查看: 1380|回复: 2
请教高手,vba怎样赋属性
发表于 2012-8-15 16:34:51 | 显示全部楼层 |阅读模式
我需要将界址点的点号赋到界址点的属性或扩展属性里,在插入块时能实现赋属性吗?我是新手,
用vba能实现插块和注记文字,但不会赋属性值,请高手教教我!
Private Sub CommandButton1_Click()
  Dim JPD As Integer
      Dim JX As String
      Dim QSDH As Integer
      Dim ZJDH As String
      Dim zqdm As String
      prompt1 = vbCrLf & "请选择界址点注记位置: "
      startpnt = ThisDrawing.Utility.GetPoint(, prompt1)
      x1 = startpnt(0)
      y1 = startpnt(1)
       jZD(0) = x1
       jZD(1) = y1
      jZDZJ(0) = x1 + 9
      jZDZJ(1) = y1 - 7.5
     ZJDH="zj2"
    '插界址点块
      Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(jZD, "JZD.dwg", 1, 1, 1, 0)
      '如果没有块
      If Err Then
        MsgBox Err
        Exit Sub
      Else
  '怎样在这里实现将界址点号赋到扩展属性里????
      End If
'定义扩展属性
  Dim JPD As Integer
      Dim JX As String
      Dim QSDH As Integer
      Dim ZJDH As String
      Dim zqdm As String
      x1 = startpnt(0)
      y1 = startpnt(1)
       jZD(0) = x1
       jZD(1) = y1
      jZDZJ(0) = x1 + 9
      jZDZJ(1) = y1 - 7.5
     ZJDH="zj2"
    '插界址点块
      '如果没有块
      If Err Then
        MsgBox Err
        Exit Sub
      End If
'定义扩展属性
  '怎样在这里赋点号给块,在扩展属性里最好
     '定义文字样式
     Dim TextColl As AcadTextStyles
     Dim textStyle As AcadTextStyle
     Set textStyle = ThisDrawing.TextStyles.Add("JZDHT")
    textStyle.fontFile = "C:\WINDOWS\Fonts\SIMHEI.TTF"
     textStyle.Width = 17
    textStyle.Height = 17
                Set tmlay = ThisDrawing.Layers.Add("JZP")
                                         tmlay.color = acRed
                       ThisDrawing.ActiveLayer = tmlay
                  Set textobj = ThisDrawing.ModelSpace.AddText(ZJDH, jZDZJ, 17)
                    textobj.ScaleFactor = 1
                    textobj.Update
                    textobj.Alignment = acAlignmentBottomLeft
                  ' textobj.Alignment = acAlignmentMiddle
                    textobj.TextAlignmentPoint = jZDZJ
                   textobj.StyleName = "JZDHT"
End Sub
 楼主| 发表于 2012-8-16 22:19:30 | 显示全部楼层
没人
发表于 2012-8-20 08:12:40 | 显示全部楼层
Dim atr As Variant
atr = blockRefObj.GetAttributes
atr(0).TextString = 点号
GMT+8, 2025-5-29 04:16 , Processed in 0.159774 second(s), 25 queries , Gzip On.
