查看: 2285|回复: 0
帮忙找找错
发表于 2012-9-17 20:56:24 | 显示全部楼层 |阅读模式
    static UINT Test(LPVOID lparam) //     static DWORD WINAPI Test(LPVOID lparam)
        Acad::ErrorStatus es = eNotImplementedYet;
        TCHAR file[][255] = {_T("E:\\caddata_2012\\a.dwg"),
            _T("E:\\caddata_2012\\b.DWG"),
            _T("E:\\caddata_2012\\c.DWG")
//         es = acDocManager->lockDocument(curDoc(), AcAp::kWrite, NULL, NULL, true);
        for (int i = 0; i < 3; i++)
            CString strFPath(*(file + i));
            // 获取数据库
            AcDbDatabase* pDatabase = new AcDbDatabase(Adesk::kFalse);
            es = pDatabase->readDwgFile(*(file + i)/*strFPath.GetBuffer(0)*/);//eNoInputFiler
            es = pDatabase->saveAs(strFPath.GetBuffer(0));
            if (pDatabase != NULL)
                delete pDatabase;//crash 3
                pDatabase = NULL;
//         es = acDocManager->unlockDocument(curDoc());
        return 1;
    // - ForTest.MyT command (do not rename)
    static void ForTestMyT(void)
        // Add your code for command ForTest.MyT here
        AfxBeginThread(Test, NULL);
//         CreateThread(NULL, NULL, Test, NULL, NULL, NULL);
//         TCHAR file[][255] = {_T("E:\\caddata_2012\\288-100-2-05.dwg"),
//             _T("E:\\caddata_2012\\288-100-4-03.DWG"),
//             _T("E:\\caddata_2012\\288-100-4-04.DWG")
//         for (int i = 0; i < 3; i++)
//             CString strFPath(*(file + i));
//             // 获取数据库
//             AcDbDatabase* pDatabase = new AcDbDatabase(Adesk::kFalse);
//             es = pDatabase->readDwgFile(/**(file + i)*/strFPath.GetBuffer(0));
//             es = pDatabase->saveAs(strFPath.GetBuffer(0));
//             if (pDatabase != NULL)
//                 delete pDatabase;//crash 3
//                 pDatabase = NULL;
IMPLEMENT_ARX_ENTRYPOINT(CForTestApp)
ACED_ARXCOMMAND_ENTRY_AUTO(CForTestApp, ForTest, MyT, MyT, ACRX_CMD_TRANSPARENT, NULL)
使用cad2012加载编出来的arx
这段代码用vs2010+arx2012 编出来在虚拟机里面加载时cad会提示兼容性的问题,运行的时候没什么问题。但是编出release版本在真机里面依然会有兼容性的提示,而且在运行时会发生异常...
有人清楚是怎么回事么?
先谢谢了哈
GMT+8, 2025-5-1 13:46 , Processed in 0.154752 second(s), 25 queries , Gzip On.
