查看: 354102|回复: 994
[资源] entmake创建图元必要条件(慢慢更新)
发表于 2012-3-16 10:33:35 | 显示全部楼层 |阅读模式
entmake创建图元较command速度快,且不受捕捉等CAD环境因素影响,因此优先选用entmake。
entmake创建图元必要条件,即创建图元的最少组码项,再少就无法正确创建图元,实际使用中需要颜色、图层等组码项自己添加。水平有限,欢迎拍砖。
1、直线
(entmake (list '(0 . "LINE") (cons 10 pt1) (cons 11 pt2)))
2、两顶点多段线(多顶点类似)
(entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 2) (cons 10 pt1) (cons 10 pt2)))
3、点表生成多段线
   (entmake (append    (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length lst)))
      (mapcar '(lambda (pt)(cons 10 pt)) lst ))
4、圆
(entmake (list '(0 . "CIRCLE") (cons 10 pt) (cons 40 r)))
5、圆弧
(entmake (list '(0 . "ARC") (cons 10 pt) (cons 40 r) (cons 50 ang1) (cons 51 ang2)))
6、单行文本
(entmake (list '(0 . "TEXT") (cons 1 str) (cons 10 pt) (cons 40 5)))
7、多行文本
  (entmake (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") '(7 . "Standard") (cons 1 str) (cons 10 pt)))
8、半径标注
  (entmake (list '(0 . "DIMENSION") '(100 . "AcDbEntity") '(100 . "AcDbDimension")(cons 10 pt) '(70 . 36) '(100 . "AcDbRadialDimension")        (cons 15 pt1) ) )
9、直径标注
  (entmake (list '(0 . "DIMENSION") '(100 . "AcDbEntity") '(100 . "AcDbDimension") (cons 10 pt1) (cons 11 pt2) '(70 . 163) '
   (100 . "AcDbDiametricDimension") (cons 15 pt3)
10、水平标注
  (entmake (list '(0 . "DIMENSION") '(100 . "AcDbEntity") '(100 . "AcDbDimension") (cons 10 pt) '(70 . 32) '(1 . "") '(100 . "AcDbAlignedDimension")
   (cons 13 pt1) (cons 14 pt2) '(100 . "AcDbRotatedDimension")
11、垂直标注
   (cons 13 pt1) (cons 14 pt2) '(50 . 1.5708) '(100 . "AcDbRotatedDimension")
12、倾斜标注
(entmake (list '(0 . "DIMENSION") '(100 . "AcDbEntity") '(100 . "AcDbDimension") (cons 10 pt1) '(70 . 33) '(1 . "") '(100 . "AcDbAlignedDimension")
   (cons 13 pt2) (cons 14 pt3)
13、entmake生成普通块
(defun emkblk (ss pt name / i)
  (entmake (list '(0 . "block") (cons 2 name) '(70 . 0) (cons 10 pt)))
  (repeat (setq i (sslength ss))    (entmake (cdr (entget (ssname ss (setq i (1- i))))))  )
  (entmake '((0 . "ENDBLK")))
  (command "_.erase" ss "")
  (entmake (list '(0 . "INSERT") (cons 2 name) (cons 10 pt)))
14、entmake插入普通块
15 、entmake生成无名块
(defun emkunameblk (ss pt / i name)
  (entmake (list '(0 . "block") '(2 . "*U") '(70 . 1) (cons 10 pt)))
  (setq name (entmake '((0 . "ENDBLK"))))
  name
16、将选择集做成属性块(选择集中单行文本作为属性)
(defun emkattblk (ss pt name / ent i)
  (entmake (list '(0 . "block") (cons 2 name) '(70 . 2) (cons 10 pt)))
    (setq ent (entget (ssname ss (setq i (1- i)))))
