查看: 1592|回复: 1
如何对自己所画的内容进行操作
发表于 2012-5-28 12:53:02 | 显示全部楼层 |阅读模式
现在有如下程序:
public void CreateCircleLine()
           // Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Database db = HostApplicationServices.WorkingDatabase;
           using (Transaction trans = db.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)(trans.GetObject(db.BlockTableId, OpenMode.ForRead));
                BlockTableRecord btr =(BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                Point3d center = new Point3d(10, 10, 0);
                Circle circle = new Circle(center, Vector3d.ZAxis, 10.0);
                circle.ColorIndex = 1;
                btr.AppendEntity(circle);
                Line line1 = new Line(Point3d.Origin, new Point3d(10, 15, 0));
                btr.AppendEntity(line1);
                Line line2 = new Line(Point3d(100,145,0), new Point3d(120, 135, 0));
                btr.AppendEntity(line2);
                trans.AddNewlyCreatedDBObject(circle,true);
                trans.AddNewlyCreatedDBObject(line1, true);
                trans.AddNewlyCreatedDBObject(line2, true);
                trans.Commit();
如何对自己创建的线及圆创建一个选择集,然后再进行移动操作啊!恳请各位高手帮帮忙啊!
发表于 2012-5-28 13:30:59 | 显示全部楼层
public virtual void TransformBy(Autodesk.AutoCAD.Geometry.Matrix3d transform)
    Autodesk.AutoCAD.DatabaseServices.Entity 的成员
GMT+8, 2025-6-1 05:50 , Processed in 0.192326 second(s), 27 queries , Gzip On.
