查看: 2643|回复: 5
错误,无法将类型“Autodesk.AutoCAD.Geometry.Point3d”转换为“double[]“
发表于 2012-2-7 18:53:23 | 显示全部楼层 |阅读模式
代码如下:
public static void SelectEntitiesWithProperties()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = HostApplicationServices.WorkingDatabase;
            TypedValue[] tvs = new TypedValue[]
                 new TypedValue((int)DxfCode.Operator, "<or"),
                 new TypedValue((int)DxfCode.Operator, "<and"),
                 new TypedValue((int)DxfCode.LayerName, "0"),
                 new TypedValue((int)DxfCode.Start, "LINE"),
                 new TypedValue((int)DxfCode.Operator, "and>"),
                 new TypedValue((int)DxfCode.Start, "CIRCLE"),
                 new TypedValue((int)DxfCode.Operator, ">="),
                 new TypedValue((int)DxfCode.Real, 10.0),// Circle Radius
                 new TypedValue((int)DxfCode.Operator, "or>")
            SelectionFilter sf = new SelectionFilter(tvs);
            PromptSelectionResult psr = ed.SelectAll(sf);
            if (psr.Status == PromptStatus.OK)
                SelectionSet SS = psr.Value;
                ObjectId[] idArray = SS.GetObjectIds();
                using (Transaction trans = db.TransactionManager.StartTransaction())
                    for (int i = 0; i < idArray.Length; i++)
                        Entity entObject = trans.GetObject(idArray, OpenMode.ForWrite) as Entity;
                        entObject.Highlight();
                        if (entObject.GetType().Name == "line")
                            Line returnLine = (Line)entObject;
                            double[] lineStartPoint = new Double[2];
                            double[] lineEndPoint = new Double[2];
                            lineStartPoint = (Double[])(returnLine.StartPoint);//错误行提示
                            lineEndPoint = (Double[])returnLine.EndPoint;//错误行提示
                            Application.ShowAlertDialog("直线的起点坐标为:" + lineStartPoint[0].ToString()
                                + "," + lineStartPoint[1].ToString()
                                + "," + lineStartPoint[2].ToString()
                                + "\n" + "直线的终点坐标为:" + lineEndPoint[0].ToString()
                                + "," + lineEndPoint[1].ToString()
                                + "," + lineEndPoint[2].ToString());
                        ed.WriteMessage(i + ":" + entObject.ObjectId.ToString() + "," + entObject.GetType().Name);
谢谢了
发表于 2012-2-8 08:42:09 | 显示全部楼层
坐标转为数组使用ToArray()如: Line myline = ent as Line;
double[] startPoint = myline.StartPoint.ToArray();
lzx838 + 1 热心帮助
发表于 2012-2-8 09:04:54 | 显示全部楼层
学了一招。
我以前都是x、y、z分别赋值的。
 楼主| 发表于 2012-2-8 09:17:55 | 显示全部楼层
double[] startPoint = myline.StartPoint.To ...
谢谢了,昨天试了一晚上也没搞定,原来方法后面忘了加(),晕死。谢谢了。
发表于 2012-2-8 09:20:03 | 显示全部楼层
好好加油,经验是慢慢积累起来的.
 楼主| 发表于 2012-2-8 10:16:48 | 显示全部楼层
lzx838 发表于 2012-2-8 09:20
好好加油,经验是慢慢积累起来的.
谢谢了。
GMT+8, 2025-5-3 18:09 , Processed in 0.248703 second(s), 28 queries , Gzip On.
