查看: 3339|回复: 5
工作坐标系
发表于 2011-11-5 00:15:06 | 显示全部楼层 |阅读模式
附上代码:
[CommandMethod("NCS")]
        public void NCS()
            //获得当前文档和数据库,并启动一个事务
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Database acCurDb = acDoc.Database;
            using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                //以读的方式打开UCS表
                UcsTable acUCSTbl;
                acUCSTbl = acTrans.GetObject(acCurDb.UcsTableId, OpenMode.ForRead) as UcsTable;
                // 以只读方式打开视图表  Open the View table for read
                UcsTableRecord acUCSTblRec;
                //检查看“New_UCS”用户坐标系表记录是否存在
                if (acUCSTbl.Has("Layout_UCS") == false)
                    acUCSTblRec = new UcsTableRecord();
                    acUCSTblRec.Name = "Layout_UCS";
                    //以写的方式打开UCSTable
                    acUCSTbl.UpgradeOpen();
                    //添加新的 UCS 表记录
                    acUCSTbl.Add(acUCSTblRec);
                    acTrans.AddNewlyCreatedDBObject(acUCSTblRec, true);
                else
                    acUCSTblRec = acTrans.GetObject(acUCSTbl["Layout_UCS"],
                                                    OpenMode.ForWrite) as UcsTableRecord;
                acUCSTblRec.Origin = new Point3d(100, 100, 0);
                acUCSTblRec.XAxis = new Vector3d(1, 0, 0);
                acUCSTblRec.YAxis = new Vector3d(0, 1, 0);
                // 以只读方式打开视口表
                ViewportTable acVportTbl;
                acVportTbl = acTrans.GetObject(acCurDb.ViewportTableId,
                                               OpenMode.ForRead) as ViewportTable;
                // 以写的方式打开视图表
                acVportTbl.UpgradeOpen();
                // 遍历符号表的每一个对象
                foreach (ObjectId acObjId in acVportTbl)
                    //以写方式打开对象
                    ViewportTableRecord acVportTblRec;
                    acVportTblRec = acTrans.GetObject(acObjId, OpenMode.ForWrite) as ViewportTableRecord;
                    // 判断是否是活动窗口,如果是就删除  See if it is one of the active viewports, and if so erase it
                    if (acVportTblRec.Name == "*Active")
                        acVportTblRec.IconAtOrigin = true;
                        acVportTblRec.IconEnabled = true;
                        acVportTblRec.SetUcs(acUCSTblRec.ObjectId);
                        acDoc.Editor.UpdateTiledViewportsFromDatabase();
                        UcsTableRecord acUCSTblRecActive;
                        acUCSTblRecActive = acTrans.GetObject(acVportTblRec.UcsName,
                                                              OpenMode.ForRead) as UcsTableRecord;
                        CAD.CurrentEditor.WriteMessage("当前坐标系为: " + acUCSTblRecActive.Name);
                        Point3d center = new Point3d(0, 0, 0); //定义圆的中心
                        double radius = 50;
                        Circle circle = new Circle(center, new Vector3d(0.0, 0.0, 1.0), radius);
                        //获得AutoCAD块表,AutoCAD将加入到图形中的对象的信息都放在这个表中
                        BlockTable bt = (BlockTable)CAD.CurrentTransactionManager.GetObject(CAD.CurrentDatabase.BlockTableId, OpenMode.ForRead, false);
                        //获得块表记录
                        BlockTableRecord btr = (BlockTableRecord)
                        CAD.CurrentTransactionManager.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false);
                        //向块表记录加入圆的相关信息
                        btr.AppendEntity(circle);
                        //向AutoCAD加入圆
                        CAD.CurrentTransactionManager.AddNewlyCreatedDBObject(circle, true);
                        // 保存新对象到数据库中
                        acTrans.Commit();
发表于 2011-11-5 08:11:53 | 显示全部楼层
Vector3d tVec1 = acDoc.Database.Ucsorg.GetAsVector(); 或 Vector3d tVec1 =new Vector3d(100, 1000, 0);
Circle circle = new Circle(center + tVec1 , new Vector3d(0.0, 0.0, 1.0), radius);
对于实体的操作使用的应该都是世界坐标系WCS
发表于 2011-11-5 09:10:45 | 显示全部楼层
谢谢兄弟帮忙!
