查看: 2407|回复: 1
两个坐标系转换程序
发表于 2012-5-5 16:29:47 | 显示全部楼层 |阅读模式
第一个,人家的程序照搬过来的,自定义坐标系
(defun c:ZCS (/ HIGH pt)
  (setvar "UCSICON" 1)
  (COMMAND "undo" "be")
  (prompt "\n请选择ucs对象:")
  (setq high (/ (getvar "VIEWSIZE") 1))        ;屏幕的高度的倍数
  (command "ucs" "ob" pause)
  (setq pt (cadr (grread 3)))                ;取得光标处坐标
  (command "plan" "")
  (command "zoom" "c" pt high)
  (COMMAND "undo" "e")
第二个,人家的程序,自己稍作修改
(defun c:WCS ()
  (setq pt (trans pt 1 0));用户坐标转化为世界坐标
  (command "ucs" "")
  (command "plan" "")
发表于 2012-5-6 21:06:53 | 显示全部楼层
楼主这两天产量很高啊,多谢分享!
GMT+8, 2025-7-23 10:38 , Processed in 0.187595 second(s), 30 queries , Gzip On.
