帖子
查看: 2598|回复: 2
改变选择集对象的图层属性
发表于 2011-10-11 21:17:04 | 显示全部楼层 |阅读模式
private void button2_Click(object sender, EventArgs e)
            Microsoft.VisualBasic.Interaction.AppActivate(AcadApp.Caption);
            AcadSelectionSet mySelectionSet;
            string myset = "NewSelectionSet1";
            mySelectionSet = AcadDoc.SelectionSets.Add(myset);
            Int16[] FilterType = new Int16[1];
            object[] FilterData = new object[1];
            FilterType[0] = 62;
            FilterData[0] = "256";
            double[] p1 = new double[3] { 0, 0, 0 };
            double[] p2 = new double[3] { 86000, 60600, 0 };
            mySelectionSet.Select(AcSelect.acSelectionSetAll, p1, p2, FilterType, FilterData);
            int t = mySelectionSet.Count;
            object[] obj = new object[mySelectionSet.Count];
            label1.Text = t.ToString();
            for (int i = 0; i <= t - 1; i++)
                T1.Text += mySelectionSet.Item(i).Document.ToString() + "\t" + "\n";
                T1.Text += mySelectionSet.Item(i).ObjectName.ToString() + "\n";
                label2.Text = mySelectionSet.Item(i).OwnerID.ToString();
                mySelectionSet.Highlight(true);
                …………………………//实现改选择集中对象的所在图层
            AcadDoc.SelectionSets.Item(myset).Delete();
该贴已经同步到 思行合一的微博
发表于 2011-10-11 23:49:39 | 显示全部楼层
VBA/VB/ActiveX/API 编程技术 这个版块或许更适合你
 楼主| 发表于 2011-10-12 12:03:38 | 显示全部楼层
为什么?朋友
GMT+8, 2025-7-12 17:58 , Processed in 0.164258 second(s), 23 queries , Gzip On.
