楼主: 仲文玉
标注线段长度【文字方式】
发表于 2013-11-1 19:26:25 | 显示全部楼层
为什么我还是无法运行呢?输入什么命令运行?我04.06.08版cad都是过了,加载后,cad命令ksbz没法运行
发表于 2013-12-27 16:14:44 | 显示全部楼层
好东西,太有用了
发表于 2014-4-10 14:54:45 | 显示全部楼层
标注乱发,怎么修改
删了  发表于 2014-4-15 19:36
发表于 2014-6-20 16:53:47 | 显示全部楼层
如何下载嘛?
发表于 2014-11-15 23:28:24 | 显示全部楼层
好,很好的直线标注工具,谢过楼主了!
发表于 2014-11-16 11:22:53 | 显示全部楼层
ppp'
发表于 2014-11-18 00:04:31 | 显示全部楼层
pl线乱跳,麻烦楼主有空修改下!
发表于 2014-11-18 08:58:28 | 显示全部楼层
错误: no function definition: VLAX-GET-ACAD-OBJECT???为何
发表于 2014-12-3 20:06:31 | 显示全部楼层
老大这个利害!多谢了!
发表于 2014-12-6 17:51:42 | 显示全部楼层
;;;多义线边长标注
(defun HH:Remove (en / NEWDATA)
  (foreach e (entget en)
    (if (and (member e newdata) (= 10 (car e)))
      nil
      (setq newdata (cons e newdata))
  (entmod (reverse newdata))
(defun c:bcbz (/ obj pianju sHandle  pt np gx bj np xc  rr  cp n ang1 zjp ms AddText pen-n pen-all)
;;;构造text
(command "layer" "M" "边长标注" "C" "6" "" "LT" "CONTINUOUS" "" "");设置一个标注图层
(command "style" "hz" "宋体" "0" "" "0" "" "")
(setvar"dimzin"0);;保留小数位数时如果位数不足可以补零
  (defun AddText (obj TextString  InsertionPoint  Height xz kb qx Alignment style / obj1 err)
  (setq obj1 (vla-addtext obj TextString  (vlax-3d-point InsertionPoint)  Height))
  (vla-put-Rotation obj1 xz)
  (vla-put-ScaleFactor obj1 kb)
  (vla-put-ObliqueAngle obj1 qx)
  (vla-put-alignment obj1 Alignment)
  (if (/= Alignment acAlignmentLeft)
    (vla-put-TextAlignmentPoint obj1 (vlax-3d-point InsertionPoint))
    (vla-put-InsertionPoint obj1 (vlax-3d-point InsertionPoint))
   (VL-CATCH-ALL-APPLY 'vla-put-StyleName (list obj1 style))
  obj1
(setq pi2 (/ pi 2))
  (setq ms (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))))
(setq  bcHeight (getdist "\n输入标注文字高度:");文字高度
        kgb         0.60 ; 宽高比
      DimScale 1 ; 边长尺度,若单位为mm,该值为1000
        flag        nil;nil标注在多段线走向的右侧,T 左侧
) ;_ setq
(while
(setq pen-n 0)
(if (setq pen-all (ssget '((0 . "*polyline"))))
    (repeat (sslength pen-all)
            (setq pianju (* bcHeight 0.7)) ;边长离线距离
            (setq pen-en (ssname pen-all pen-n))
            (setq obj (vlax-ename->vla-object pen-en)
                  n 0)
              (while (and (setq pt (vlax-curve-getPointAtParam obj n))
              (setq np (vlax-curve-getPointAtParam obj (1+ n)))
         ) ;_ 结束and
    (if        (/= 0.0 (setq bugle (vla-GetBulge obj n)))
        (setq midpt (vlax-curve-getPointAtParam obj (+ 0.5 n))
             bj (* (atan (abs bugle)) 4)
            xc (* 0.5 (distance Pt np))
            gg (abs (* bugle xc))
            rr (/ (+ (* xc xc) (* gg gg)) (* 2 gg))
            ang1 (angle pt np)
            cp (polar Pt ang1 xc)
            cp (polar midpt (angle midpt cp) rr)
            bc (rtos (/ (- (vlax-curve-getDistAtParam obj (1+ n)) (vlax-curve-getDistAtParam obj n)) DimScale) 2 2)
       (if flag
            (setq zjp (polar midpt (cond ((> bugle 0)(angle midpt cp))(t (angle  cp midpt))) pianju))
            (setq zjp  (polar midpt (cond ((> bugle 0)(angle  cp midpt))(t (angle midpt cp))) pianju))
        (if (not (or (and (>= ang1 0) (< ang1 (* 0.666666 pi))) (and (> ang1 (* 1.666666 pi)) (< ang1 (* 2.0 pi)))))
         (setq ang1 (- ang1 pi))
        (AddText ms bc  zjp  bcHeight ang1 kgb 0 acAlignmentMiddle Style)
     );progn
              ang1 (angle pt np)
        (if flag
            (setq zjp (polar midpt (+ pi2 ang1) pianju))
          (setq zjp (polar midpt (- ang1 pi2) pianju))
        (if (not (or (and (>= ang1 0) (< ang1 (* 0.666666 pi))) (and (> ang1 (* 1.666666 pi)) (<= ang1 (* 2.0 pi)))))
      );progn
    ) ;结束if
    (setq n (1+ n))
  ) ; 结束while
  (setq pen-n (1+ pen-n)))
GMT+8, 2025-8-25 14:13 , Processed in 0.253957 second(s), 20 queries , Gzip On.
