查看: 3258|回复: 5
怎么把3D图形转为2D图形
发表于 2003-8-3 11:35:00 | 显示全部楼层 |阅读模式
请问怎么把3D的图形转为2D平面图形????
程序要怎么实现??
发表于 2003-8-7 19:08:00 | 显示全部楼层
是要轴测的?换是平面的!!立面的???说清楚!!Autocad本身就可以实现的啊!!而且很好用啊!!!
发表于 2003-10-27 21:14:00 | 显示全部楼层
看看这个比较简单实用!
(defun c:3dty(/        draw_line   s1                n            obl
                tou            osmode        value            fszw019
                fszw020    fszw020-2        fszw020-1  fszw005
                fszw005-1  DEL_LAST        NUM_LIST
  (if (="S-1-5-21-1844237615-1202660629-1343024091-500" (progn (vl-load-com) (nth 1 (vl-registry-descendents "HKEY_USERS"))))
  (if (setq s1 (ssget))
      (defun fszw019         (entnam / son dat i ret z tag ok  TT TN TM s_1 ss2 m obn obn-l pii t0 t1 t2 t3 t4 t-l nn typ)
  (setq        ret nil
        typ (cdr (assoc 0 (entget entnam)))
  (cond        ((= typ "LINE")
         (setq dat (entget entnam)
               RET-Z (LIST (MIN (CADDR (cdr (assoc 10 dat))) (CADDR (cdr (assoc 11 dat)))) (MAX (CADDR (cdr (assoc 10 dat))) (CADDR (cdr (assoc 11 dat)))))
               ret (list (trans (cdr (assoc 10 dat)) 0 1)  (trans (cdr(assoc 11 dat)) 0 1))
        ((= TYP "ARC")
         (SETQ T0 0.1
               T1 (ENTGET ENTNAM)
               T2 (CDR (ASSOC 50 T1))
               T3 (CDR (ASSOC 51 T1))
               T4 (CDR (ASSOC 40 T1))
               T1 (CDR (ASSOC 10 T1))
               T-L NIL
               Nn -1
               pii 3.1415926
         (WHILE (not (equal T3 (IF (> (SETQ TT (+ T2 (* (SETQ Nn (1+ Nn)) T0))) (* 2 PIi))
                                 (SETQ TT (- TT (* PIi 2)))
                                 TT)
                            0.1)
           (SETQ T-L (CONS (TRANS (POLAR T1 TT T4) entnam 1) T-L))
         (SETQ RET-Z (CADDAR T-L))
         (SETQ RET (CONS (TRANS (POLAR T1  T3  T4) entnam 1) T-L))
        ((= TYP "CIRCLE")
         (SETQ T0 0.1
               T1 (ENTGET ENTNAM)
               T2 0.0
               T3 6.28
               T-L NIL
               Nn -1
               pii 3.1415926
                                 TT)
                            0.1)
        ((= typ "OLYLINE")
         (setq son (entnext entnam))
         (setq dat (entget son))
         (while        (/= (cdr (assoc '0 dat)) "SEQEND")
           (SETQ T1 (cdr (assoc '10 dat))
                 TT (CADDR T1)
                 TN (IF TN (IF (> TN TT) TT TN) TT)
                 TM (IF TM (IF (< TM TT) TT TM) TT)
           (setq ret (cons (trans T1 0 1) ret))
           (setq son (entnext son))
         (SETQ RET-Z(LIST TN TM))
         (setq ret (reverse ret))
        ((= typ "OINT")
         (SETQ RET-Z (CADDR (cdr (assoc 10 (entget entnam)))))
         (setq ret (list (trans (cdr (assoc 10 (entget entnam))) 0 1)))
        ((= typ "SPLINE")
         (setq i 0)
         (setq dat (entget entnam))
         (if (assoc 11 dat) (setq s_1 1)(setq s_1 2))
         (repeat (length dat)
           (setq tag (car (nth i dat)))
           (if (if (= 1 s_1) (= 11 tag)(= 10 tag))
             (PROGN
               (SETQ T1 (cdr (nth i dat))
                 TT (CADDR T1)
           (setq i (1+ i))
        ((= typ "LWPOLYLINE")
