nm 0)
  21.     (if (= sty "圆")
  22.       (repeat (sslength s)
  23.         (setq ent1 (ssname s (setq n (1+ n))))
  24.         (if (entget ent1)
  25.           (progn
  26.             (setq cpt1 (dxf ent1 10) r1 (dxf ent1 40))
  27.             (if (setq ss (ssget "x" (list (cons 0 "circle") (cons 10 cpt1) (cons 40 r1))))
  28.               (progn
  29.                 (ssdel ent1 ss)
  30.                 (setq m -1)
  31.                 (repeat (sslength ss)
  32.                   (setq ent (ssname ss (setq m (1+ m))))
  33.                   (if (not (ssmemb ent s))
  34.                     (progn
  35.                       (ssdel ent ss)
  36.                       (setq m (1- m))
  37.                     )
  38.                   )
  39.                 )
  40.                 (command "_.erase" ss "")
  41.                 (setq nm (+ nm (sslength ss)))
  42.               )
  43.             )
  44.           )
  45.         )
  46.       )
  47.       (repeat (sslength s)
  48.         (setq ent1 (ssname s (setq n (1+ n))))
  49.         (if (entget ent1)
  50.           (progn
  51.             (if (= sty "直线")
  52.               (setq spt1 (dxf ent1 10) ept1 (dxf ent1 11))
  53.               (setq spt1 (tang (dxf ent1 50) 2pi)
  54.                     ept1 (tang (dxf ent1 51) 2pi)
  55.                     cpt1 (dxf ent1 10)
  56.                     r1 (dxf ent1 40)
  57.               )
  58.             )
  59.             (if (setq ss (if (= sty "直线")
  60.                            (ssget "cp" (list (polar spt1 (angle ept1 spt1) 0.1)
  61.                                              (polar ept1 (- (angle spt1 ept1) (/ pi 4)) 0.15)
  62.                                              (polar ept1 (+ (angle spt1 ept1) (/ pi 4)) 0.15)
  63.                                        ) '((0 . "line"))
  64.                            )
  65.                            (ssget "x" (list (cons 0 "arc") (cons 10 cpt1) (cons 40 r1)))
  66.                          )
  67.                 )
  68.               (progn
  69.                 (ssdel ent1 ss)
  70.                 (setq m -1)
  71.                 (repeat (sslength ss)
  72.                   (setq ent (ssname ss (setq m (1+ m))))
  73.                   (if (not (ssmemb ent s))
  74.                     (progn
  75.                       (ssdel ent ss)
  76.                       (setq m (1- m))
  77.                     )
  78.                   )
  79.                 )
  80.                 (setq m -1)
  81.                 (repeat (sslength ss)
  82.                   (setq ent2 (ssname ss (setq m (1+ m))))
  83.                   (if (= sty "直线")
  84.                     (setq spt2 (dxf ent2 10)
  85.                           ept2 (dxf ent2 11)
  86.                     )
  87.                     (setq spt2 (tang (dxf ent2 50) 2pi)
  88.                           ept2 (tang (dxf ent2 51) 2pi)
  89.                           cpt2 (dxf ent2 10)
  90.                           r2 (dxf ent2 40)
  91.                     )
  92.                   )
  93.                   (cond
  94.                     ((and (on_ent spt2 spt1 ept1 sty) (on_ent ept2 spt1 ept1 sty))
  95.                       (entdel ent2)
  96.                     )
  97.                     ((and (on_ent spt1 spt2 ept2 sty) (on_ent ept1 spt2 ept2 sty))
  98.                       (entdel ent1)
  99.                       (setq ent1 ent2 spt1 spt2 ept1 ept2)
  100.                       (if (= sty "圆弧")
  101.                         (setq cpt1 cpt2 r1 r2)
  102.                       )
  103.                     )
  104.                     ((and (if (= sty "直线")
