查看: 6727|回复: 18
AutoCAD 2013 即将出炉
发表于 2012-2-27 11:08:11 | 显示全部楼层 |阅读模式
AutoCAD 2013 即将出炉
It's always so exciting when the next release of AutoCAD arrives - I feel like a kid at Christmas as I unwrap all the new shiny features. I thought I'd share a general overview of some of the new features you'll be seeing in AutoCAD 2013. More to come of course!
下一版的AutoCAD即将到来,此刻心情异常兴奋,犹如圣诞节的小孩般急于解开其全新的超炫功能。接下来我就说说AutoCAD 2013中有什么样的新功能特性。
Command Line(命令行):
You Command Line fans will love the new modern enhancements to the UI. Now you can control the color and transparency of the command line. Float the undocked command line (which defaults to a single row) above the AutoCAD drawing window. You'll notice that the semi-transparent prompt history (displays up to 50 lines) doesn’t affect the drawing area.
如果你是命令行的狂热者,你应该会喜欢上它新的更为炫华的界面。现在你可以控制命令行的颜色和透明度。让未锁定的命令行(默认为单行)飘浮在AutoCAD图形窗口的上面。你将注意到半透明提示历史(可显示50行)而不影响绘图区域。
Array Enhancements:
AutoCAD 2012 really knocked it out of the park with the new Associative Arrays. AutoCAD 2013 will take them a bit further by showing objects in a pattern faster, and with more handy grips.
Hatching:
The Hatch Editor ribbon tab now allows you to select more than one hatch object at a time.
In-Canvas Property Preview
Dynamical check out object properties as you select them (including transparency)! Get the right property value every time!
Point Clouds
Point Clouds can now be easily attached and managed from the External Reference Manager. The Attach Point Cloud dialog box now provides a preview and more detailed information.
A new bounding box appears when you select a point cloud (making it easier to visualize its position in 3D space). The new Point Cloud ribbon tab also appears with all the necessary Point Cloud tools.
If intensity data is included, you can use the analysis tools to view point intensity with different color schemes.
(And now you can clip a point cloud!)
PressPull
Now you can press/pull multiple objects at one time! You can also select 2D and 3D curves (not just inside a bounded area).
Surface Curve Extraction
Use the new Extract Isolines tool (Surface ribbon tab) to quickly extract isoline curves from an existing surface or face of a solid.
You can change the direction of the isolines, select a chain or draw a spline on the curved surface.
Import Inventor Files
In AutoCAD 2013 you can import Inventor models (hoorah!)
Model Documentation
Be far, my favorite feature in AutoCAD 2012 was the new Model Documentation tools. Thankfully, AutoCAD 2013 adds in Detail Views and Section Views!
You can also select the objects you want to include in your model documentation (no longer limited to ALL the objects).
Associative Annotations
Now the dimensions added to the drawing views (with the model documentation tools) are associative and smart! If you change the design - these annotations do a much better job of updating (love this!).
Strike-through Text
Now available for Mtext, Mleaders, Dimensions and Tables!
Bring Leaders to the Front
Leaders are now included with the TextToFront tool
Wipeouts display but don't Plot
With the new WIPEOUTFRAME system variable.
Reverse Polyline Widths
Use the new PLINEREVERSEWIDTHS setvar when using the REVERSE tool to ensure the results you want.
Offset Preview
Hooray for a Preview of your offset results!
Autodesk Exchange Apps
Apps on Autodesk Exchange can now be accessed from any web browser.
Cloud Connectivity
Online Documents: Autodesk 360, Online Options, Open On Mobile, Upload Multiple
Customization Sync: Sync my Settings,Choose Settings
Share & Collaborate: Share Document, Collaborate Now
Model Documentation
Detail Views and Section Views has been added.
It is now possible to select what objects to include in the model documentation.
Dimensions added to the drawing views (with the model documentation tools) are associative.
Migration
Template updated
The template has been updated.
Social Media Links
Autodesk has included links to their Facebook and Twitter accounts. AutoCAD On Facebook and AutoCAD On Twitter.
Based on Google translation from Autodesk's Japanese site these are news in AutoCAD 2013:
  • Command-line options that you can click
  • Preview of property editing
  • Viewport preview of the changes
  • Extract the surface dividing line
  • Boundary stretching tool according to the situation
  • View and cross-sectional view detailed diagram
  • Strikethrough
  • Latest user templates
  • Read Inventor file
  • Autodesk Cloud connection
  • Social media connection
  • Customize synchronization and support files
  • Application of AutoCAD Autodesk Exchange
http://lynn.blogs.com/lynn_allens_blog/2012/02/autocad-2013-is-approaching-the-finish-line.html
发表于 2012-2-27 11:34:42 | 显示全部楼层
Yes!现在可以自由谈论AutoCAD 2013了!我有空贴一些大家分享一下吧
发表于 2012-2-27 13:02:24 | 显示全部楼层
看来CAD2013已经完工了,但愿好用。
发表于 2012-2-27 14:01:54 | 显示全部楼层
暂不升级,看看
发表于 2012-2-27 20:45:50 | 显示全部楼层
启动欢迎界面
发表于 2012-2-27 21:00:17 | 显示全部楼层
可惜直到RC版,那个QuickCalc Panel Anchor 的 bug 依然没有修复
安装程序界面的问题也没有解决,还是老样子,宁人失望...
发表于 2012-2-28 08:41:41 | 显示全部楼层
激活不了啊。哥们们!
发表于 2012-2-28 09:14:19 | 显示全部楼层
你是测试人员吗?如果是,那就自动激活了
发表于 2012-2-29 12:12:24 | 显示全部楼层
我现在比较期待MAC版的ACAD 2013啦
发表于 2012-2-29 17:14:45 | 显示全部楼层
要什么时候能出来呀?
GMT+8, 2025-5-18 08:54 , Processed in 0.213480 second(s), 29 queries , Gzip On.
