查看: 3869|回复: 1
学习飞狐大哥模拟Line方法,添加“反接”和“圆弧”两个功能
发表于 2012-2-28 17:09:58 | 显示全部楼层 |阅读模式
using System;
using System.Collections.Generic;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
namespace EventHandler
    public class CLineJig : DrawJig
        CBasicMethod myMethod = new CBasicMethod();
        List<Point3d> m_Points = new List<Point3d>();
        List<ObjectId> m_Lines = new List<ObjectId>();
        List<Point3d> m_ArcPts = new List<Point3d>();
        Point3d m_EndPoint;
        int tt = 0;
        Point3d[] pt_Reverse = new Point3d[10];    // 控制点的反接,限10次以内
        LineJigStatus m_Status = LineJigStatus.Add;
        private bool m_ArcStart = false;
        private string lineJudge = null;
        public enum LineJigStatus
            Add,
            Undo,
            Close,
            Finish,
            Reverse
        public LineJigStatus JigStatus
            get { return m_Status; }
            set { m_Status = value; }
        public Point3d StartPoint
            get { return m_Points[1]; }
        public Point3d EndPoint
            get { return m_Points[0]; }
        protected override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.WorldDraw draw)
            return true;
        protected override SamplerStatus Sampler(JigPrompts prompts)
            JigPromptPointOptions jigOpts = new JigPromptPointOptions();
            jigOpts.UserInputControls =
                UserInputControls.Accept3dCoordinates |
                UserInputControls.NoZeroResponseAccepted |
                UserInputControls.NoNegativeResponseAccepted |
                UserInputControls.NullResponseAccepted;
            switch (m_Points.Count)
                case 0:
                    jigOpts.UseBasePoint = false;
                    jigOpts.SetMessageAndKeywords("\n指定第一点或[标准化(S)]:", "Standard");
                    break;
                case 1:
                    jigOpts.Cursor = CursorType.RubberBand;
                    jigOpts.SetMessageAndKeywords("\n指定下一点或 [放弃(U)]:", "Undo");
                    jigOpts.UseBasePoint = true;
                    jigOpts.BasePoint = m_Points[0];
                    break;
                default:
                    jigOpts.SetMessageAndKeywords("\n指定下一点或 [回退(U)/反接(R)/闭合(C)/弧(A)]:", "Undo Reverse Close Arc");
                    break;
            PromptPointResult res = prompts.AcquirePoint(jigOpts);
            switch (res.Status)
                case PromptStatus.Cancel:
                case PromptStatus.None:
                    m_Status = LineJigStatus.Finish;
                    return SamplerStatus.Cancel;
                case PromptStatus.Keyword:
                    switch (res.StringResult)
                        case "Undo":
                            m_Status = LineJigStatus.Undo;
                            break;
                        case "Close":
                            m_EndPoint = m_Points[m_Points.Count - 1];
                            m_Status = LineJigStatus.Close;
                            break;
                        case "Reverse":
                            if (tt == 0)
                                pt_Reverse[tt] = m_Points[0];
                                m_Points[0] = m_Points[m_Points.Count - 1];
                                tt++;
                            else
                                m_Points[0] = pt_Reverse[tt - 1];
                                m_EndPoint = pt_Reverse[tt - 1];
                                tt++;
                            break;
                        case "Arc":
                            m_ArcPts.Insert(0, m_Points[0]);
                            m_ArcStart = true;
                            break;
                        case "Standard":
                            break;
                    return SamplerStatus.OK;
                default:
                    Point3d positionTemp = res.Value;
                    if (positionTemp != m_EndPoint)
                        m_EndPoint = positionTemp;
                    else
                        return SamplerStatus.NoChange;
                    break;
        public int AddPoint()
            m_Points.Insert(0, m_EndPoint);
            return m_Points.Count;
        public void AddLine(Line line)
            m_Lines.Insert(0, line.ObjectId);
        public ObjectId CurrLine
            get { return m_Lines.Count == 0 ? ObjectId.Null : m_Lines[0]; }
        public int RemovePoint()
            m_Points.RemoveAt(0);
        public void RemveLine()
            m_Lines.RemoveAt(0);
        [CommandMethod("DrawLineMethod")]
        public void DrawLineMethod()
            Database db = CopyDatabase.destDb;
            CLineJig ljig = new CLineJig();
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            ObjectId linetypeID = ObjectId.Null;
            Line line = null;
            // 开始交互绘制
            while (ljig.JigStatus != LineJigStatus.Finish)
                // 圆弧绘制的启动开关
                if (ljig.m_ArcStart == false)
                    PromptResult res = ed.Drag(ljig);
                else
                    PromptPointOptions opt = new PromptPointOptions("\n指定一个弧上的点: ");
                    PromptPointResult prt;
                    prt = ed.GetPoint(opt);
                    if (prt.Status == PromptStatus.OK)
                        ljig.m_ArcPts.Insert(0, prt.Value);
                        PromptPointOptions opt1 = new PromptPointOptions("\n指定弧段的终点:");
                        PromptPointResult prt1;
                        prt1 = ed.GetPoint(opt1);
                        if (prt1.Status == PromptStatus.OK)
                            ljig.m_ArcPts.Insert(0, prt1.Value);
                            ljig.m_EndPoint = prt1.Value;
                            ljig.AddPoint();
                switch (ljig.JigStatus)
                    case LineJigStatus.Add:
                    case LineJigStatus.Close:
                        if (ljig.AddPoint() != 1 && ljig.m_ArcStart == false)
                            using (Transaction tr = db.TransactionManager.StartTransaction())
                                // 注意,当要修改一个不是当前文档的数据库时,或者要阻止别的执行文本来修改该数据库时,就需要锁定文档。
                                DocumentLock documentLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument();
                                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                                line = new Line(ljig.StartPoint, ljig.EndPoint);
                                line.SetDatabaseDefaults();
                                btr.AppendEntity(line);
                                tr.AddNewlyCreatedDBObject(line, true);
                                ljig.AddLine(line);
                                tr.Commit();
                                documentLock.Dispose();
                        else
                            if (ljig.m_ArcPts.Count == 3)
                                    DocumentLock documentLock = Application.DocumentManager.MdiActiveDocument.LockDocument();
                                    Arc myArc = myMethod.AddArcFromPt(ljig.m_ArcPts[0], ljig.m_ArcPts[1], ljig.m_ArcPts[2]);
                                    btr.AppendEntity(myArc);
                                    tr.AddNewlyCreatedDBObject(myArc, true);
                                    tr.Commit();
                                    ljig.m_ArcStart = false;
                                    ljig.m_ArcPts.Clear();
                        break;
                    case LineJigStatus.Undo:
                        ljig.RemovePoint();
                        if (ljig.CurrLine != ObjectId.Null)
                                line = (Line)ljig.CurrLine.GetObject(OpenMode.ForWrite);
                                line.Erase(true);
                                ljig.RemveLine();
                                tr.Commit();
                        break;
                    default:
                        break;
                if (ljig.JigStatus == LineJigStatus.Close)
                    ljig.JigStatus = LineJigStatus.Finish;
说明:其中绘制圆弧方法见上一贴“根据三点画圆弧”。
该贴已经同步到 菜鸟Liu的微博
发表于 2012-2-28 18:21:50 | 显示全部楼层
开来懂LISP就是好啊
GMT+8, 2025-5-31 04:50 , Processed in 0.158026 second(s), 23 queries , Gzip On.
