查看: 3414|回复: 2
请问大家如何在图纸空间中添加对象
发表于 2011-10-27 17:40:10 | 显示全部楼层 |阅读模式
一般情况下我们用程序生成的对象都在模型空间里显示,我需要在图纸空间的输出一段文字,请教一下,需要怎样才能实现呢?我用的是vb.net,C#的实现方法也可以,谢谢大家!
发表于 2011-10-28 14:08:49 | 显示全部楼层
       /// <summary>
        /// 开始当前事务处理
        /// </summary>
        /// <returns>开始当前事务处理</returns>
        public static Autodesk.AutoCAD.DatabaseServices.Transaction  StartTransaction
            get
                return Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction();
/// <summary>
        /// 图元添加到模型空间
        /// </summary>
        public static ObjectId AddToModelSpace(this Autodesk.AutoCAD.DatabaseServices.Entity ent)
            return ent.AddToSomeSpace("Model");
        /// <summary>
        /// 图元添加到任意空间
        /// </summary>
        public static ObjectId AddToSomeSpace(this Autodesk.AutoCAD.DatabaseServices.Entity ent, string LayoutName)
            ObjectId entId = ObjectId.Null;
            using (Transaction trans = StartTransaction)
                DBDictionary dict = (DBDictionary)trans.GetObject(CurrentDatabase.LayoutDictionaryId, OpenMode.ForRead);//得到所有空间,包括模型及布局
                ObjectId lyid = dict.GetAt(LayoutName);
                Layout ly = (Layout)trans.GetObject(lyid, OpenMode.ForRead);
                BlockTableRecord btr = (BlockTableRecord)trans.GetObject(ly.BlockTableRecordId, OpenMode.ForWrite);
                entId = btr.AppendEntity(ent);
                trans.AddNewlyCreatedDBObject(ent, true);
                trans.Commit();
            return entId;
代码一看就应该明白。可以添加到任意空间,用了扩展方法(你不用就修改下)ent的AddToSomeSpace,参数里面加上空间的名字即可加到对应空间具体可见:http://blog.sina.com.cn/s/blog_69e8fdf00100zv4r.html
发表于 2011-10-28 23:13:30 | 显示全部楼层
  1.     '''
  2.     ''' 向任意空间添加多个对象
  3.     '''
  4.     '''
  5.     '''
  6.     '''
  7.     '''
  8.     Public Function AppendEntity(ByVal Ents() As Entity, ByVal LayoutName As String) As ObjectId()
  9.         Dim rtnIDs(Ents.Length - 1) As ObjectId
  10.         Using Trans As Transaction = DB.TransactionManager.StartTransaction
  11.             Dim DictLy As DBDictionary = Trans.GetObject(DB.LayoutDictionaryId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead)
  12.             If DictLy.Contains(LayoutName) = False Then
  13.                 For I As Integer = 0 To rtnIDs.Length - 1
  14.                     rtnIDs(I) = ObjectId.Null
  15.                 Next
  16.                 Trans.Commit()
  17.                 Return rtnIDs
  18.             End If
  19.             Dim Lyid As ObjectId = DictLy.GetAt(LayoutName)
  20.             Dim Ly As Layout = Trans.GetObject(Lyid, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead)
  21.             Dim BTR As BlockTableRecord = Trans.GetObject(Ly.BlockTableRecordId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
  22.             Dim Ent As Entity = Nothing
  23.             For I As Integer = 0 To Ents.Length - 1
  24.                 Ent = Ents(I)
  25.                 rtnIDs(I) = BTR.AppendEntity(Ent)
  26.                 Trans.AddNewlyCreatedDBObject(Ent, True)
  27.             Next
  28.             Trans.Commit()
  29.         End Using
  30.         Return rtnIDs
  31.     End Function
GMT+8, 2025-5-3 17:47 , Processed in 0.173346 second(s), 23 queries , Gzip On.