发表于 2011-11-5 09:39:12 | 显示全部楼层
我在建坐标系时也出现相同问题,请各位帮帮忙啊 ,刚学二次开发:
1.以wcs为基准,新建ucs1
2.以ucs1为基准,新建ucs2
3.相同代码,ucs1位置正确了,但ucs2就不对了,它的圆心位置仍然是以wcs为准了,而我想以ucs1为基准。
public static void DrawingLayout(double[] orgPt, double length, double width, double height)
            //初始化绝对坐标系
            IniLayout.TCS("ABS", new double[3] { 0, 0, 0 });
            CAD.CreateCircle(new double[4] { 0, 0, 0, 50 });
            //初始化坐标系ucs1:
            IniLayout.TCS("ucs1", orgPt);
            //初始化坐标系ucs2:
            double[] p = new double[3];
            p[0] = 1000 + length / 2;
            p[1] = 1000 + width / 2;
            p[2] = 0;
            IniLayout.TCS("ucs2", p);
   /// <summary>
        /// 给定原点,创建坐标系
        /// </summary>
        public static void TCS(String ucsName, double[] p)
            using (DocumentLock docLock = CAD.CurrentDocument.LockDocument())   //注意此句,如果自定义对话框与CAD交互,一定要锁定文档
                //获得当前文档和数据库,并启动一个事务,开始事务处理
                using (Transaction acTrans = CAD.CurrentDatabase.TransactionManager.StartTransaction())
                    //以读的方式打开UCS表
                    UcsTable acUCSTbl;
                    acUCSTbl = acTrans.GetObject(CAD.CurrentDatabase.UcsTableId, OpenMode.ForRead) as UcsTable;
                    //检查看0cs用户坐标系表记录是否存在
                    try
                        if (acUCSTbl.Has(ucsName) == false)
                            acUCSTblRec.Name = ucsName;
                            //添加新的 UCS 表记录
                        else
                            acUCSTblRec = acTrans.GetObject(acUCSTbl[ucsName], OpenMode.ForWrite) as UcsTableRecord;
                        CAD.CurrentEditor.WriteMessage(p[0].ToString() + ">" + p[1].ToString() + "\n");
                        acUCSTblRec.Origin = new Point3d(p[0], p[1], p[2]);
                        // 以只读方式打开视口表
                        acVportTbl = acTrans.GetObject(CAD.CurrentDatabase.ViewportTableId,
                        // 以写的方式打开视图表
                        // 遍历符号表的每一个对象
                            //以写方式打开对象
                            // 判断是否是活动窗口
                                CAD.CurrentDocument.Editor.UpdateTiledViewportsFromDatabase();
                                CAD.CurrentEditor.WriteMessage("\n当前坐标系为: " + acUCSTblRecActive.Name);
                                // 保存新对象到数据库中
                                acTrans.Commit();
                    catch (Exception e)
                        MessageBox.Show(e.Message);
发表于 2011-11-5 09:50:02 | 显示全部楼层
        public static ObjectId CreateCircle(double[] p)
            ObjectId entId = ObjectId.Null;
                CAD.CurrentEditor.WriteMessage("\n" + p[0].ToString()+" "+p[1].ToString()+" "+ p[2].ToString()+" " + p[3].ToString()+"\n");
                Point3d center = new Point3d(p[0], p[1], p[2]);
                Vector3d tVec1 = CAD.CurrentDocument.Database.Ucsorg.GetAsVector();
                Circle circle = new Circle(center+tVec1, new Vector3d(0.0, 0.0, 1.0),p[3]);
                Database db = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database;
                //开始事务处理,也就是往CAD中加入东西
                Transaction trans = CAD.CurrentTransactionManager.StartTransaction();
                BlockTable bt = (BlockTable)CAD.CurrentTransactionManager.GetObject(db.BlockTableId, OpenMode.ForRead, false);
                //获得块表记录
                //向块表记录加入圆的相关信息
                entId = btr.AppendEntity(circle);
                //向AutoCAD加入圆
                trans.Commit();
            return entId;
发表于 2011-11-5 14:42:09 | 显示全部楼层
顶。。。求高人指点
GMT+8, 2025-5-3 18:01 , Processed in 0.175866 second(s), 26 queries , Gzip On.
