查看: 2050|回复: 4
求教!!C#有条件选择CAD实体
发表于 2012-2-7 11:06:49 | 显示全部楼层 |阅读模式
http://www.cnblogs.com/wf225/archive/2008/08/08/1263674.html
这篇文章有相关代码,可是我运行时怎么提示“错误 CS0103: 当前上下文中不存在名称"Tools"”;自己搞不明白,所以请教各位大神了,谢谢。
 楼主| 发表于 2012-2-7 11:41:30 | 显示全部楼层
各位,帮帮小弟吧,谢谢!!
发表于 2012-2-7 13:28:57 | 显示全部楼层
Tools应该是作者自己定义的类,可以自己改动一下代码,试试如下代码:
        [CommandMethod("SEWP")]
        public static void SelectEntitiesWithProperties()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            TypedValue[] tvs = new TypedValue[]
                new TypedValue((int)DxfCode.Operator, "<or"),
                new TypedValue((int)DxfCode.Operator, "<and"),
                new TypedValue((int)DxfCode.LayerName, "0"),
                new TypedValue((int)DxfCode.Start, "LINE"),
                new TypedValue((int)DxfCode.Operator, "and>"),
                new TypedValue((int)DxfCode.Start, "CIRCLE"),
                new TypedValue((int)DxfCode.Operator, ">="),
                new TypedValue((int)DxfCode.Real, 10.0),// Circle Radius
                new TypedValue((int)DxfCode.Operator, "or>")
            SelectionFilter sf = new SelectionFilter(tvs);
            PromptSelectionResult psr = ed.SelectAll(sf);
            if (psr.Status == PromptStatus.OK)
                SelectionSet SS = psr.Value;
                ObjectId[] idArray = SS.GetObjectIds();
                Database db = HostApplicationServices.WorkingDatabase;
                using (Transaction ta = db.TransactionManager.StartTransaction())
                    for (int i = 0; i < idArray.Length; i++)
                        Entity ent = (Entity)ta.GetObject(idArray, OpenMode.ForRead);
                        ent.Highlight();
                        ed.WriteMessage("\n"+i + ":" + ent.ObjectId.ToString() + "," + ent.GetType().Name);
                    ta.Commit();
xiaozhuyaofei + 1
 楼主| 发表于 2012-2-7 18:07:36 | 显示全部楼层
        [CommandMethod("SEWP")] ...
运行通过了,谢谢了。
如果返回值让它为直线的起始坐标和终点坐标,圆的话返回圆心和半径该怎么修改呢?
发表于 2012-2-8 08:39:21 | 显示全部楼层
xiaozhuyaofei 发表于 2012-2-7 18:07
运行通过了,谢谢了。
   ent.Highlight();
    if (ent is Line)
        Line myline = ent as Line;
        ed.WriteMessage("\n直线"+i+"起点坐标:"+myline.StartPoint.ToString()+"终点坐标:"+myline.EndPoint.ToString());
else if (ent is Circle)
        Circle mycircle = ent as Circle;
          ed.WriteMessage("\n圆" + i +"圆心:"+ mycircle.Center.ToString() +"半径:" +mycircle.Radius.ToString());
lzx838 + 1 热心帮助
GMT+8, 2025-5-3 18:19 , Processed in 0.140726 second(s), 28 queries , Gzip On.
