楼主: 【KAIXIN】
批量交点插入块(支持选块样板,多段线、曲线、直线)
发表于 2021-6-24 23:57:49 | 显示全部楼层
谢谢朋友,真是好人,
发表于 2021-6-30 10:00:31 | 显示全部楼层
支持一下...
支持一下...
发表于 2021-11-15 11:11:12 | 显示全部楼层
感谢,非常实用的程序
发表于 2022-9-7 12:22:10 | 显示全部楼层
学习学习支持一下
发表于 2023-11-1 19:37:27 | 显示全部楼层
这个源码好像和你的不完全一样
(defun c:t1 ()
(vl-load-com)
(setq cmd (getvar "cmdecho"))
(setvar "cmdecho" 0 )
(setq blockent (ssname (ssget "L") 0))
(command "select" "")
  (setvar "osmode" 15359)
  (princ "\n★功能:在批量图元的相交点处插入块")
  (princ "\n请选择多段线、样条曲线、直线、圆、圆弧或椭圆:")
  (command "undo" "be")
  (if (not (setq ss (ssget '((0 . "*LINE,ARC,CIRCLE,ELLIPSE")))))
    (progn (princ "\n提示:未选取图元,程序退出。\n") (exit))
  (setq acad (vlax-get-acad-object))
  (setq acaddocument (vla-get-activedocument acad))
  (setq mspace (vla-get-modelspace acaddocument))
  (setq blockname (cdr (assoc 2 (entget blockent))))
  (setq blockX (cdr (assoc 41 (entget blockent))))
  (setvar "osmode" 0)
  (setq ptlist (ssinters ss))
  (foreach pt ptlist
    (vla-insertblock
      mspace
      (vlax-3d-point pt)
      blockname
      blockX
      blockX
      blockX
      0
  (command "undo" "e")
(defun ssinters (ss / i num obj1 obj2 j interpts ptlist)
  (setq i 0 num (sslength ss))
  (while (< i (1- num))
    (setq obj1 (ssname ss i)
          obj1 (vlax-ename->vla-object obj1)
          j    (1+ i))
    (while (< j num)
      (setq obj2     (ssname ss j)
            obj2     (vlax-ename->vla-object obj2)
            interpts (vla-intersectwith obj1 obj2 0)
            interpts (vlax-variant-value interpts))
      (if (> (vlax-safearray-get-u-bound interpts 1) 0)
          (setq interpts (vlax-safearray->list interpts))
          (while (> (length interpts) 0)
            (setq ptlist (cons (list (car interpts) (cadr interpts) (caddr interpts)) ptlist))
            (setq interpts (cdddr interpts)))
      (setq j (1+ j))
    (setq i (1+ i))
  ptlist
发表于 2024-7-9 13:15:43 | 显示全部楼层
感谢作者的分享!
发表于 2024-8-27 10:23:43 | 显示全部楼层
;;;*****交点插块 程序开始*****
(defun c:t1 ()
  (setvar "cmdecho" 0)
  (vl-load-com)
  (princ
    "\n★功能:在批量图元的相交点处插入块。\n提示:在执行此功能前请确定图块的基点是否在其中心位置,否则会出现插入点偏位现象。\n"
  (while
    (progn (setq blockent     (entsel "\n请选择要插入交点的图块:")
                 blockentname (car blockent)
           (not        (if (= blockent nil)
                  nil
                  (= (cdr (assoc 0 (entget blockentname))) "INSERT")
(princ
       "\n提示:选取的不是图块或未选取任何图元,请重新选取:"
  (setq blockname (cdr (assoc 2 (entget blockentname))))
  (initget 6)
  (if (not (setq bili (getreal "\n插入比例<1.0>")))
    (setq bili 1.0)
  (setvar "osmode" 0)
  (foreach pt ptlist
    (vla-insertblock
      mspace
      (vlax-3d-point pt)
      blockname
      bili
      bili
      bili
      0
  (setq        i   0
        num (sslength ss)
          j    (1+ i)
    (while (< j num)
                       obj1
                       obj2
                       0
          (setq        interpts
                                     (cadr interpts)
                                     (caddr interpts)
                               ptlist
      (setq j (1+ j))
    (setq i (1+ i))
  ptlist
;;;*****交点插块 程序结束*****
GMT+8, 2025-5-1 17:44 , Processed in 0.190150 second(s), 18 queries , Gzip On.
