查看: 2083|回复: 0
关于cmdactive,LISPLINK中单步调试没有问题,但加载后运行TT2就不行了
发表于 2012-5-8 09:43:10 | 显示全部楼层 |阅读模式
  1. (defun C:tt2( / color constantwidth e1 elevation layer lst_e_p lst_pt1 obj1 pause pt_start ss)
  2. (setq lst_e_p (entsel "\n选择等高线:"))
  3. (princ "\n         lst_e_P = ") (princ lst_e_P);Erase_DV
  4. (getstring "\nPress Enter to continue...");Erase_DV
  5. (getstring "\nBreakpoint 1, press Enter to continue...");Erase_BP
  6. (setq obj1 (vlax-ename->vla-object(setq e1 (car lst_e_p))))
  7. (princ "\n            obj1 = ") (princ obj1);Erase_DV
  8. (getstring "\nPress Enter to continue...");Erase_DV
  9. (setq pt_start (osnap (cadr lst_e_p)"nea"));起点pt_start,位于obj1上
  10. (princ "\n        pt_start = ") (princ pt_start);Erase_DV
  11. (getstring "\nPress Enter to continue...");Erase_DV
  12. (setq layer (vlax-get obj1 'layer))
  13. (setq color (vlax-get obj1 'color))
  14. (setq ConstantWidth (vlax-get obj1 'ConstantWidth))
  15. (princ "\n   constantwidth = ") (princ constantwidth);Erase_DV
  16. (getstring "\nPress Enter to continue...");Erase_DV
  17. (setq Elevation (vlax-get obj1 'Elevation))
  18. (princ "\n       elevation = ") (princ elevation);Erase_DV
  19. (getstring "\nPress Enter to continue...");Erase_DV
  20. (command "pline" '(0 0))
  21. (while (= (setq cmdd(getvar "cmdactive")) 1)
  22. ;  (princ "\n            cmdd = ") (princ cmdd);Erase_DV
  23. ;  (getstring "\nPress Enter to continue...");Erase_DV
  24.
  25. ;  (princ "\n选点/U回退:")
  26.   (command pause)
  27. )
  28. )
GMT+8, 2025-7-23 08:37 , Processed in 0.171748 second(s), 29 queries , Gzip On.
