查看: 2242|回复: 5
求助!!!怎么得到三维实体的表面积???
发表于 2012-7-14 19:39:49 | 显示全部楼层 |阅读模式
需要估算油漆,怎么在三维实体模型中得到表面积?
发表于 2012-7-14 20:46:32 | 显示全部楼层
2009以上版本可以引用acdbmgdbrep.dll
以下就没有直接的办法了
 楼主| 发表于 2012-7-14 20:51:28 | 显示全部楼层
感觉这样可以解决,但不知道怎么验证是否正确
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Public Class Class1
    <CommandMethod("xarea")> _
    Public Sub xarea()
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim toal As Double = 0
        Using trans As Transaction = db.TransactionManager.StartOpenCloseTransaction()
            Dim value(0) As TypedValue
            value(0) = New TypedValue(DxfCode.Start, "3DSOLID")
            Dim fill As SelectionFilter = New SelectionFilter(value)
            Dim optsel As New PromptSelectionOptions()
            optsel.MessageForAdding = "选择实体:"
            Dim selrec As PromptSelectionResult = ed.GetSelection(fill)
            If selrec.Status = PromptStatus.OK Then
                Dim mysel As SelectionSet = selrec.Value
                For Each xobj As SelectedObject In mysel
                    If Not IsDBNull(xobj) Then
                        Dim ent As Solid3d = trans.GetObject(xobj.ObjectId, OpenMode.ForRead)
                        If Not IsDBNull(ent) Then
                            Dim axarae As Double = ent.Area
                            toal = toal + axarae
                            ed.WriteMessage(CStr(toal))
                        End If
                    End If
                Next
            End If
        End Using
    End Sub
End Class
发表于 2012-7-14 22:20:28 | 显示全部楼层
Solid3d居然有Area属性。。。是我想复杂了
发表于 2012-7-14 22:27:27 | 显示全部楼层
        [CommandMethod("tt123")]
        public static void Test123()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var resEnt = ed.GetEntity("select a Solid3d:");
            using (var tr = new DBTransaction())
                var s = tr.GetObject<Solid3d>(resEnt.ObjectId);
                ed.WriteMessage(s.Area.ToString());
测试的结果没有问题
发表于 2012-7-15 15:58:06 | 显示全部楼层
GMT+8, 2025-5-3 06:03 , Processed in 0.144997 second(s), 25 queries , Gzip On.