    (if (= (cdr (assoc 0 ent)) "TEXT")
      (entmake (list '(0 . "ATTDEF") (assoc 10 ent) (assoc 40 ent) (assoc 1 ent) (cons 3 (cdr (assoc 1 ent)))
      (cons 2 (cdr (assoc 1 ent))) '(70 . 0)))
      (entmake (cdr ent))
17、生成图层
  (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") '(70 . 0) '(6 . "Continuous")
   (cons 2 name)
18、创建新线型
  (entmake (list '(0 . "LTYPE") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLinetypeTableRecord") (cons 2 "BERDIG 5-545") '  (3 . "Border ____   ____   ____   ____   ____") '(70 . 0) '(73 . 2) '(40 . 15.0) '(49 . 10.0) '(74 . 0) '
   (49 . -5.0) '(74 . 0)    )  )
19、引线
  (entmake (list '(0 . "LEADER") '(100 . "AcDbEntity") '(100 . "AcDbLeader")  (cons 10 pt) (cons 10 pt1)
   (cons 10 pt2)
20、构造线
(entmake (list '(0 . "XLINE") '(100 . "AcDbEntity") '(100 . "AcDbXline") (cons 10 pt) (cons 11 pt1)))
21、椭圆
  (entmake '((0 . "ELLIPSE") (100 . "AcDbEntity")(100 . "AcDbEllipse")(10 3969.6 4289.14 0.0)(11 -1828.47 0.0 0.0)
     (40 . 0.416093)
     (42 . 6.28319)
22、 点
(entmake (list '(0 . "POINT") (cons 10 pt)))
23、entmake文字样式
  (entmake (list '(0 . "STYLE") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbTextStyleTableRecord") (cons 2 name) '(70 . 0)
   (cons 40 h) (cons 41 w) '(3 . "romans.shx") '(4 . "Hztxts.shx")
24、 建立第一级标注样式(来源于论坛)
  (entmake (list '(0 . "DIMSTYLE")
                 '(100 . "AcDbDimStyleTableRecord")
                 '(70 . 0)
                 (cons 340 (tblobjname "style" "Standard")) ; 文字样式名
                 (cons 2 "普通螺纹")   ; 标注样式名
                 '(3 . "M<>")        ; 标注前缀
                 '(40 . 0.0)        ; 标注特征比例,缩放到布局
                '(41 . 2.5)        ; 箭头尺寸
                '(42 . 1.5)        ; 起点偏移量
                '(43 . 5.5)        ; 基线间距
                '(44 . 1.5)        ; 超出尺寸线
                '(47 . 0.000)        ; 上偏差
                '(48 . 0.000)        ; 下偏差
                '(71 . 0)        ; 公差无
                '(77 . 1)        ; 文字在尺寸线上方
                '(74 . 1)        ;
                '(140 . 3.0)        ; 文字高度
                '(141 . -2.5)        ; 圆心标记
                '(144 . 1.0)        ; 测量比例单位
                '(146 . 0.7)        ; 公差高度比例
                '(147 . 1.0)        ; 文字从尺寸线偏移
                '(172 . 2)        ; 尺寸界线间连线
                '(176 . 256)        ; 随层
                '(177 . 256)        ; 随层
                '(178 . 256)        ; 随层
