楼主: 半听可乐
大旱盼甘霖,程序盼完善!
 楼主| 发表于 2012-9-26 17:04:16 | 显示全部楼层
渴望高手帮忙中……
发表于 2012-9-27 18:42:39 | 显示全部楼层
可以画楼梯踏步。可以扩展成点钢筋,可以扩展成多行文字
 楼主| 发表于 2012-12-1 17:30:43 来自手机 | 显示全部楼层
不甘心就这样不了了之…
发表于 2012-12-1 23:56:25 | 显示全部楼层
加个一个简单的扑捉
;;; ★hvlines 动态垂直水平线
;;;  By  tjuzkj  明经社区分享  http://bbs.mjtd.com/thread-91313-1-1.html
(defun c:hvlines (/ g1 g2 gr h l lst ms nearpt p p1 pt1 pt2 pt3 pt4 ptx pty v x) ; Lee Mac 2011
  (defun *error* (m)
    (redraw)
  (or
    *n
    (setq *n 3)
  (if (setq p1 (getpoint "\n指定第一个角点: "))
      (setq ms (princ "\n指定对角点 [TAB/+/-]: "))
      (while (progn
        (setq gr (grread t 15 0)
       g1 (car gr)
       g2 (cadr gr)
        (cond
   ((= 5 g1)
     (redraw)
     (if (setq nearpt (osnap g2 "_END,_MID,CEN,NOD,QUA,INT,INS,PER")) ; 取得最近的捕捉点
       (PROGN
         (setq g2 nearpt)
         (setq h (/ (getvar "viewsize") (cadr (getvar "screensize")))
        d (getvar "pickbox")
        lst (list (* d h) (* (- d 0.5) h) (* (+ d 0.5) h))
        ptx (car g2)
        pty (cadr g2)
         (foreach x lst
    (setq pt1 (list (- ptx x) (- pty x))
          pt2 (list (+ ptx x) (- pty x))
          pt3 (list (+ ptx x) (+ pty x))
          pt4 (list (- ptx x) (+ pty x))
    (grvecs (list 2 pt1 pt2 pt2 pt3 pt3 pt4 pt4 pt1))
     (if *v
         (setq h (/ (- (car g2) (car p1)) (1+ *n))
        v (- (cadr g2) (cadr p1))
        p p1
         (repeat *n
    (setq p (list (+ h (car p)) (cadr p) (caddr p)))
    (grdraw p (list (car p) (+ v (cadr p)) (caddr p)) -1)
         (setq l (list p1 (list (car p1) (+ v (cadr p1)) (caddr p1)) g2 (list (+ h (car p)) (cadr p)
               (caddr p)
         (setq h (- (car g2) (car p1))
        v (/ (- (cadr g2) (cadr p1)) (1+ *n))
        p p1
         (repeat *n
    (setq p (list (car p) (+ v (cadr p)) (caddr p)))
    (grdraw p (list (+ (car p) h) (cadr p) (caddr p)) -1)
         (setq l (list p1 (list (+ (car p1) h) (cadr p1) (caddr p1)) g2 (list (car p) (+ v (cadr p))
               (caddr p)
     (mapcar
       '(lambda (a b)
   (grdraw a b 1 -1)
       l
       (append
         (cdr l)
         (list (car l))
   ((= 2 g1)
     (cond
       ((member g2 '(45 95))
         (if (= 1 *n)
    (princ (strcat "\n--> 行数达到最小2。" (substr ms 2)))
    (setq *n (1- *n))
       ((member g2 '(43 61))
         (setq *n (1+ *n))
       ((= 9 g2)
         (setq *v (not *v))
         t
   ((= 3 g1)
       (setq g2 nearpt)
     (if *v
         (repeat *n
    (setq p1 (list (+ h (car p1)) (cadr p1) (caddr p1)))
    (entmakex (list (cons 0 "LINE") (cons 10 (trans p1 1 0)) (cons 11 (trans (list (car p1) (+ v
                  (cadr p1)
             (caddr p1)
              ) 1 0
         (repeat *n
    (setq p1 (list (car p1) (+ v (cadr p1)) (caddr p1)))
    (entmakex (list (cons 0 "LINE") (cons 10 (trans p1 1 0)) (cons 11 (trans (list (+ (car p1) h)
             (cadr p1)
             (caddr p1)
              ) 1 0
     nil
  (redraw)
发表于 2012-12-2 08:06:04 来自手机 | 显示全部楼层
学习学习。
 楼主| 发表于 2012-12-2 09:52:08 | 显示全部楼层
langjs 发表于 2012-12-1 23:56
加个一个简单的扑捉
谢谢狼大侠!能不能进一步完善成我一楼描述的那样呢?
发表于 2012-12-2 13:19:07 | 显示全部楼层
太牛了,
发表于 2012-12-2 13:46:29 | 显示全部楼层
动态交点布块就爽了。
发表于 2012-12-2 14:36:31 | 显示全部楼层
;; 预览
从间距数据来看,院长莫非也是管道专业出身? 1.画出来的是个块?我想要一根根的line 2.主要间距和边缘间距能根据不同边界同时满足? 3.希望保留动态预览的效果,并且可以动态加减line,从而调整间距  发表于 2012-12-2 15:08
发表于 2012-12-2 17:57:07 | 显示全部楼层
GMT+8, 2025-7-15 19:02 , Processed in 0.192503 second(s), 20 queries , Gzip On.
