查看: 2837|回复: 3
求高手解释一下ent.DwgOut(filer);
发表于 2012-7-11 15:45:53 | 显示全部楼层 |阅读模式
//Copyright 2004 byAutodesk, Inc.
//Permission to use,copy, modify, and distribute this software in
//object code formfor any purpose and without fee is hereby granted,
//provided that theabove copyright notice appears in all copies and
//that both thatcopyright notice and the limited warranty and
//restricted rightsnotice below appear in all supporting
//documentation.
//AUTODESK PROVIDESTHIS PROGRAM "AS IS" AND WITH ALL FAULTS.
//AUTODESKSPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
//MERCHANTABILITY ORFITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
//DOES NOT WARRANTTHAT THE OPERATION OF THE PROGRAM WILL BE
//UNINTERRUPTED ORERROR FREE.
//Use, duplication,or disclosure by the U.S. Government is subject to
//restrictions setforth in FAR 52.227-19 (Commercial Computer
//Software -Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
//(Rights inTechnical Data and Computer Software), as applicable.
using System;
using System.Collections;
using System.Reflection;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
namespace filer
     public class TestFiler
         ///Defines a command which prompt a message on the AutoCAD command line
         [CommandMethod("runfiler")]
         public void filer()
              Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
              PromptEntityOptions opt = new PromptEntityOptions("Selectan object to dump");用户交互操作
              PromptEntityResult res ;  用户操作的返回
              do
                   res = ed.GetEntity(opt); 通过 opt 获取一个实体
                   opt.Message = "\nNo object selected. Select an object todump";
              while (res.Status == PromptStatus.Error); 你懂得!
              if (res.Status == PromptStatus.OK)
                   using (Transaction t = Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction())事务操作
                       Entity ent = (Entity)t.GetObject(res.ObjectId,OpenMode.ForRead); 读取当前的这个实体
                       MyFiler filer = new MyFiler();   类型为 MyFiler ,并且其值的类型为 MyFiler
                       ent.DwgOut(filer);  这里没有看懂,大侠赐教~!
                       t.Commit(); 提交事务操作
     class MyFiler :Autodesk.AutoCAD.DatabaseServices.DwgFiler
         string fileType = "";
         string dwgVersion = "";
         public MyFiler()
     ///  _____________________  Data Reading  _____________________
         public override System.IntPtr ReadAddress()
              ed.WriteMessage(MethodInfo.GetCurrentMethod().Name+ " = " + "\n");
              return new System.IntPtr ();
         public override byte[] ReadBinaryChunk()
              return null;
         public override bool ReadBoolean()
              return false;
         public override byte ReadByte()
              return 0;
         public override void ReadBytes(byte[]value)
         public override double ReadDouble()
              return 0;
         public override Handle ReadHandle()
              return new Handle ();
         public override ObjectId ReadHardOwnershipId()
              return new ObjectId ();
         public override ObjectId ReadHardPointerId()
         public override short ReadInt16()
              return 0;
         public override int ReadInt32()
              return 0;
         public override Point2d ReadPoint2d()
              return new Point2d();
         public override Point3d ReadPoint3d()
              return new Point3d();
         public override Scale3d ReadScale3d()
              return new Scale3d();
         public override ObjectId ReadSoftOwnershipId()
         public override ObjectId ReadSoftPointerId()
         public override string ReadString()
              return null;
         public override ushort ReadUInt16()
              return 0;
         public override uint ReadUInt32()
              return 0;
         public override Vector2d ReadVector2d()
              return new Vector2d();
         public override Vector3d ReadVector3d()
              return new Vector3d();
         public override void ResetFilerStatus()
         public override void Seek(int offset, int method)
         ///  _____________________  Data Writing  _____________________
         public override void WriteAddress(System.IntPtr value)
              ed.WriteMessage(value.ToString()+"\n");
         public override void WriteBinaryChunk(byte[]chunk)
              ed.WriteMessage(MethodInfo.GetCurrentMethod().Name+ " = ");
         public override void WriteBoolean(bool value)
         public override void WriteByte(byte value)
         public override void WriteBytes(byte[]value)
         public override void WriteDouble(double value)
         public override void WriteHandle(Handle handle)
         public override void WriteHardOwnershipId(ObjectId value)
         public override void WriteHardPointerId(ObjectId value)
         public override void WriteInt16(short value)
         public override void WriteInt32(int value)
         public override void WritePoint2d(Point2d value)
         public override void WriteScale3d(Scale3d value)
         public override void WriteSoftOwnershipId(ObjectId value)
         public override void WriteSoftPointerId(ObjectId value)
         public override void WriteString(string value)
         public override void WriteUInt16(ushort value)
         public override void WriteUInt32(uint value)
         public override void WriteVector2d(Vector2d value)
         public override void WriteVector3d(Vector3d value)
         public override FullDwgVersion DwgVersion
              get
                   if (dwgVersion != base.DwgVersion.ToString())
                       dwgVersion = base.DwgVersion.ToString();
                       ed.WriteMessage(MethodInfo.GetCurrentMethod().Name+ " = " + dwgVersion +"\n");
                   return base.DwgVersion;
         public override ErrorStatus FilerStatus
              get
                   //ed.WriteMessage(MethodInfo.GetCurrentMethod().Name + " = " +FilerStatus.GetType() + "\n");
                   return new ErrorStatus ();
              set
         public override FilerType FilerType
              get
                   if (fileType != FilerType.CopyFiler.ToString())
                    fileType = FilerType.CopyFiler.ToString();
                       ed.WriteMessage(MethodInfo.GetCurrentMethod().Name+ " = " + fileType +" \n");
                   return FilerType.CopyFiler;
         public override int Position
              get
                   return 0;
         public override void WritePoint3d(Point3d value)
              ed.WriteMessage(value.ToString()+ "\n");
 楼主| 发表于 2012-7-11 15:46:50 | 显示全部楼层
这个是C:\ObjectARX 2008\samples\dotNet\FilerSample 这个例子
发表于 2012-7-11 19:54:55 | 显示全部楼层
ent.DwgOut(filer);
按MyFiler的格式去解析
这应该是语法基础了、、、
 楼主| 发表于 2012-7-12 08:27:28 | 显示全部楼层
ent  获取了实体的信息,然后 .DwgOut(filer)让实体按照 MyFiler 的格式解析~!
GMT+8, 2025-5-3 05:55 , Processed in 0.179653 second(s), 23 queries , Gzip On.