                '(271 . 3)        ; 尺寸标注精度
                '(272 . 3)        ; 公差标注精度
                '(275 . 0)        ; 角度标注制式,十进制。
                '(288 . 1)        ; 手动放置尺寸
25、点表生成样条曲线(感谢院长提供)
  (entmake (append
      (list '(0 . "SPLINE") '(100 . "AcDbEntity") '(100 . "AcDbSpline") '(71 . 3))
      (mapcar '(lambda (pt) (cons 11 pt))  ptlst)
26、生成SOLID (pt1234四点围成图形,如三点则最后两点相同)
(entmake (list '(0 . "SOLID") (cons 10 pt1)  (cons 11 pt2) (cons 12 pt4) (cons 13 pt3)))
27、 Entmake构造线(射线)
        by:自贡黄明儒 http://bbs.mjtd.com/thread-109700-1-1.html
28、[功能]生成带凸度多段线
;;[用法](LC:make-arcpline (getpoint "\n 请输入圆弧第一点:") (getpoint "\n 请输入圆弧第二点:") (getreal "\n 请输入圆弧凸度:"))
;;[作者]BY 老仓测绘上班记
;;;(setq pt1 (getpoint "\n 请输入圆弧第一点:")
;;;      pt2 (getpoint "\n 请输入圆弧第二点:")
;;;      arcBulge -0.426309)
(defun LC:make-arcpline (pt1 pt2 arcBulge / pt1 pt2 arcBulge arclst)
  (setq arclst (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(90 . 2) (cons 10 pt1)
                   (cons 42 arcBulge) (cons 10 pt2)))
  (entmake arclst)
暂时先这么多,以后再补充。
另提供CAD图元群码表供查询
增加个样条曲线的吧  发表于 2012-10-29 10:18
请问MTEXT如何换行呢,使用entmake  发表于 2012-5-22 09:56
无名块和属性块也要区别对待  发表于 2012-3-20 21:38
块插入也可以用entmake  发表于 2012-3-17 12:48
好东西,鼓励  发表于 2012-3-16 14:01
参与人数 22明经币 +23 收起 理由
hubeiwdlue + 1 很给力!
cghdy + 1 神马都是浮云
tigcat + 1 很给力!
bzhjl + 1
434939575 + 1 必须支持!!!!!
vectra + 1
wwwbxd + 1 赞一个!
zctao1966 + 1 很给力!
wowan1314 + 1 支持继续!
linshiyin2 + 1 增加字段吧
本帖被以下淘专辑推荐:
发表于 2012-3-22 20:14:06 | 显示全部楼层
Theswamp.org 有个函数
  1. (defun MinDxfDef ( ename / result temp )
  2.     ;;  will create crap if the current or parent
  3.     ;;  layer of the candidate entity is locked
  4.     (foreach pair (setq result (entget ename))
  5.         (if (entmakeX (setq temp (vl-remove pair result)))
  6.             (progn (entdel (entlast))(setq result temp))
  7.             result
  8.         )
  9.     )
  10. )
此函数功能:将所选的对像自动生成entmake所需的必要条件,超先酷  发表于 2016-2-2 14:25
有时很有用!  发表于 2012-5-26 21:33
此程序胜过nn张表格,明总应给予奖励!  发表于 2012-5-23 12:00
好方法,谢谢奉献!  发表于 2012-5-23 11:54
回复 支持 3 反对 1
发表于 2012-3-16 13:34:39 | 显示全部楼层
谢谢楼主分享对于mtext,控制文字的对齐格式可以使用以下组码:
(71 . 1) 左对齐-上对齐  这个是默认的对齐方式
(71 . 4) 左对齐-中央对齐
(71 . 7) 左对齐-下对齐
(71 . 2) 居中对齐-上对齐
(71 . 5) 居中对齐-中央对齐
(71 . 8) 居中对齐-下对齐
(71 . 3) 右对齐-上对齐
(71 . 6) 右对齐-中央对齐
(71 . 9) 右对齐-下对齐
如果使用替换文字编辑器,则通过输入格式代码应用格式。 可为文字加下划线、删除线和创建堆叠文字。 用户可以修改颜色、字体和文字高度, 还可以修改文字字符间距或增加字符本身宽度。 要应用格式,请使用下表中列出的格式代码:
[td]
段落格式代码
格式代码作用输入...要生成 ...