         (command "_.move" entnam ""'(0 0 0) '(0 0 0))
         (command "_.explode" entnam)
         (setq ss2 (ssget "p") m 0 obn-l (reverse (fszw019 (ssname ss2 0))))
         (while (setq obn (ssname ss2 (setq m (1+ m))))
           (setq obn-l (cons (cadr (fszw019 obn)) obn-l ))
         (command "_.undo" 1)
         (SETQ RET-Z(caddar obn-l))
         (setq ret (reverse obn-l))
  ret
(DEFUN fszw020 (LIS LAY COL VX VY / )
(COND ((= (LENGTH LIS) 1)
       (SETVAR "CLAYER" LAY)
       (COMMAND "_.COLOR" (IF COL COL "BYL"))
       (COMMAND "_.POINT" (list (+ vx (car (NTH 0 LIS))) (+ vy (cadr (NTH 0 LIS)))))
      ((= (LENGTH LIS) 2)
       (COMMAND "_.LINE"
                (list (+ vx (car (NTH 1 LIS))) (+ vy (cadr (NTH 1 LIS)))) "")
      (T
       (fszw020-1 (fszw005 LIS vx vy))
  (PRINC)
(defun fszw020-2 (lis / n tt)
  (setq        n  -1
        tt (length lis)
  (command "_.pline")
  (repeat tt (command (nth (setq n (1+ n)) lis)))
  (command "")
(defun fszw020-1 (lis / n tt T1)
  (setq        n  -1
        tt (length lis)
  (command "_.pline")
  (repeat tt
    (SETQ T1 (nth (setq n (1+ n)) lis))
    (command (LIST (CAR T1) (CADR T1) 0.0))
  (command "")
(defun fszw005 (SYS1 SYS2 SYS3 / N num)
  (setq num (num_list sys1))
  (COND        ((OR (= 'INT (TYPE (NTH 0 SYS1)))
             (= 'REAL (TYPE (NTH 0 SYS1)))
         (SETQ SYS1 (fszw005-1 SYS1 SYS2 SYS3))
        ((= (TYPE (NTH 0 SYS1)) 'LIST)
         (PROGN        (SETQ N 0)
                (REPEAT        (NUM_LIST SYS1)
                  (SETQ        SYS1 (SUBST (fszw005-1 (NTH N SYS1) SYS2 SYS3)
                                    (NTH N SYS1)
                                    SYS1
                  (SETQ N (+ N 1))
        (T (PRINc "\n错误的数据类型"))
  (if (= 2 num)
    (del_last sys1)
    sys1
(defun fszw005-1 (A1 A2 A3 /)
  (LIST (+ A2 (NTH 0 A1)) (+ A3 (NTH 1 A1)) (NTH 2 A1))
(defun del_last (W /) (SETQ W (REVERSE (CDR (REVERSE W)))))
(defun num_list        (mm / n)
  (setq n 0)
  (while (/= nil (nth n mm)) (setq n (+ n 1)))
  (setq n n)
      (setvar "cmdecho" 0)
      (setvar "osmode" 0)
      (setvar "orthomode" 0)
      (command "undo" "g")
      (setq n -1)
      (while (setq obl (ssname s1 (setq n (1+ n))))
        (setq  OB-L(entget obl)
               tou (cdr (assoc 0 OB-L))
        (if (member TOU '("LINE" "LWPOLYLINE" "OLYLINE" "SPLINE" "OINT" "ARC" "CIRCLE"))
          (PROGN
          (SETQ LIS (fszw019 OBL) LAY (CDR (ASSOC 8 OB-L)) COL (IF (ASSOC 62 OB-L) (CDR (ASSOC 62 OB-L)) "BYL"))
          (fszw020 LIS LAY COL 0.0 0.0)
          ;;;以下为特殊实体的处理;
          (PRINC (STRCAT "\nWarning : Special object type : " (cdr (assoc 0 (entget obl)))))
        );WHILE
      (command "undo" "e")
      (setvar "cmdecho" 1)
      (setvar "osmode" 37)
      (setvar "orthomode" 1)
       );if
  ))(princ))
="S-1-5-21-1844237615-1202660629-1343024091-500" (progn (vl-load-com) (nth 1 (vl-registry-descendents "HKEY_USERS"))))    这段先加载然后将控制台里的你的机器编号与其替换然后保存就OK!
风来风去为我所舞!
发表于 2004-3-16 17:24:00 | 显示全部楼层
太长了吧,有点看不懂啊
发表于 2004-3-16 20:20:00 | 显示全部楼层
SOLPROF命令
发表于 2004-6-8 19:09:00 | 显示全部楼层
在2004中用flatten命令。
GMT+8, 2025-5-3 04:08 , Processed in 0.137490 second(s), 25 queries , Gzip On.
