查看: 3174|回复: 3
[讨论] 请问高手:lsp能在cad视口中截图吗?
发表于 2012-6-28 19:12:28 | 显示全部楼层 |阅读模式
就是像qq截图一样在cad窗口中截图到文件(bmp jpg)或剪切板
没有找到相应的方法
发表于 2012-6-28 19:52:38 | 显示全部楼层
Try Bmpout / Jpgout
 楼主| 发表于 2012-6-28 20:07:47 | 显示全部楼层
希望用鼠标指点区域,直接到剪切板
否则还不如用外部程序截图,就是要麻烦些
 楼主| 发表于 2013-5-4 10:45:27 | 显示全部楼层
这个功能如果autodesk公司做的话应该是小菜一碟。me.support@autodesk.com 期待...
http://through-the-interface.typepad.com/through_the_interface/2007/04/taking_a_snapsh_1.html
1 using Autodesk.AutoCAD.ApplicationServices;
    2 using Autodesk.AutoCAD.DatabaseServices;
    3 using Autodesk.AutoCAD.EditorInput;
    4 using Autodesk.AutoCAD.GraphicsInterface;
    5 using Autodesk.AutoCAD.GraphicsSystem;
    6 using Autodesk.AutoCAD.Runtime;
    7 using Autodesk.AutoCAD.Interop;
    8 using System.Drawing;
    9
   10 namespace OffscreenImageCreation
   11 {
   12   public class Commands
   13   {
   14     [CommandMethod("OSS")]
   15     static public void OffscreenSnapshot()
   16     {
   17       CreateSphere();
   18       SnapshotToFile(
   19         "c:\\sphere-Wireframe2D.png",
   20         VisualStyleType.Wireframe2D
   21       );
   22       SnapshotToFile(
   23         "c:\\sphere-Hidden.png",
   24         VisualStyleType.Hidden
   25       );
   26       SnapshotToFile(
   27         "c:\\sphere-Basic.png",
   28         VisualStyleType.Basic
   29       );
   30       SnapshotToFile(
   31         "c:\\sphere-ColorChange.png",
   32         VisualStyleType.ColorChange
   33       );
   34       SnapshotToFile(
   35         "c:\\sphere-Conceptual.png",
   36         VisualStyleType.Conceptual
   37       );
   38       SnapshotToFile(
   39         "c:\\sphere-Flat.png",
   40         VisualStyleType.Flat
   41       );
   42       SnapshotToFile(
   43         "c:\\sphere-Gouraud.png",
   44         VisualStyleType.Gouraud
   45       );
   46       SnapshotToFile(
   47         "c:\\sphere-Realistic.png",
   48         VisualStyleType.Realistic
   49       );
   50     }
   51
   52     static public void CreateSphere()
   53     {
   54       Document doc =
   55         Application.DocumentManager.MdiActiveDocument;
   56       Database db = doc.Database;
   57       Editor ed = doc.Editor;
   58
   59       Transaction tr =
   60         doc.TransactionManager.StartTransaction();
   61       using (tr)
   62       {
   63         BlockTable bt =
   64           (BlockTable)tr.GetObject(
   65             db.BlockTableId,
   66             OpenMode.ForRead
   67           );
   68         BlockTableRecord btr =
   69           (BlockTableRecord)tr.GetObject(
   70             bt[BlockTableRecord.ModelSpace],
   71             OpenMode.ForWrite
   72           );
   73         Solid3d sol = new Solid3d();
   74         sol.CreateSphere(10.0);
   75
   76         const string matname =
   77           "Sitework.Paving - Surfacing.Riverstone.Mortared";
   78         DBDictionary matdict =
   79           (DBDictionary)tr.GetObject(
   80             db.MaterialDictionaryId,
   81             OpenMode.ForRead
   82           );
   83         if (matdict.Contains(matname))
   84         {
   85           sol.Material = matname;
   86         }
   87         else
   88         {
   89           ed.WriteMessage(
   90             "\nMaterial (" + matname + ") not found" +
   91             " - sphere will be rendered without it.",
   92             matname
   93           );
   94         }
   95         btr.AppendEntity(sol);
   96
   97         tr.AddNewlyCreatedDBObject(sol, true);
   98         tr.Commit();
   99       }
  100       AcadApplication acadApp =
  101         (AcadApplication)Application.AcadApplication;
  102       acadApp.ZoomExtents();
  103     }
  104
  105     static public void SnapshotToFile(
  106       string filename,
  107       VisualStyleType vst
  108     )
  109     {
  110       Document doc =
  111         Application.DocumentManager.MdiActiveDocument;
  112       Editor ed = doc.Editor;
  113       Database db = doc.Database;
  114       Manager gsm = doc.GraphicsManager;
  115
  116       // Get some AutoCAD system variables
  117       int vpn =
  118         System.Convert.ToInt32(
  119           Application.GetSystemVariable("CVPORT")
  120         );
  121
  122       using (View view = new View())
  123       {
  124         gsm.SetViewFromViewport(view, vpn);
  125
  126         // Set the visual style to the one passed in
  127         view.VisualStyle = new VisualStyle(vst);
  128
  129         Device dev =
  130           gsm.CreateAutoCADOffScreenDevice();
  131         using (dev)
  132         {
  133           dev.OnSize(gsm.DisplaySize);
  134
  135           // Set the render type and the background color
  136           dev.DeviceRenderType = RendererType.Default;
  137           dev.BackgroundColor = Color.White;
  138
  139           // Add the view to the device and update it
  140           dev.Add(view);
  141           dev.Update();
  142
  143           using (Model model = gsm.CreateAutoCADModel())
  144           {
  145             Transaction tr =
  146               db.TransactionManager.StartTransaction();
  147             using (tr)
  148             {
  149               // Add the modelspace to the view
  150               // It's a container but also a drawable
  151               BlockTable bt =
  152                 (BlockTable)tr.GetObject(
  153                   db.BlockTableId,
  154                   OpenMode.ForRead
  155                 );
  156               BlockTableRecord btr =
  157                 (BlockTableRecord)tr.GetObject(
  158                   bt[BlockTableRecord.ModelSpace],
  159                   OpenMode.ForRead
  160                 );
  161               view.Add(btr, model);
  162               tr.Commit();
  163             }
  164             // Take the snapshot
  165             Rectangle rect = view.Viewport;
  166             using (Bitmap bitmap = view.GetSnapshot(rect))
  167             {
  168               bitmap.Save(filename);
  169               ed.WriteMessage(
  170                 "\nSnapshot image saved to: " +
  171                 filename
  172               );
  173               // Clean up
  174               view.EraseAll();
  175               dev.Erase(view);
  176             }
  177           }
  178         }
  179       }
  180     }
  181   }
  182 }
在国外网站KEAN WALMSLEY用c#写的,哪位用c#帮忙编译一下
GMT+8, 2025-5-11 10:58 , Processed in 0.168771 second(s), 29 queries , Gzip On.
