帖子
查看: 2424|回复: 2
如何把一个实体放入系统剪贴板
发表于 2011-10-17 15:07:23 | 显示全部楼层 |阅读模式
如何把一个实体放入系统剪贴板
发表于 2011-10-17 18:43:55 | 显示全部楼层
' Demonstrates SetData, ContainsData, and GetData
' using a custom format name and a business object.
Public ReadOnly Property TestCustomFormat() As Customer
    Get
        Clipboard.SetData("CustomerFormat", New Customer("Customer Name"))
        If Clipboard.ContainsData("CustomerFormat") Then
            Return CType(Clipboard.GetData("CustomerFormat"), Customer)
        End If
        Return Nothing
    End Get
End Property
<Serializable()> Public Class Customer
    Private nameValue As String = String.Empty
    Public Sub New(ByVal name As String)
        nameValue = name
    End Sub
    Public Property Name() As String
        Get
            Return nameValue
        End Get
        Set(ByVal value As String)
            nameValue = value
        End Set
    End Property
End Class
 楼主| 发表于 2011-10-17 20:41:59 | 显示全部楼层
' using a custom format name and a business objec ...
我一点也看不出您是如何把一个实体放入系统剪贴板的。请您举个例子,例如把一条直线对象放入系统剪贴板,然后到一个打开的dwg文档中去粘贴一下看看,看是否真的把这一直线对象通过编程放入了系统剪贴板。
GMT+8, 2025-7-5 15:55 , Processed in 0.171918 second(s), 23 queries , Gzip On.
