楼主: aaa862
谁有批量删除短小线的插件
发表于 2021-1-19 23:10:25 | 显示全部楼层
(defun c:eed (/ s n index ent leng)
  (setq entde (ssadd))
  (setq s (ssget "X" '((0 . "line,arc,circle,POLYLINE,LWPOLYLINE,SPLINE"))))
  (setq n (sslength s))
  (setq index (- n 1))
  (repeat n
    (vl-load-com)
    (setq ent (ssname s index))
    (setq curve-obj (vlax-ename->vla-object ent))
    (setq leng (vlax-curve-getDistAtParam
                 curve-obj
                 (vlax-curve-getEndParam curve-obj)
    (setq index (- index 1))
    (if (> leng 0.005)
      T
        (setq entde (ssadd ent entde))
  (command "_.ERASE" entde "")
发表于 2021-4-21 10:40:45 | 显示全部楼层
;批量删除短小线的插件
(defun c:e3 (/ s n index ent leng)
(setvar "cmdecho" 0)(command "UNDO" "G")
(if (not va) (progn (setq va 0.3)) (setq va2 va))
(setq va2 (getreal (strcat "\n請輸入欲删除線长在<0.3>以下之圖元<" (rtos va) ">:")))
(if (not va2) (setq va2 va) (setq va va2))
  (setq s (ssget '((0 . "line,arc,circle,POLYLINE,LWPOLYLINE,SPLINE"))))
  (repeat n
    (vl-load-com)
                 curve-obj
    (if (> leng va2)
      T
  );(prompt (strcat "\r余 " (itoa (- SSL N)) " 个物件     "))
  (setq mm (sslength entde))
;(prompt (strcat "\共删除长度" (itoa (VA2)) "以下图元" (itoa (entde)) " 个 "))
(princ "\n共删除长度")
(princ  va2)
(princ "以下图元")
(princ mm)
(princ"个")
  (command "UNDO" "E")
发表于 2021-4-21 10:42:29 | 显示全部楼层
2496653555 发表于 2021-4-21 10:40
;批量删除短小线的插件
(setvar "cmdecho" 0)(command "UNDO" "G" ...
上面的改了一下,加了输入长度,最后的提示请大神帮忙改下,
发表于 2021-7-21 23:41:46 来自手机 | 显示全部楼层
源码看不懂,能否直接发插件
发表于 2021-7-23 16:43:04 来自手机 | 显示全部楼层
shyshineboy 发表于 2012-10-31 10:26
用cad自带的qs命令选择后 e删除
qs不是保存命令吗
GMT+8, 2025-8-11 20:03 , Processed in 0.134569 second(s), 16 queries , Gzip On.