\0...\o
打开和关闭 下划线
Autodesk \OAutoCAD\o
\L...\l
打开和关闭 下划线
Autodesk \LAutoCAD\l
插入不间断 空格
Autodesk AutoCAD\~LT
插入反斜杠
Autodesk \\AutoCAD
插入左大括号和右大括号
Autodesk \{AutoCAD\}
\Cvalue;
修改为 指定的颜色
Autodesk \C2;AutoCAD
\ File name;
修改为 指定的字体文件
Autodesk \Ftimes; AutoCAD
\Hvalue;
修改为 以图形单位表示的 指定文字高度
Autodesk \H2;AutoCAD
\Hvaluex;
将文字高度修改为 当前样式文字高度的 数倍
Autodesk \H3x;AutoCAD
\S...^...;
堆叠 \、# 或 ^ 符号后的文字
1.000\S+0.010^-0.000;
\Tvalue;
调整字符间距,从 .75 到 4 倍
\T2;Autodesk
\Qangle;
修改倾斜角度
\Q20;Autodesk
\Wvalue;
修改宽度比例生成宽字
\W2;Autodesk
\A
设置对齐方式值,有效值为:0、1、2 (底端对正、居中对正、顶端对正)
\A1;1\S1/2
\P
结束段落
Autodesk\PAutoCAD
大括号最多可以嵌套八层。
也可以使用控制代码添加特殊的字符,例如公差和标注符号。 请参见 MTEXT
样例:在替换文字编辑器中设置文字格式
本例说明了下图中的文字是如何创建的。
通过输入控制代码或 Unicode 字符串可以输入以下特殊字符或符号。 或在在位文字编辑器中,在展开的工具栏上单击“符号”。
注意 不支持在垂直文字中使用符号
[td]
Unicode 字符串和控制代码
控制代码Unicode 字符串结果
%%d
\U+00B0
度符号 (°)
%%p
\U+00B1
公差符号 (±)
%%c
\U+2205
直径符号 (&#8709;)
要插入以下文字符号,请在展开的“文字格式”工具栏上单击“符号”,或输入适当的 Unicode 字符串:
[td]
文字符号和 Unicode 字符串
名称符号Unicode 字符串
几乎相等
\U+2248
角度
\U+2220
边界线
\U+E100
中心线
\U+2104
增量
\U+0394
电相位
\U+0278
流线
\U+E101
标识
\U+2261
初始长度
\U+E200
界碑线
\U+E102
不相等
\U+2260
欧姆
\U+2126
欧米加
\U+03A9
地界线
\U+214A
下标 2
\U+2082
平方
\U+00B2
立方
\U+00B3
以上文字符号适用于下列 TrueType (TTF) 字体和 SHX 字体:
    Simplex RomanS Isocp Isocp2 Isocp3 Isoct Isoct2 Isoct3 Isocpeur(仅 TTF 字体) Isocpeur italic(仅 TTF 字体) Isocteur(仅 TTF 字体)
  • Isocteur italic(仅 TTF 字体)
回复 支持 4 反对 0
发表于 2012-3-17 19:54:37 | 显示全部楼层
谢谢楼主 收藏了 希望能继续补充
发表于 2012-3-16 11:32:08 | 显示全部楼层
好东西,鼓励
发表于 2012-3-16 19:00:59 | 显示全部楼层
多谢楼主分享。
发表于 2012-3-16 20:47:30 | 显示全部楼层
研究的挺透,赞一个!
发表于 2012-3-16 22:44:30 | 显示全部楼层
总结的不错...
发表于 2012-3-16 23:26:11 | 显示全部楼层
很好,
发表于 2012-3-17 09:11:12 | 显示全部楼层
写的很好 学习了
发表于 2012-3-17 11:59:47 | 显示全部楼层
感谢楼主分享,学习了!
发表于 2012-3-17 12:47:30 | 显示全部楼层
可以做成函数
无名块和属性块我还没有研究,还有非图形词典都太高深了我也不会,风版写一些啊这些东西的entmake补充进来啊  发表于 2012-3-20 21:47
GMT+8, 2025-12-12 06:52 , Processed in 0.239490 second(s), 32 queries , Gzip On.
