查看: 2206|回复: 1
[VBA]求助!用VBA提取CAD中实体段信息
发表于 2012-4-15 16:26:56 | 显示全部楼层 |阅读模式
我是新手,求助高手帮忙指点一下,我的代码在VBA编辑器里运行老是出现错误(红色字体部分),我感觉语法上没有什么错误,但是每次运行都出错,找不出原因,整了好久!希望哪位大侠帮忙指点一下,万分感激!!!
Sub CommandButton1_Click()
    Dim A As String
    Dim B As String
    Dim CC As ENTITIES_Type
    Dim i, il As Integer
    Open "e:\vba\1.DXF" For Input As #1
    Do While B = "ENTITIES"
    Input #1, B
    Loop
    Seek #1, Seek(1)
    Do While Not EOF(1)
      Input #1, B
     Loop
Do Input #1,B
  Loop Until B <>"0"
i = i + 1
    Select Case B
    Case "LINE"
    CC.Style = "line"
    CC.X1 = Str$(X1)
    CC.Z1 = Str$(Z1)
    CC.X2 = Str$(X2)
    CC.Z2 = Str$(Z2)
    xx1 = X2
    Case "ARC"
    CC.Style = "ARC"
    CC.X1 = Str$(X1)
    CC.Z1 = Str$(Z1)
    CC.X2 = Str$(X2)
    CC.Z2 = Str$(Z2)
    CC.X3 = Str$(X3)
    CC.Z3 = Str$(Z3)
    CC.R = Str$(R)
    CC.ANGLE1 = Str$(ANGLE1)
    CC.ANGLE2 = Str$(ANGLE2)
    If Abs(X1 - xx1) > 0.5 Then
CC.WISE = "0"
    A = CC.X1: CC.X1 = CC.X2: CC.X2 = A
    A = CC.Z1: CC.Z1 = CC.Z2: CC.Z2 = A
    A = CC.ANGLE1: CC.ANGLE1 = CC.ANGLE2: CC.ANGLE2 = A
    Else: CC.WISE = "1"
End If
xx1 = X2
  Case "CIRCLE"
    il = il + 1
    CC.Style = "CIRCLE"
    CC.X1 = Str$(X1)
    CC.Z1 = Str$(Y1)
    CC.R = Str$(R1)
    CC.X2 = CC.Z1
    xx1 = X1
    Case Else
    CC.Style = "NONE"
    End Select
    Seek #1, Seek(1)
    j = Str$(i)
    Close #1
    End Sub
 楼主| 发表于 2012-4-15 16:41:35 | 显示全部楼层
补充一点,如果把红色字体部分删除后,就可以运行了,不过如果删除了,那么我提取出来的应该就不只是实体段的信息了。困惑!
GMT+8, 2025-5-25 05:07 , Processed in 0.159414 second(s), 24 queries , Gzip On.
