查看: 3150|回复: 4
CAD获取一个图形上所有直线的交点
发表于 2012-7-20 11:04:11 | 显示全部楼层 |阅读模式
  1. #region 相交判断
  2.         [CommandMethod("crossCAD")]
  3.         public void CrossCAD()
  4.         {
  5.             TypedValue[] pTypeValue = new TypedValue[1];
  6.             pTypeValue[0] = new TypedValue((int)DxfCode.LayerName, “测试”);
  7.             SelectionFilter pSelectionFilter=new SelectionFilter(pTypeValue);
  8.             PromptSelectionResult selectResult = pDocument.Editor.SelectAll(pSelectionFilter);
  9.             SelectionSet pSelectionSet = selectResult.Value;
  10.             using (Transaction tran = pDatabase.TransactionManager.StartTransaction())
  11.             {
  12.                 List crossPoint = new List();//存放相交点
  13.                 Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(pSelectionSet.Count.ToString());
  14.                 for(int i=0;i= minX && y >= minY && x <= maxX && y<= maxY)
  15.                                     {
  16.                                         #region 确定第二条线的最大最小坐标
  17.                                         if (secondLine.StartPoint.X < secondLine.EndPoint.X)
  18.                                         {
  19.                                             minX = secondLine.StartPoint.X;
  20.                                             maxX = secondLine.EndPoint.X;
  21.                                         }
  22.                                         else
  23.                                         {
  24.                                             minX = secondLine.EndPoint.X;
  25.                                             maxX = secondLine.StartPoint.X;
  26.                                         }
  27.                                         if (secondLine.StartPoint.Y < secondLine.EndPoint.Y)
  28.                                         {
  29.                                             minY = secondLine.StartPoint.Y;
  30.                                             maxY = secondLine.EndPoint.Y;
  31.                                         }
  32.                                         else
  33.                                         {
  34.                                             maxY = secondLine.StartPoint.Y;
  35.                                             minY = secondLine.EndPoint.Y;
  36.                                         }
  37.                                         #endregion
  38.                                         if (x >= minX && y >= minY && x <= maxX && y <= maxY)
  39.                                         {
  40.                                             crossPoint.Add(new Point2d(x, y));
  41.                                         }
  42.                                     }
  43.                                 }
  44.                                 #endregion
  45.                             }
  46.                         }
  47.                     }
  48.                 }
  49.                 if (crossPoint.Count == 1)
  50.                 {
  51.                     Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("交点为:"+crossPoint[0].X.ToString()+","+crossPoint[0].Y.ToString());
  52.                     return;
  53.                 }
  54.                 BlockTable pBlockTable = tran.GetObject(pDatabase.BlockTableId, OpenMode.ForRead) as BlockTable;
  55.                 BlockTableRecord pBlockTableRecord = tran.GetObject(pBlockTable[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
  56.                 for (int i = 0; i < crossPoint.Count; i++)
  57.                 {
  58.                     Circle pCircle = new Circle(new Point3d(crossPoint[i].X, crossPoint[i].Y, 0), Vector3d.ZAxis, 1);
  59.                     pCircle.ColorIndex = 0;
  60.                     pBlockTableRecord.AppendEntity(pCircle);
  61.                     tran.AddNewlyCreatedDBObject(pCircle, true);
  62.                 }
  63.                 tran.Commit();
  64.             }
  65.         }
  66.         #endregion
图层名称我用的是“测试”,大家根据自己需要改下。
通过以上代码可以将一个图层上所有直线相交点用圆的形式标出,希望大家有用
发表于 2012-7-20 12:17:44 | 显示全部楼层
纯数学的方法? 不过好像差点代码。。。
试下这段代码
  1.         [CommandMethod("tx1")]
  2.         public static void CrossCAD()
  3.         {
  4.             var doc = Application.DocumentManager.MdiActiveDocument;
  5.             var db = doc.Database;
  6.             var ed = doc.Editor;
  7.             var sf =
  8.                 new SelectionFilter
  9.                 (
  10.                     new TypedValue[]{ new TypedValue(0, "line")}
  11.                 );
  12.             var res = ed.SelectAll(sf);
  13.             if (res.Status != PromptStatus.OK) return;
  14.             using (var tr = doc.TransactionManager.StartTransaction())
  15.             {
  16.                 var lines = new List<Line>();
  17.                 foreach(ObjectId id in res.Value.GetObjectIds())
  18.                 {
  19.                     lines.Add((Line)tr.GetObject(id, OpenMode.ForRead));
  20.                 }
  21.                 List<Point3d> pts = new List<Point3d>();
  22.                 for (int m = 0; m < lines.Count; m++)
  23.                 {
  24.                     LineSegment3d ls1 = new LineSegment3d(lines[m].StartPoint, lines[m].EndPoint);
  25.                     for (int n = m + 1; n < lines.Count; n++)
  26.                     {
  27.                         LineSegment3d ls2 = new LineSegment3d(lines[n].StartPoint, lines[n].EndPoint);
  28.                         CurveCurveIntersector3d cc3d = new CurveCurveIntersector3d(ls1, ls2, Vector3d.ZAxis);
  29.                         if (cc3d.NumberOfIntersectionPoints == 1)
  30.                         {
  31.                             pts.Add(cc3d.GetIntersectionPoint(0));
  32.                         }
  33.                     }
  34.                 }
  35.                 BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
  36.                 BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
  37.                 foreach (var pt in pts)
  38.                 {
  39.                     Circle c = new Circle(pt, Vector3d.ZAxis, 1);
  40.                     btr.AppendEntity(c);
  41.                     tr.AddNewlyCreatedDBObject(c, true);
  42.                 }
  43.                 tr.Commit();
  44.             }
  45.         }
 楼主| 发表于 2012-7-20 14:00:29 | 显示全部楼层
雪山飞狐_lzh 发表于 2012-7-20 12:17
纯数学的方法? 不过好像差点代码。。。
试下这段代码
缺代码吗 亲?纯数学运算的方法做的 通过构建二元一次方程 然后 判断相交点是否在线上...代码完全可行哈 当然你的代码要简洁点 哈哈
发表于 2019-3-26 18:39:45 | 显示全部楼层
不是AUTOLISP?看不懂,能否做成一个插件LSP
发表于 2019-5-16 18:42:41 | 显示全部楼层
学习了 感谢楼主
GMT+8, 2025-5-1 14:31 , Processed in 0.175799 second(s), 24 queries , Gzip On.
