楼主: yjr111
组合物体选择
发表于 2013-9-2 10:26:52 | 显示全部楼层
绝对支持源码
发表于 2014-3-30 13:21:49 | 显示全部楼层
谢谢!支持!以后会有用到的时候
发表于 2014-9-2 00:53:19 | 显示全部楼层
做块的时候 已取消标注!; 错误: *error* 函数中出错AutoCAD 变量设置被拒绝: "nomutt" nil
发表于 2014-9-3 09:34:37 | 显示全部楼层
发表于 2014-9-30 08:12:39 | 显示全部楼层
我做了如下改动以支持spline,但没效果,请指教
;;;;;;组合物体中各图元特性
        (cond((= etype "LINE")
                  (setq texing(fixnum(vla-get-length vla_e)))
                 ((= etype "SPLINE")
                   ;spline 不能使用vla-get-length
                  ;(setq texing(fixnum(vla-get-length vla_e)))
                  (setq texing(fixnum
                    ;(vla-get-length vla_e)
                    (distance
                      (vlax-curve-getStartPoint vla_e)
                      (vlax-curve-getEndPoint vla_e)
                    ;(distance (vlax-curve-getStartPoint (setq vla_e (vlax-ename->vla-object (car (entsel))))) (vlax-curve-getEndPoint vla_e))
                 ((= etype "LWPOLYLINE")
                 ((= etype "CIRCLE")
                  (setq texing (fixnum(vla-get-radius vla_e)))
                 ((= etype "ARC")
                  (setq texing(fixnum(vla-get-arclength vla_e)))
                 ((= etype "ELLIPSE")
                  (setq texing (fixnum(vla-get-RADIUSRATIO vla_e)))
                 ((or(= etype "TEXT")(= etype "MTEXT"))
                  (setq texing(vla-get-textstring vla_e))
                 ((= etype "INSERT")
                  (setq texing(vla-get-name vla_e))
                 ((= etype "HATCH")
                  (setq texing (fixnum(vla-get-area vla_e)))
                 ((= etype "SOLID")
                  (setq texing (length(vlax-safearray->list(vlax-variant-value(vla-get-coordinates vla_e)))))
                 (T
                  (setq texing etype)
                (setq as_e  (strcat etype (rtos texing 2 5)))
                (findm2mp AS_E)
                (SETQ lst_texing NIL)
               ((= etype "SPLINE")
                  (setq texing(fixnum
                    (distance
                (findm2mp AS_E)
                (findm2mp AS_E)
               ((= etype "CIRCLE")
                (setq texing(fixnum(vla-get-radius vla_e)))
                (findm2mp AS_E)
               ((= etype "ARC")
                (setq texing (fixnum(vla-get-arclength vla_e)))
                (findm2mp AS_E)
                (findm2mp AS_E)
                (setq as_e (strcat etype texing))
                (if(= etype "TEXT")
                   (findm2mp AS_E)
                    (findm2mp AS_E)
               ((= etype "INSERT")
                (setq texing (vla-get-name vla_e))
                (findm2mp AS_E)
               ((= etype "HATCH")
                (findm2mp AS_E)
               ((= etype "SOLID")
                (findm2mp AS_E)
               (T
                (setq texing etype)
                (findm2mp AS_E)
发表于 2014-10-20 20:21:32 | 显示全部楼层
感谢分享...不错
发表于 2015-9-12 10:28:28 | 显示全部楼层
要是能把物体组成块就好了,不是所有选择出来组成一个大块,是希望把相同组合体选择出来组块
发表于 2015-10-29 20:02:01 | 显示全部楼层
很好用的程序,,谢谢楼主分享。。
发表于 2017-11-2 16:51:32 | 显示全部楼层
谢谢楼主分享!非常感谢楼主!
发表于 2018-5-1 17:07:39 | 显示全部楼层
老师:我用这个命令时提示
命令: xse
; 错误: no function definition: VLAX-GET-ACAD-OBJECT
怎么处理?
GMT+8, 2025-8-3 00:33 , Processed in 0.170044 second(s), 18 queries , Gzip On.