  105.                             (equal (tang (angle spt1 ept1) pi) (tang (angle spt2 ept2) pi) 0.001)
  106.                             T
  107.                           )
  108.                           (or (on_ent spt2 spt1 ept1 sty) (on_ent ept2 spt1 ept1 sty))
  109.                      )
  110.                       (entdel ent2)
  111.                       (if (= sty "直线")
  112.                         (progn
  113.                           (if (on_ent spt2 spt1 ept1 sty)
  114.                             (setq spt2 ept2)
  115.                           )
  116.                           (if (> (distance spt1 spt2) (distance ept1 spt2))
  117.                             (progn (chg_ent ent1 11 spt2) (setq ept1 spt2))
  118.                             (progn (chg_ent ent1 10 spt2) (setq spt1 spt2))
  119.                           )
  120.                         )
  121.                         (if (on_ent spt2 spt1 ept1 sty)
  122.                           (progn (chg_ent ent1 51 ept2) (setq ept1 ept2))
  123.                           (progn (chg_ent ent1 50 spt2) (setq spt1 spt2))
  124.                         )
  125.                       )
  126.                     )
  127.                     (T (setq nm (1- nm)))
  128.                   )
  129.                   (setq nm (1+ nm))
  130.                 )
  131.               )
  132.             )
  133.           )
  134.         )
  135.       )
  136.     )
  137.     (prompt (strcat "-->共选到:" (itoa (sslength s)) "个" sty ",消去" (itoa nm) "个。"))
  138.   )
  139.   (command "_.undo" "_be")
  140.   (command "_.ucs" "")
  141.   (setq os (getvar "osmode")
  142.         2pi (* 2 pi)
  143.         sline (ssadd)
  144.         sarc (ssadd)
  145.         scircle (ssadd)
  146.         n -1
  147.   )
  148.   (setvar "cmdecho" 0)
  149.   (setvar "osmode" 0)
  150.   (prompt "\n-->请选取(直线、圆弧或圆):")
  151.   (if (setq ss (ssget '((0 . "line,arc,circle"))))
  152.     (progn
  153.       (prompt "\n-->正在消除合并重复线条,请稍候...")
  154.       (prompt "\n")
  155.       (repeat (sslength ss)
  156.         (setq ent (ssname ss (setq n (1+ n))))
  157.         (cond
  158.           ((= (dxf ent 0) "LINE") (ssadd ent sline))
  159.           ((= (dxf ent 0) "ARC") (ssadd ent sarc))
  160.           ((= (dxf ent 0) "CIRCLE") (ssadd ent scircle))
  161.         )
  162.       )
  163.     )
  164.   )
  165.   (if (> (sslength sline) 1) (progn (undup sline "直线") (setq pmt T)))
  166.   (if (> (sslength sarc) 1) (progn (undup sarc "圆弧") (setq pmt T)))
  167.   (if (> (sslength scircle) 1) (progn (undup scircle "圆") (setq pmt T)))
  168.   (if (and ss (not pmt)) (prompt "\n没有重复实体!"))
  169.   (setvar "osmode" os)
  170.   (command "_.undo" "_e")
  171.     (PRINC))
发表于 2012-9-23 09:18:37 | 显示全部楼层
CAD自带overkill删除重复对象
 楼主| 发表于 2012-9-23 11:58:05 | 显示全部楼层
杨如迁 发表于 2012-9-23 09:18
CAD自带overkill删除重复对象
我试试  谢谢
 楼主| 发表于 2012-9-23 15:34:49 | 显示全部楼层
CAD自带overkill删除重复对象
你好,请问可不可以实现:图形改成一条连续的封闭的图形呢?谢谢!
发表于 2012-9-23 18:20:08 | 显示全部楼层
CAD自动的合并命令就可以
 楼主| 发表于 2012-9-24 08:13:17 | 显示全部楼层
【KAIXIN】 发表于 2012-9-23 18:20
CAD自动的合并命令就可以
你好  能说详细一点么  谢谢啦
发表于 2012-9-24 08:25:29 | 显示全部楼层
水上浮舟 发表于 2012-9-24 08:13
你好  能说详细一点么  谢谢啦
  1. ;批量连线(相连的线成一条)
  2. (DEFUN C:XX (/ KX)
  3.       (PRINC "\n-->请框选LINE,ARC,LWPOLYLINE,POLYLINE:")
  4.     (setvar "peditaccept" 1) ;加入这个系统变量的代码
  5.     (if (setq KX (ssget '((0 . "LINE,ARC,LWPOLYLINE,POLYLINE"))))
  6.         (command "_pedit" "m" KX "" "j" "0.1" "")
  7.     )
  8. )
 楼主| 发表于 2012-9-25 08:14:08 | 显示全部楼层
【KAIXIN】 发表于 2012-9-24 08:25
请问这样处理过的图形 是封闭的一条线么?
自行测试  发表于 2012-9-25 08:24
 楼主| 发表于 2012-9-25 15:43:37 | 显示全部楼层
试过了,只有部分了连接到一起了,如果能整体连接到一起就好了!
GMT+8, 2025-5-3 04:05 , Processed in 0.252437 second(s), 29 queries , Gzip On.
