查看: 2640|回复: 0
求助:用AutoCAD.Net C#创建带属性块的方法?
发表于 2011-12-26 22:53:28 | 显示全部楼层 |阅读模式
--------------以下代码是在AutoCAD2004中用VBA创建带属性的块
Private Sub MyDFZK1(Mblk As String)
    Dim circleObj(0) As AcadCircle
    Dim radius As Double
     Dim insPt(0 To 2) As Double
    insPt(0) = 0:    insPt(1) = 0:    insPt(2) = 0
    Dim buffblock  As AcadBlock
    Set buffblock = ThisDrawing.Blocks.Add(insPt, Mblk)
    radius = 1#
    Set circleObj(0) = buffblock.AddCircle(insPt, radius)
    Dim hatchObj As AcadHatch
    Dim patternName As String
    Dim PatternType As Long
    Dim bAssociativity As Boolean
    ' 定义和创建图案填充
    patternName = "SOLID"
    PatternType = 0
    bAssociativity = True
    Set hatchObj = buffblock.AddHatch(PatternType, patternName, bAssociativity)
    hatchObj.AppendOuterLoop (circleObj)
    hatchObj.Evaluate
    radius = 2#
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim insertionPoint(0 To 2) As Double
    Dim tag As String
    Dim value As String
    height = 2.5
    mode = acAttributeModeNormal
    prompt = "孔号:"
    insertionPoint(0) = insPt(0) + 5#: insertionPoint(1) = insPt(1) + 5#: insertionPoint(2) = insPt(2)
    tag = "孔号"
    value = "ZK001"
    Set attributeObj = buffblock.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
    ThisDrawing.Regen (True)
End Sub
请各位大侠指点,在AUTOCAD2007中,用AUTOCAD.NET   C#创建带属性块的方法?
GMT+8, 2025-5-3 18:01 , Processed in 0.132010 second(s), 24 queries , Gzip On.
