查看: 3477|回复: 3
我用C#平时都是针对当前活动文档a.dwg作业,此时如何向一个非活动文档b.dwg中画一个圆
发表于 2011-10-10 08:10:15 | 显示全部楼层 |阅读模式
发表于 2011-10-10 20:47:32 | 显示全部楼层
帮你顶一下,我也想学会。
谢谢!
发表于 2012-4-2 22:46:34 | 显示全部楼层
同顶呀。有谁知道如何利用DWGDirect或DWGDirectX呀?这两个控件能够做到楼主的功能,可以谁有具体的教程呀
发表于 2012-4-6 08:52:08 | 显示全部楼层
      <CommandMethod("ABCD")> _
        Public Sub ABCD()
            Dim docs As DocumentCollection = Application.DocumentManager
            Dim doc As Document = Nothing
            For I As Integer = 0 To docs.Count - 1
                doc = docs(I)
                Dim NameStr As String = doc.Name
                NameStr = NameStr.Substring(NameStr.LastIndexOf("\") + 1)
                If NameStr = "b.dwg" AndAlso doc.IsActive = False Then
                    Using objDocLock As DocumentLock = doc.LockDocument
                        Using objTrans As Transaction = doc.Database.TransactionManager.StartTransaction
                            Dim BlkTbl As BlockTable = objTrans.GetObject(doc.Database.BlockTableId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead)
                            Dim BlkTblRec As BlockTableRecord = objTrans.GetObject(BlkTbl(BlockTableRecord.ModelSpace), Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
                            Dim acCirc As Circle = New Circle(New Point3d(0, 0, 0), Vector3d.ZAxis.GetNormal, 3)
                            BlkTblRec.AppendEntity(acCirc)
                            objTrans.AddNewlyCreatedDBObject(acCirc, True)
                            objTrans.Commit()
                        End Using
                    End Using
                End If
            Next
        End Sub
用VB写了个,已经测试通过,凑合看看吧
GMT+8, 2025-5-3 03:42 , Processed in 0.200462 second(s), 28 queries , Gzip On.
