楼主: lidaxiu
能不能实现图元批量对齐,请大师们指教了
发表于 2012-5-23 20:49:09 | 显示全部楼层
已经用上了,好顺手呀,谢G版了。
发表于 2012-5-24 11:32:53 | 显示全部楼层
;; 对齐
;; 兴趣来了,GX基础上改了下,未测试,不行再改。
(defun c:pldq ()
;;子程序
;;选择集转表
  (defun gxl-Sel-SS->List (ss / i s )
    (if ss
      (repeat  (setq i (sslength ss))
         (setq s (cons (ssname ss (setq i (1- i))) s))    )    ))
           ;;计算物体中心点
            (defun gxl-getboxCenter (e1 / obj minpoint maxpoint)
              (if (= 'ENAME (type e1))
                  (setq obj (vlax-ename->vla-object e1))
                  ;转换图元名
                  (setq obj e1)
          (vla-GetBoundingBox obj 'minpoint 'maxpoint)
          ;取得包容图元的最大点和最小点
          (setq minpoint (vlax-safearray->list minpoint))
          ;把变体数据转化为表
          (setq maxpoint (vlax-safearray->list maxpoint))
          ;把变体数据转化为表
          (setq p (mapcar '+ minpoint maxpoint))
          (mapcar '(lambda (x) (* 0.5 x)) p))
;;主程序
      (setq cmdecho (getvar 'cmdecho))
      (setq osmode (getvar 'osmode))
      (setvar 'osmode 0)
      (setvar 'cmdecho 0)
      (princ "\n选择基准物体:")
      (setq s1 (ssget))
      (princ "\n选择要对齐物体:")
      (setq s2 (ssget))
      (setq s1 (GXL-SEL-SS->LIST s1)
            s2 (GXL-SEL-SS->LIST s2)
      ;_ 按Y从大到小排序
      (setq s1 (mapcar '(lambda (x) (list x (GXL-GETBOXCENTER x))) s1))
      (setq s1 (vl-sort s1 '(lambda (a b) (> (cadadr a) (cadadr b))) ))
      (setq s2 (mapcar '(lambda (x) (list x (GXL-GETBOXCENTER x))) s2))
      (setq s2 (vl-sort s2 '(lambda (a b) (> (cadadr a) (cadadr b))) ))
      ;_ 表长比较
      (if  (> (length s1) (length s2) )
         (setq
  TMP s2    s2 s1   s1 TMP   )
      (initget "H S")
      (setq key (getkword "[横向对齐(H)/竖向对齐(S)]:  " ) )
      (cond
          (= key "H")  (hen)
          (= key "S")  (shu)
     (defun hen()
      (setq n 0)
      (repeat (length s1)
         (setq e1 (car (nth n s1))
               p1 (cadr (nth n s1))
         (if (setq e2 (car (nth n s2)))
           (setq p2 (cadr (nth n s2)))
           (setq p3 (list (car p2) (cadr p1) (caddr p2)))
           (command "move" e2 "" p2 p3)
         (setq n (1+ n))
     (defun shu()
      (setq n 0)
      (repeat (length s1)
           (setq p3 (list (cadr p2) (car p1) (caddr p2)))
         (setq n (1+ n))
      (setvar 'osmode osmode)
      (setvar 'cmdecho cmdecho)
 楼主| 发表于 2012-5-24 21:17:00 | 显示全部楼层
恩不错,可是没运行成功呢,提示  no function definition: HEN
发表于 2012-5-25 10:03:21 | 显示全部楼层
crazylsp
运行你修改的那后,无反应。那对齐没效果。cad2010 64
发表于 2012-5-25 10:41:07 | 显示全部楼层
看看情况,拿分走人
发表于 2012-5-26 22:45:29 | 显示全部楼层
学习G版的招数
发表于 2012-6-10 00:31:22 | 显示全部楼层
G版太强大了
发表于 2012-6-19 14:34:42 | 显示全部楼层
看起来这个程序非常不错
发表于 2012-6-19 15:14:55 | 显示全部楼层
批量对齐不错不错
发表于 2012-6-19 15:21:05 | 显示全部楼层
谢谢分享程序。
GMT+8, 2026-1-27 11:04 , Processed in 0.146568 second(s), 19 queries , Gzip On.
