查看: 3692|回复: 0
三点创建圆弧(由于开发需要,将VB版本改成c#版本)
发表于 2012-2-28 16:49:44 | 显示全部楼层 |阅读模式
   #region 根据三点创建圆弧
        private Point3d GetArcCenter(Point3d pt1,Point3d pt2,Point3d pt3,ref double radius)
            double xysm, xyse, xy;
            double[] m_ArcCenter = new double[3];
            xy = Math.Pow(pt1.X, 2) + Math.Pow(pt1.Y, 2);
            xyse = xy - Math.Pow(pt3.X, 2) - Math.Pow(pt3.Y, 2);
            xysm = xy - Math.Pow(pt2.X, 2) - Math.Pow(pt2.Y, 2);
            xy = (pt1.X - pt2.X) * (pt1.Y - pt3.Y) - (pt1.X - pt3.X) * (pt1.Y - pt2.Y);
            // 判断参数有效性
            if (Math.Abs(xy)<0.000001)
                MessageBox.Show("所输入的参数无法创建圆形!");
                return Point3d.Origin;
            // 获得圆心和半径
            m_ArcCenter[0] = ((xysm * (pt1.Y - pt3.Y)) - (xyse * (pt1.Y - pt2.Y))) / (2 * xy);
            m_ArcCenter[1] = ((xyse * (pt1.X - pt2.X)) - (xysm * (pt1.X - pt3.X))) / (2 * xy);
            m_ArcCenter[2] = 0;
            radius = Math.Sqrt((pt1.X - m_ArcCenter[0]) * (pt1.X - m_ArcCenter[0]) + (pt1.Y - m_ArcCenter[1]) * (pt1.Y - m_ArcCenter[1]));
            if (radius<0.000001)
                MessageBox.Show("半径过小");
            // 函数返回圆心的位置,而半径在参数中通过引用方式返回
            Point3d arcCenter = new Point3d(m_ArcCenter[0], m_ArcCenter[1], m_ArcCenter[2]);
            return arcCenter;
        public Arc AddArcFromPt(Point3d ptSt,Point3d ptSc,Point3d ptEn,ObjectId objid,string featurename)
            // 三点法创建圆弧
            Point3d ptCenter;
            double radius = 0.0;
            Arc objArc;
            ptCenter = GetArcCenter(ptSt, ptSc, ptEn, ref radius);
            if (isClockWise(ptCenter, ptSt, ptSc, ptEn))
                objArc = AddArcCSEP(ptCenter, ptSt, ptEn, radius,objid,featurename);
            else
                objArc = AddArcCSEP(ptCenter, ptEn, ptSt, radius,objid,featurename);
            return objArc;
        private Arc AddArcCSEP(Point3d ptCenter,Point3d ptSt,Point3d ptEn,double radius,ObjectId objid,string featurename)
            double radiusent;
            double stAng, enAng;
            // 计算半径
            radiusent = radius;
            // 计算起点角度和终点角度
            stAng = CalLineAngle(ptCenter, ptSt);
            enAng = CalLineAngle(ptCenter, ptEn);
            Arc objArc = new Arc(ptCenter, radius, stAng, enAng);
            objArc.LinetypeId = objid;
            objArc.Layer = featurename;
            objArc.SetDatabaseDefaults();
            return objArc;
        private bool isClockWise(Point3d ptCenter,Point3d ptSt,Point3d ptSc,Point3d ptEn)
            double a1, a2, a3;
            a1 = CalLineAngle(ptSt, ptCenter);
            a2 = CalLineAngle(ptSc, ptCenter);
            a3 = CalLineAngle(ptEn, ptCenter);
            bool isClock = (a1 < a2) | (a2 < a3) | (a1 < a3);
            return isClock;
        private double CalLineAngle(Point3d vStartPt,Point3d vEndPt)
            double X, Y;
            double CalculateLineAngle = 0.0;
            double dbJudgeAngle = 0.001;
            X = vEndPt.X - vStartPt.X;
            Y = vEndPt.Y - vStartPt.Y;
            if ((X > 0 && Y > 0)||(X > 0 && Y < 0))
                CalculateLineAngle = Math.Atan(Y / X);
            else if ((X < 0 && Y > 0) || (X < 0 && Y < 0))
                CalculateLineAngle = Math.PI + Math.Atan(Y / X);
            else if(X == 0)
                if (Y < 0)
                    CalculateLineAngle = -Math.PI / 2;
                else if (Y > 0)
                    CalculateLineAngle = Math.PI / 2;
            else if (Y == 0)
                if (X < 0)
                    CalculateLineAngle = Math.PI;
                else if (X > 0)
                    CalculateLineAngle = 0;
            else
            if (Math.Abs(CalculateLineAngle - 0) < dbJudgeAngle)
                return CalculateLineAngle;
            else if (CalculateLineAngle < 0)
                CalculateLineAngle = 2 * Math.PI + CalculateLineAngle;
            else
        #endregion
该贴已经同步到 菜鸟Liu的微博
GMT+8, 2025-5-31 07:03 , Processed in 0.158649 second(s), 23 queries , Gzip On.
