楼主: langjs
[资源] entmake创建图元必要条件(慢慢更新)
发表于 2017-12-31 08:37:00 | 显示全部楼层
感谢楼主分享,学习了!
发表于 2017-12-31 09:43:23 | 显示全部楼层
谢谢楼主,借来学习了
发表于 2018-4-15 17:20:28 | 显示全部楼层
对这个组码表对了半天,layer和style的还好,不多,dimstyle的太多了,又不按照字母顺序,一个个找的,累啊
以下命令就是创建layer、style和dimstyle的,可以新建也可以对已存在的进行修改
代码还是有点长,不知道还可以优化不?
(defun c:bzh()
;;;创建或修改图层
;;;(sub_chk_layer lname lcolor llt llw lp)
(sub_chk_layer "#000" 8 "Continuous" -1 1);;;原始层,8灰
(sub_chk_layer "#001" 3 "Continuous" -1 1);;;标注文字,3绿,2.5高
(sub_chk_layer "#002" 4 "Continuous" -1 1);;;说明文字,4青,3.0高
(sub_chk_layer "#003" 7 "Continuous" -1 1);;;结构,7白
(sub_chk_layer "#004" 8 "Continuous" -1 0);;;辅助层,8灰,不打印
;;;创建文字样式
;;;(sub_chk_style sname shxname bigfontname)
(sub_chk_style "#wolf_romand" "ecidi_romand.shx" "ecidi_hzfs.shx")
(sub_chk_style "#wolf_romans" "ecidi_romans.shx" "ecidi_hzfs.shx")
;;;创建标注样式
;;;sub_chk_dimstyle(dname dscale dtxtheight ddecnumber  sname)
(sub_chk_dimstyle "#wolf_1-1_cm"   1.0   2.5 1 "#wolf_romand")
(sub_chk_dimstyle "#wolf_1-10_cm"  10.0  2.5 1 "#wolf_romand")
(sub_chk_dimstyle "#wolf_1-20_cm"  20.0  2.5 1 "#wolf_romand")
(sub_chk_dimstyle "#wolf_1-25_cm"  25.0  2.5 1 "#wolf_romand")
(sub_chk_dimstyle "#wolf_1-50_cm"  50.0  2.5 1 "#wolf_romand")
(sub_chk_dimstyle "#wolf_1-100_cm" 100.0 2.5 1 "#wolf_romand")
(sub_chk_dimstyle "#wolf_1-1"   1.0   2.5 0 "#wolf_romand")
(sub_chk_dimstyle "#wolf_1-10"  10.0  2.5 0 "#wolf_romand")
(sub_chk_dimstyle "#wolf_1-20"  20.0  2.5 0 "#wolf_romand")
(sub_chk_dimstyle "#wolf_1-25"  25.0  2.5 0 "#wolf_romand")
(sub_chk_dimstyle "#wolf_1-50"  50.0  2.5 0 "#wolf_romand")
(sub_chk_dimstyle "#wolf_1-100" 100.0 2.5 0 "#wolf_romand")
(defun sub_chk_layer(lname lcolor llt llw lp)
(if (null (tblsearch "layer" lname))
        (sub_layer_create lname lcolor llt llw lp)
        (sub_layer_modify lname lcolor llt llw lp)
(defun sub_layer_create(lname lcolor llt llw lp)
(entmake (list
                   '(0 . "LAYER")
                   '(100 . "AcDbSymbolTableRecord")
                   '(100 . "AcDbLayerTableRecord")
                   '(70 . 0)
                   (cons 2 lname);层名
                   (cons 62 lcolor);颜色
                   (cons 6 llt);线型
                   (cons 370 llw);线宽,-1=Default
                   (cons 290 lp);0不打印,1打印)
(prompt (strcat "\n图层" lname "创建完毕"))
(defun sub_layer_modify(lname lcolor llt llw lp)
(setq ename (tblobjname "layer" lname))
(setq elist (entget ename))
(setq elist (elist_subst 62 lcolor elist))
(setq elist (elist_subst 6 llt elist))
(setq elist (elist_subst 370 llw elist))
(setq elist (elist_subst 290 lp elist))
(entmod elist)
(prompt (strcat "\n图层" lname "修改完毕"))
(defun sub_chk_style(sname shxname bigfontname)
(if (null (tblsearch "style" sname))
        (sub_style_create sname shxname bigfontname)
        (sub_style_modify sname shxname bigfontname)
(defun sub_style_create(sname shxname bigfontname)
(entmake (list
        '(0 . "STYLE")
        '(100 . "AcDbTextStyleTableRecord")
        '(70 . 0)
        (cons 2 sname);文字样式名称
        (cons 40 0);固定文字高度,为0时表示高度不固定
        (cons 41 0.80);宽度系数
        (cons 50 0.0);倾斜角度
        ;(cons 71 0);文字产生标志
        ;(cons 42 0.0);最后使用的高度
        (cons 3 shxname);shx字体
        (cons 4 bigfontname);大字体
(prompt (strcat "\n文字样式" sname "创建完毕"))
(defun sub_style_modify(sname shxname bigfontname)
(setq ename (tblobjname "style" sname))
(setq elist (elist_subst 40 0 elist))
(setq elist (elist_subst 41 0.8 elist))
(setq elist (elist_subst 50 0 elist))
(setq elist (elist_subst 3 shxname elist))
(setq elist (elist_subst 4 bigfontname elist))
(entmod elist)
(prompt (strcat "\n文字样式" sname "修改完毕"))
