查看: 2729|回复: 4
高手请进,求助
发表于 2011-10-19 22:15:53 | 显示全部楼层 |阅读模式
[指定圆批量替换半径]
我想实现:敲入命令后,点取要被替换的圆(自动读取其半径,紧接着提示输入要的半径值,接着可框选对象,实现只将该半径的圆替换为输入的半径,而不改变其它半径的圆(而且不会修改圆弧,只修改圆)!
以下是[简易批量替换圆半径]的源码,请教高手,如果要改成具备上述功能的源码,应如何修改,先行谢过!!
(Defun c:cr ()
(command "redraw")
(command "undo" "begin")
(setq pbx (getvar "pickbox"))
(setvar "pickbox" 3)
(setq ucsfl (getvar "ucsfollow"))
(setvar "ucsfollow" 0)
(command "ucs" "world")   ;转到世界坐标系
( setq R (getreal "\ninput R ")) ;输入圆半径
(setq fil (ssget))   ;选择圆
(setq len (sslength fil))  ;确定选中圆的个数
(setq n 0)
(while (<= n (- len 1))
   (setq e (ssname fil n))
   (setq ed (entget e))
   (setq b nil) (setq c nil)
   (if (/= "CIRCLE" (cdr (assoc 0 ed)))
    (setq n (+ 1 n))
     (setq R0 (cdr (assoc 40 ed))) ;old circle's radius
     (setq pt0 (cdr (assoc 10 ed))) ;old circle's center
     (setq ed (subst (cons 40 R) (assoc 40 ed) ed))
     (setq n (+ 1 n))
     (entmod ed)
(command "zoom" "c" pt0 "15")  ;可调整该数字以适应不同半径的圆
     (setq ang 0)
     (while (< ang (* 2 pi))
      (setq pt1 (polar pt0 ang R0))
      (setq ang (+ ang (/ pi 30)))
      (setq pt2 (osnap pt1 "endp"))
      (setq b (cons pt2 b))
(setq ln (length b))
(setq lnn (- ln 1))
(setq i 0)
(setq pt (nth i b))
(while (<= i lnn)
  (setq pt (nth i b))
  (setq j (+ i 1))
  (setq jt (nth j b))
  (while (and (not (equal pt jt)) (< j lnn))
    (setq qt (nth j b))
    (setq j (+ 1 j))
    (setq jt (nth j b))
  (if (not (equal pt jt)) (setq c (cons pt c)))
  (setq i (+ 1 i))
  (setq k 0)
  (setq L (length c))
  (while (<= k (- L 1))
    (setq pt (nth k c))
       (if (> R0 R)
          (command "extend" e "" pt "")
          (command "trim" e "" pt "")
    (setq k (+ 1 k))
   );while结束
(command "ucs" "p")   ;返回用户坐标系
(setvar "ucsfollow" ucsfl)
(setvar "pickbox" pbx)
(command "undo" "end")
发表于 2011-10-20 10:50:11 | 显示全部楼层
首先声明俺也是菜鸟,不是高手!简单回答一下你的问题,其实不用这么多语句的程序,另写一个也不麻烦!下面是我按你的要求写的程序,希望能帮到你!
  1. (defun c:cr()
  2.   (setq oldobj (entsel "\n请选择要改变半径的对象:"))
  3.   (setq newrad (getreal"\n请输入新的半径值:"))
  4.   (setq oldobjlst (entget (car oldobj)))
  5.   (setq oldrad (cdr (assoc '40 oldobjlst)))
  6.   (setq oldradlst (assoc '40 (entget (car oldobj))))
  7.   (setq ss (ssget (list '(0 . "circle") oldradlst)))
  8.   (setq n 0)
  9.   (repeat (sslength ss)
  10.     (setq ss_n (ssname ss n))
  11.     (setq ss_n_lst (entget ss_n))
  12.     (setq newradlst (cons 40 newrad))
  13.     (setq ss_n_lst (subst newradlst oldradlst ss_n_lst))
  14.     (entmod ss_n_lst)
  15.     (setq n (1+ n))
  16.   )
  17.   (princ)
  18. )
发表于 2011-10-20 15:36:51 | 显示全部楼层
zyhandw 发表于 2011-10-20 10:50
首先声明俺也是菜鸟,不是高手!简单回答一下你的问题,其实不用这么多语句的程序,另写一个也不麻烦!下面 ...
非常感谢你,好东西啊!找了好久了。
 楼主| 发表于 2011-10-20 22:58:10 | 显示全部楼层
楼主真的吗?你还说您是菜鸟,海,现在的高手都这般谦虚!在下真的实在佩服啊!!不多说了,先试下效果,万分感激溢于言表
发表于 2011-10-22 10:30:38 | 显示全部楼层
大家共同探讨、进步!!
GMT+8, 2025-5-25 06:19 , Processed in 0.178633 second(s), 27 queries , Gzip On.
