查看: 2079|回复: 3
如何复制一个打开的图形文件,我的出错了
发表于 2012-2-29 10:35:11 | 显示全部楼层 |阅读模式
  1. <CommandMethod("CreateTkMap")> Public Sub CreateTkMap()
  2.         Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection()
  3.         Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
  4.         Dim acCurDb As Database = acDoc.Database
  5.         Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
  6.         Dim acSSPrompt As PromptSelectionResult
  7.         acSSPrompt = acDocEd.SelectAll()
  8.         If acSSPrompt.Status = PromptStatus.OK Then
  9.             Dim acSSet As SelectionSet = acSSPrompt.Value
  10.             For Each acSSObj As SelectedObject In acSSet
  11.                 acObjIdColl.Add(acSSObj.ObjectId)
  12.             Next
  13.         Else
  14.             Application.ShowAlertDialog("活动文档无内容或复杂过程出现错误!")
  15.             Exit Sub ' 退出
  16.         End If
  17.         Dim sLocalRoot As String = Application.GetSystemVariable("LOCALROOTPREFIX")
  18.         Dim sTemplatePath As String = sLocalRoot + "Template\acad.dwt"
  19.         Dim acDocMgr As DocumentCollection = Application.DocumentManager
  20.         Dim acNewDoc As Document = acDocMgr.Add(sTemplatePath)
  21.         Dim acDbNewDoc As Database = acNewDoc.Database
  22.         Using acLckDoc As DocumentLock = acNewDoc.LockDocument()
  23.             Using acTrans = acDbNewDoc.TransactionManager.StartTransaction()
  24.                 Dim acBlkTblNewDoc As BlockTable
  25.                 acBlkTblNewDoc = acTrans.GetObject(acDbNewDoc.BlockTableId, OpenMode.ForWrite)
  26.                 Dim acBlkTblRecNewDoc As BlockTableRecord
  27.                 acBlkTblRecNewDoc = acTrans.GetObject(acBlkTblNewDoc(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
  28.                 Dim acIdMap As IdMapping = New IdMapping()
  29.                 '  acIdMap.DestinationDatabase = acCurDb
  30.                 acDocMgr.MdiActiveDocument = acNewDoc
  31.                 acCurDb.WblockCloneObjects(acObjIdColl, acBlkTblRecNewDoc.ObjectId, acIdMap, DuplicateRecordCloning.Replace, False)
  32.                 acTrans.Commit()
  33.             End Using
  34.         End Using
  35.         'acDocMgr.MdiActiveDocument = acNewDoc
  36.         '  对新图形文件继续操作出问题 如双击图形
  37.     End Sub
 楼主| 发表于 2012-2-29 10:38:00 | 显示全部楼层
我是想把一个打开的图形文件复制一份,然后在复制的文件上进行进一步的操作。
如果执行下面的命令是没有问题的,保存的图形也是没有问题的
acNewDoc.CloseAndSave("c:\fft.dwg")  ' 关闭 保存
但是我要执行别的操作,如缩放,程序崩溃了。
大家能不能帮我找找问题所在
发表于 2012-2-29 10:50:52 | 显示全部楼层
换一个版本呢
 楼主| 发表于 2012-2-29 10:56:48 | 显示全部楼层
秋天的飓风 发表于 2012-2-29 10:50
换一个版本呢
画一些简单的线条 再执行这个命令 程序没有什么问题
再用一下工程图执行这个命令 就出现问题了
我想是不是拷贝过程,没有收尾的操作
应该不是版本问题
GMT+8, 2025-5-31 04:50 , Processed in 0.162439 second(s), 24 queries , Gzip On.
