查看: 2257|回复: 3
请教各位大能,如何新建mline实体啊
发表于 2012-8-19 13:40:13 来自手机 | 显示全部楼层 |阅读模式
如何用代码新建mline实体啊,是不是用Mline.AppendSegment(Point3d)方法新建mline实体啊,我用这个方法写的代码,调试时在这一行出现eInvaildStyle异常
[CommandMethod("lp")]
        public static void Multline()
            Database db = HostApplicationServices.WorkingDatabase;
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            PromptPointResult ppr1 = doc.Editor.GetPoint("\nspecial start point1");
            PromptPointResult ppr2 = doc.Editor.GetPoint("\nspecial start point2");
            Point3d pt1 = new Point3d(((ppr1.Value.X + ppr2.Value.X) / 2), ((ppr1.Value.Y + ppr2.Value.Y) / 2), 0);
            PromptPointResult ppr3 = doc.Editor.GetPoint("\nspecial end point");
            Point3d pt2 = ppr3.Value;
            double l = Math.Sqrt(Math.Pow((ppr2.Value.X - ppr1.Value.X), 2) + Math.Pow((ppr1.Value.Y - ppr2.Value.Y), 2));
            using (Transaction trans = db.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
                BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                Mline ml = new Mline();
                ml.SetDatabaseDefaults();
                ml.Scale = l;
                ml.AppendSegment(pt1);
                ml.AppendSegment(pt2);
                btr.AppendEntity(ml);
                trans.AddNewlyCreatedDBObject(ml, true);
                trans.Commit();
 楼主| 发表于 2012-8-22 12:23:45 | 显示全部楼层
我自己研究出来了,这个命令是用3点画MLINE,第一点第二点的距离是MLINE的SCALE,第一点第二点的中点是MLINE的起点,第三点是MLINE的终点。下面是代码
                DBDictionary MlineStyleDic = (DBDictionary)trans.GetObject(db.MLStyleDictionaryId, OpenMode.ForWrite);
                MlineStyle ms = new MlineStyle();
                ms = (MlineStyle)trans.GetObject(MlineStyleDic.GetAt("STANDARD"), OpenMode.ForRead);
                ml.Style = ms.ObjectId;
                ml.Scale = l;
                ml.Justification = MlineJustification.Zero;
                Vector3d vec = new Vector3d(0,0,1);
                ml.Normal = vec;
                trans.Commit();
发表于 2012-8-22 12:55:46 | 显示全部楼层
public double DistanceTo(Autodesk.AutoCAD.Geometry.Point3d point)
    Autodesk.AutoCAD.Geometry.Point3d 的成员
发表于 2012-8-26 06:57:05 | 显示全部楼层
学习了,呵呵
GMT+8, 2025-5-3 07:24 , Processed in 0.154021 second(s), 24 queries , Gzip On.