(defun elist_subst(dxfcode dxfcodevalue elist)
(subst (cons dxfcode dxfcodevalue) (assoc dxfcode elist) elist)
(defun sub_chk_dimstyle(dname dscale dtxtheight ddecnumber sname)
(if (null (tblsearch "dimstyle" dname))
        (sub_dimstyle_create dname dscale dtxtheight ddecnumber sname)
        (sub_dimstyle_modify dname dscale dtxtheight ddecnumber sname)
(defun sub_dimstyle_create(dname dscale dtxtheight ddecnumber sname)
(entmake (list
        '(0 . "dimstyle")
        '(100 . "AcDbDimStyleTableRecord")
        '(70 . 0)
        (cons 2 dname);标注样式名
        (cons 40 dscale);dimscale,全局标注比例因子
        (cons 140 dtxtheight);dimtxt,标注文字高度
        (cons 271 ddecnumber);dimdec,主单位标注的公差值的小数位数
        (cons 340 (tblobjname "style" sname))
        (cons 41 2.0);dimasz,直线和箭头-标注箭头尺寸
        (cons 42 2.5);dimexo,尺寸界线偏移
        (cons 43 7.0);dimdli,尺寸界线增量
        (cons 44 1.5);dimexe,尺寸界线延伸
        (cons 49 1.5)
        (cons 73 0);dimtih,非零时将文字水平放在内侧
        (cons 74 0);dimtoh,非零时将文字水平放在外侧
        (cons 77 1);dimtad,非零时文字在尺寸线上方
        (cons 78 8);dimzin,控制是否对主单位值做消零处理:0(1)=消除(包含)零英尺和零英寸
        (cons 141 0.0);dimcen,中心标记/中心线的大小
        (cons 147 0.68);dimgap,尺寸线间距
        (cons 171 4);dimaltd,换算单位小数位
        (cons 172 1);dimtofl,如果文字放在尺寸界线外侧,非零时则强制在尺寸界线之间画直线
        (cons 174 1);dimtix,非零时将文字强制放在尺寸界线的内侧
        (cons 176 256);dimclrd,尺寸线颜色,0=byblock,256=bylayer
        (cons 177 256);dimclre,尺寸界线颜色,0=byblock,256=bylayer
        (cons 178 256);dimclrt,标注文字颜色,0=byblock,256=bylayer
        (cons 272 1);dimtdec,显示公差值的小数位数
        (cons 274 4);dimalttd,换算单位标注的公差值的小数位数
        (cons 279 1);dimtmove,标注文字移动规则:0-尺寸线和标注文字一起移动,1=移动标注文字时添加引线,2=允许标注文字自由移动而不添加引线
        (cons 290 1)
(prompt (strcat "\n标注样式" dname "创建完毕"))
(defun sub_dimstyle_modify(dname dscale dtxtheight ddecnumber sname)
(setq ename (tblobjname "dimstyle" dname))
(setq elist (elist_subst 40 dscale elist))
(setq elist (elist_subst 140 dtxtheight elist))
(setq elist (elist_subst 271 ddecnumber elist))
(setq elist (elist_subst 340 (tblobjname "style" sname) elist))
(setq elist (elist_subst 41 2.0 elist))
(setq elist (elist_subst 42 2.5 elist))
(setq elist (elist_subst 43 7.0 elist))
(setq elist (elist_subst 44 1.5 elist))
(setq elist (elist_subst 49 1.5 elist))
(setq elist (elist_subst 73 0 elist))
(setq elist (elist_subst 74 0 elist))
(setq elist (elist_subst 77 1 elist))
(setq elist (elist_subst 78 8 elist))
(setq elist (elist_subst 141 0.0 elist))
(setq elist (elist_subst 147 0.68 elist))
(setq elist (elist_subst 171 4 elist))
(setq elist (elist_subst 172 1 elist))
(setq elist (elist_subst 174 1 elist))
(setq elist (elist_subst 176 256 elist))
(setq elist (elist_subst 177 256 elist))
(setq elist (elist_subst 178 256 elist))
(setq elist (elist_subst 272 1 elist))
(setq elist (elist_subst 274 4 elist))
(setq elist (elist_subst 279 1 elist))
(setq elist (elist_subst 290 1 elist))
(entmod elist)
(prompt (strcat "\n标注样式" dname "修改完毕"))
发表于 2018-4-16 23:13:25 | 显示全部楼层
最近迷上了vlisp,本身就不是学编程的,搞了几个小程序很有成就感,可是再往深了玩,真的挺不容易,老是陷入误区,这周搞得四点钟睡觉,很疲惫。真的感谢明经,各位大佬带带我啊,不一定要给干货,给我引引路少走点弯路啊。==============另外想问问各位大佬,有没有vlisp交流群啊,带我一个,要是没有我建了一个QQ交流群:764135083    望各位大佬进来援助
发表于 2018-5-6 09:08:50 | 显示全部楼层
gzxl 发表于 2013-1-9 23:26
支持几下
还好有这个,不用记那么多
这个是什么啊?可以自动提取的程序吗?
发表于 2018-5-6 09:17:52 | 显示全部楼层
ThinkerHua 发表于 2016-1-1 16:32
不理解为什么创建某些图形需要类似
'(100 . "AcDbEntity")
'(100 . "AcDbMText")
你好,你问的这个问题解决了吗?能够指导下?谢谢!
发表于 2018-5-9 17:04:49 | 显示全部楼层
已收藏,,这些对我来说太有用了,学到很多东西
发表于 2018-5-10 14:08:09 | 显示全部楼层
写的很好 学习了
发表于 2018-6-2 02:44:28 | 显示全部楼层
学习了,谢谢
GMT+8, 2025-12-12 17:39 , Processed in 0.198667 second(s), 20 queries , Gzip On.
