- 积分
- 4434
- 明经币
- 个
- 注册时间
- 2006-7-11
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
楼主 |
发表于 2011-12-10 13:06:01
显示全部楼层
代码在这里
- Public Class Jig_CCopy
- ' 从DrawJig类继承.
- Inherits DrawJig
- ' 声明全局变量.
- Dim sourcePt, targetPt, curPt As Point3d
- Dim keyword As String
- Dim i, k, few As Integer
- Dim entCopy(,), entCopy1(), oldEnt() As Entity, ids As ObjectId()
- Dim db As Database = HostApplicationServices.WorkingDatabase
- Dim doc As Document = Application.DocumentManager.MdiActiveDocument
- Dim ed As Editor = doc.Editor
- <CommandMethod("CCopy")> Sub testCCopy()
- keyword = "C"
- Dim res As PromptSelectionResult
- Dim sSet As SelectionSet
- Dim opt As New PromptSelectionOptions
- res = ed.SelectImplied()
- If res.Status = PromptStatus.OK Then
- sSet = res.Value
- ids = sSet.GetObjectIds()
- Else
- ' 选择集交互操作
- opt.MessageForAdding = "请选择对象:"
- opt.AllowDuplicates = True
- res = ed.GetSelection(opt)
- If res.Status <> PromptStatus.OK Then Return
- sSet = res.Value
- End If
- ' 得到基点
- Dim optPoint As New PromptPointOptions(vbCrLf & "请输入基点:")
- optPoint.AllowNone = True
- Dim resPoint As PromptPointResult = ed.GetPoint(optPoint)
- If resPoint.Status <> PromptStatus.OK Then Return
- sourcePt = resPoint.Value
- ReDim entCopy1(ids.Length - 1)
- ReDim oldEnt(ids.Length - 1)
- '获取对象
- Using trans As Transaction = db.TransactionManager.StartTransaction()
- For i = 0 To ids.Length - 1
- oldEnt(i) = trans.GetObject(ids(i), OpenMode.ForWrite)
- Next
- trans.Commit()
- End Using
- Dim lop As Boolean = True
- '循环
- Do While lop = True
- ' 将源对象设置为高亮
- oldEnt(i).Highlight()
- ' 复制
- entCopy1(i) = oldEnt(i).Clone()
- Next
- ' 设置目标点和拖拽临时点
- targetPt = sourcePt
- curPt = targetPt
- ' 开始拖拽.
- Dim jigRes As PromptResult = ed.Drag(Me)
- If jigRes.Status = PromptStatus.OK Then
- AppendEntity(entCopy1(i))
- Next
- ElseIf keyword = "A" Then
- curPt = targetPt
- ' 开始拖拽.
- jigRes = ed.Drag(Me)
- For k = 0 To few - 1
- AppendEntity(entCopy(k, i))
- Next
- Next
- ' 取消源对象的高亮状态.
- oldEnt(i).Unhighlight()
- Next
- '结束循环
- lop = False
- ElseIf keyword = "F" Then
- curPt = targetPt
- ' 开始拖拽.
- Next
- Next
- ' 取消源对象的高亮状态.
- Next
- lop = False
- Else
- lop = False
- ' 取消源对象的高亮状态.
- Next
- End If
- Else
- lop = False
- ' 取消源对象的高亮状态.
- Next
- End If
- Else
- lop = False
- ' 取消源对象的高亮状态.
- Next
- End If
- Loop
- End Sub
- ' Sampler函数用于检测用户的输入.
- Protected Overrides Function Sampler(ByVal prompts As JigPrompts) As SamplerStatus
- If keyword = "C" Then
- Dim optJig As New JigPromptPointOptions(vbCrLf & "请指定第二点[阵列(A)]:")
- ' 设置拖拽光标类型.
- optJig.Cursor = CursorType.RubberBand
- ' 设置拖动光标基点.
- optJig.BasePoint = sourcePt
- optJig.UseBasePoint = True
- '为optJig添加关键字
- optJig.Keywords.Add("A", "A", "A", False, True)
- 'optJig.Keywords.Add("C", "C", "C", False, True)
- ''默认关键字
- 'optJig.Keywords.Default = "C"
- ' 用AcquirePoint函数得到用户输入的点.
- Dim resJig As PromptPointResult = prompts.AcquirePoint(optJig)
- targetPt = resJig.Value
- ' 如果用户拖拽,则用矩阵变换的方法移动选择集中的全部对象.
- If resJig.Status = PromptStatus.Keyword Then
- keyword = "A"
- '获取等分数量
- Dim optfew As New PromptIntegerOptions(vbCrLf & "请输入等分数量")
- Dim resfew As PromptIntegerResult = ed.GetInteger(optfew)
- If resfew.Status <> PromptStatus.OK Then Return True
- few = resfew.Value
- ReDim entCopy(0 To few - 1, ids.Length - 1)
- ' 复制.
- entCopy(k, i) = oldEnt(i).Clone()
- Next
- Next
- Else
- If curPt <> targetPt Then
- Dim moveMt As Matrix3d = Matrix3d.Displacement(targetPt - curPt)
- entCopy1(i).TransformBy(moveMt)
- Next
- ' 保存当前点.
- curPt = targetPt
- Return SamplerStatus.OK
- Else
- Return SamplerStatus.NoChange
- End If
- End If
- ' 定义一个点拖动交互类.
- Dim optJig As New JigPromptPointOptions(vbCrLf & "请指定第二点[布满(F)]:")
- ' 设置拖拽光标类型.
- ' 设置拖动光标基点.
- '为optJig添加关键字
- optJig.Keywords.Add("F", "F", "F", False, True)
- ''默认关键字
- keyword = "F"
- ' 复制.
- Next
- Next
- Else
- 'Dim moveMt As Matrix3d = Matrix3d.Displacement((targetPt - curPt) / few * (k + 1))
- entCopy(k, i).TransformBy(Matrix3d.Displacement((targetPt - curPt) * (k + 1)))
- Next
- Next
- ' 保存当前点.
- curPt = targetPt
- Else
- End If
- End If
- ' 定义一个点拖动交互类.
- Dim optJig As New JigPromptPointOptions(vbCrLf & "请指定第二点:")
- ' 设置拖拽光标类型.
- ' 设置拖动光标基点.
- entCopy(k, i).TransformBy(Matrix3d.Displacement((targetPt - curPt) / few * (k + 1)))
- Next
- Next
- ' 保存当前点.
- curPt = targetPt
- Else
- End If
- End If
- End Function
- ' WorldDraw函数用于刷新屏幕上显示的图形.
- Protected Overrides Function WorldDraw(ByVal draw As WorldDraw) As Boolean
- ' 刷新画面.
- draw.Geometry.Draw(entCopy1(i))
- Next
- Else
- ' 刷新画面.
- draw.Geometry.Draw(entCopy(k, i))
- Next
- Next
- End If
- Return True
- End Function
- ' 将图形对象加入到模型空间的函数.
- Public Shared Function AppendEntity(ByVal ent As Entity) As ObjectId
- ' 得到当前文档图形数据库.
- Dim entId As ObjectId
- ' 以读方式打开块表.
- Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
- ' 以写方式打开模型空间块表记录.
- Dim btr As BlockTableRecord = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
- ' 将图形对象的信息添加到块表记录中,并返回ObjectId对象.
- entId = btr.AppendEntity(ent)
- ' 把图形对象添加到事务处理中.
- trans.AddNewlyCreatedDBObject(ent, True)
- ' 提交事务处理.
- trans.Commit()
- End Using
- Return entId
- End Function
- End Class
