查看: 4237|回复: 3
读取属性块出现的问题??
发表于 2011-10-20 17:06:38 | 显示全部楼层 |阅读模式
using System;
using System.Collections.Generic;
using System.Text;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.DatabaseServices;
namespace MyApplication
    class DumpAttributes
        [CommandMethod("LISTATT")]
        public void ListAttributes()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            Database db = HostApplicationServices.WorkingDatabase;
            Transaction trans = db.TransactionManager.StartTransaction();
            try
                TypedValue[] filList = new TypedValue[1];
                filList[0] = new TypedValue((int)DxfCode.Start, "Insert");
                SelectionFilter filter = new SelectionFilter(filList);
                PromptSelectionOptions opts = new PromptSelectionOptions();
                opts.MessageForAdding = "Select block references:";
                PromptSelectionResult res = ed.GetSelection(opts, filter);
                if (res.Status != PromptStatus.OK)
                    return;
                SelectionSet selSet = res.Value;
                ObjectId[] idArray = selSet.GetObjectIds();
                foreach (ObjectId blkId in idArray)
                    BlockReference blkRef = (BlockReference)trans.GetObject(blkId, OpenMode.ForRead);
                    BlockTableRecord btr = (BlockTableRecord)trans.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead);
                    ed.WriteMessage("\nBlock:" + btr.Name);
                    btr.Dispose();
                    AttributeCollection attCol = blkRef.AttributeCollection;
                    foreach (ObjectId attId in attCol)
                        AttributeReference attRef = (AttributeReference)trans.GetObject(attId, OpenMode.ForRead);
                        string str = ("\n Attribute Tag:" + attRef.Tag + "\n Attribute String" + attRef.TextString);
                        ed.WriteMessage(str);
                        trans.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                ed.WriteMessage(ex.Message);
            finally
                trans.Dispose();
对象的当前状态使该操作无效。为什麽??
发表于 2011-10-21 17:49:11 来自手机 | 显示全部楼层
屏蔽btr.dispose试试
 楼主| 发表于 2011-10-23 16:35:38 | 显示全部楼层
还是不行;
还是出现同样的问题。还是谢谢你的回答!
发表于 2011-10-25 16:29:58 | 显示全部楼层
解决了吗,把 trans.Commit();放在循环外面试试,我也不是很明白
GMT+8, 2025-5-3 17:25 , Processed in 0.150960 second(s), 27 queries , Gzip On.
