查看: 2047|回复: 9
【请教】关于打开图纸炸碎另存无效的问题
发表于 2012-7-27 12:05:25 | 显示全部楼层 |阅读模式
最近在做处理历史图纸的工作,过程如下:
1、打开原图纸,剔除不需处理的信息,另存为*-1.dwg;
2、打开原图纸,剔除需要处理的信息,另存为*-2.dwg;
3、打开*-1.dwg,执行explode命令,另存为*-3.dwg;
4、打开*-3.dwg,提取处理的信息,另存为*.xls;
5、打开*-2.dwg,添加从*.xls中读取的信息,另存为*-new.dwg。
编写的程序前2步执行良好,但是第3步发生问题,炸碎的图形保存后,仍是炸碎前的样子。不知道问题出在哪里,请大家伙提供宝贵意见和指导,谢谢!
第3步的程序如下:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.IO;
using System.Text.RegularExpressions;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(CNPTCAD.testGetInfoFromDwg))]
namespace CNPTCAD
    class testGetInfoFromDwg
        [CommandMethod("testGetInfoFromDwg",CommandFlags.Session)]
        //[CommandMethod("testGetInfoFromDwg")]
        public static void DotestGetInfoFromDwg()
            OpenFileDialog openFileDialog3 = new OpenFileDialog();
            openFileDialog3.Multiselect = false;
            openFileDialog3.Filter = "AutoCAD  files  (*.dwg)|*.dwg";
            openFileDialog3.FilterIndex = 0;
            openFileDialog3.RestoreDirectory = true;
            openFileDialog3.Title = "test";
            if (openFileDialog3.ShowDialog() == DialogResult.OK)
                String filename = openFileDialog3.FileName;
                Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(filename, false);
                DocumentLock doclock = doc.LockDocument();
                int flag = 0;
                if(flag == 0){
                    doc.SendStringToExecute("_ai_selall\n", false, false, true);
                    flag = 1;
                    //Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(flag.ToString());
               if(flag == 1){
                    doc.SendStringToExecute("explode\n", false, false, true);
                    flag = 2;
               if (flag == 2)
                   doc.Database.SaveAs(filename.Substring(0, filename.Length - 10) + "_3.dwg", DwgVersion.Newest);
                   flag = 3;
                doclock.Dispose();
                //下面这句屏蔽的话,可以看到原图形确实被炸碎了
                //doc.CloseAndDiscard();
发表于 2012-7-27 17:43:57 | 显示全部楼层
顾名思义,保存并丢弃,就是保存但是放弃对数据库的操作
发表于 2012-7-27 21:03:43 | 显示全部楼层
楼上的说法貌似合理,但应该是对于当前文件来说吧?
doc.Database.SaveAs(filename.Substring(0, filename.Length - 10) + "_3.dwg", DwgVersion.Newest);  这句是另存到了新的文件哦,新的文件情况怎样?
发表于 2012-7-27 21:09:52 | 显示全部楼层
1,我妹见过这样的做法,不过看上去应该是可行的;
2,同二楼的思路,把doc.CloseAndDiscard(); 改成doc. CloseAndSave(string fileName);试试,看看新旧两个文件都是什么情况;
3,  DocumentLock doclock = doc.LockDocument();去掉或用LockDocument(DocumentLockMode lockMode, string globalCommandName, string localCommandName, bool promptIfFails),lockMode多用几个试试
 楼主| 发表于 2012-7-30 09:00:04 | 显示全部楼层
首先感谢楼上两位的帮助!
1、我加//doc.CloseAndDiscard(); 的意思是想说,原图不关闭可以看到确实被炸开了,但是另存的dwg却发现没有炸开;
2、doc. CloseAndSave(string fileName);这句我也试了,应该是执行原图保存和关闭,但实际上也没有执行,只是关闭了,炸开的效果没有保存;
3、DocumentLock doclock = doc.LockDocument();这句不要的话,是要报错的,因为有对文件的操作。
目前我是用了SendStringToExecute的方法,分别执行_ai_selal, explode, _qsave, _close 来完成功能的,虽然比较笨,但是还算好用,呵呵。
发表于 2012-7-31 08:47:05 | 显示全部楼层
尽量不要调用命令 我的建议 SendStringToExecute也不要用 这个方法没什么用
发表于 2012-7-31 20:02:14 | 显示全部楼层
支持斑竹,还是用invoke好
 楼主| 发表于 2012-8-1 11:36:01 | 显示全部楼层
确实如此,因为不确定它的执行时间和顺序,我已经改了代码
发表于 2012-8-1 13:49:31 | 显示全部楼层
发表于 2012-8-2 14:04:32 | 显示全部楼层
GMT+8, 2025-5-26 06:54 , Processed in 0.158959 second(s), 23 queries , Gzip On.
