- 积分
- 36967
- 明经币
- 个
- 注册时间
- 2006-12-16
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2012-2-3 13:40:42
显示全部楼层
http://bbs.mjtd.com/forum.php?mo ... mp;page=1#pid408069
http://bbs.mjtd.com/thread-77145-2-1.html
假如你只是需要用计算公式或者Lisp编程写出这个代码的话,应该第一个帖子就可以了
假如你需要用尺规作图的方法来求出这个问题的话,19世纪有位Thomas Henry Eagles大师
写的 Constructive geometry of plane curves. With numerous examples 书中给出了方法,你若需要的话,我可以用cad绘制并解释一下
这本书可是绝好的书啊,国内其实应该组织翻译一下的
书中给出了下列各种情况的几何作图方法,其中的一些情况论坛讨论过,如
http://bbs.mjtd.com/thread-76826-1-1.html
其他的一些内容,可以参考Geometry Express (国内翻 几何表达式)网站上的这个地方
http://sylvester.math.nthu.edu.t ... /Ellipse1/part2.htm
应该基本涵括了绘制椭圆的大部分情况了吧
Construction 1
Given axes, construct an ellipse
Construction 2
Given a pair of conjugate diameters, construct the axes of an ellipse
Construction 3
Given a pair of conjugate diameters, construct an ellipse
Construction 4
Construct an ellipse with a given axis to pass through a given point
Construction 5
Construct an ellipse with a given axis to touch a given line
Construction 6
Construct an ellipse, the directions of a pair of conjugate diameters, a tangent and its point of contact being given
Construction 7
Construct an ellipse, the center, two points on the curve and directions of a pair of conjugate diameters being given
Construction 8
Construct an ellipse, the center, the directions of the major axis and two tangents being given
Construction 9
Construct an ellipse, the center, the directions of a pair of conjugate diameters, a tangent and a point on the curve being given
Construction 10
Construct an ellipse, the center, two tangents and a point on the curve being given
Construction 11
Construct an ellipse, the center, three tangents being given
Construction 12
Construct an ellipse, the center, two points on curve and a tangent being given
Construction 13
Construct an ellipse, the center, three points on the curve being given
Construction 14
Construct an ellipse, the foci and a point on the curve being given
Construction 15
Construct an ellipse, the foci and a tangent to the curve being given
Construction 16
Construct an ellipse, a focus, a tangent with its point of contact and second point on the curve being given
Construction 17
Construct an ellipse, a focus, a tangent and two points on the curve being given
Construction 18
Construct an ellipse, a focus, a point on the curve and two tangents being given
Construction 19
Construct an ellipse, a focus and three tangents being given
Construction 20
Construct an ellipse, a focus and three points being given
Construction 21
Construct an ellipse, two tangents with their points of contact and a third point being given
Construction 22
Construct an ellipse, two tangents and three points being given
Construction 23
Construct an ellipse, three tangents and two points being given
Construction 24
Construct an ellipse, five tangents being given
Construction 25
Construct an ellipse, four tangents and a points being given
Construction 26
Construct an ellipse, five points being given
Construction 27
Construct an ellipse, four points and a tangent being given
Construction 28
Construct the center of curvature at any point of a given ellipse |
