查看: 1411|回复: 1
一个程序求修改。
发表于 2012-5-29 10:55:09 | 显示全部楼层 |阅读模式
我编了一个程序,但是最后一句总是不运行,但我又不想运行两次,希望一个命令连续完成。求修改。谢谢。
(defun c:ha()
(prompt "\nCHOOSE POINT FOR HATCH AREA:")
(setq point nil)
(setq pt (getpoint "\nSelect a point:"))
(while (/= pt nil)
  (setq point (cons pt point))
   (command "pline")
     (foreach x point (command x))
   (command "c" )
   (setq box(entlast))
   (command "layer" "s" "st-g-hatch" "")
   (initdia)
   (command "_bhatch")
  (command "erase" box "")
发表于 2012-5-29 11:43:19 | 显示全部楼层
(command "_bhatch" PAUSE PAUSE)
GMT+8, 2025-7-23 04:34 , Processed in 0.187600 second(s), 29 queries , Gzip On.
