查看: 3023|回复: 1
C#打印程序出错,是在AUTOCAD开发手册上操的。
发表于 2011-10-8 21:31:35 | 显示全部楼层 |阅读模式
C#打印程序出错,是在AutoCAD开发手册上操的。这是我做的一个批量打印程序,打印那一块全是在手册上操的。编译没问题,运行的时候有三行代码发生异常,且这三行代码都是原封不动从手册上操的。改来改去也没搞懂什么原因。请各位大侠指教!万分感谢!
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.PlottingServices;
namespace AllBlock
    public class Class1
        //public void Init()
            public static Document doc = Application.DocumentManager.MdiActiveDocument;
            public static Database db = doc.Database;
            public static Editor ed = doc.Editor;
        [CommandMethod("ba")]
        public void ba()
            //Init();
            TypedValue[] tv = new TypedValue[1];
            tv.SetValue(new TypedValue((int)DxfCode.BlockName, "a4"),0);
            // 赋值过滤条件给 SelectionFilter 对象    Assign the filter criteria to a SelectionFilter object
            SelectionFilter acSelFtr = new SelectionFilter(tv);
            // 要求在图形区域中选择对象    Request for objects to be selected in the drawing area
            PromptSelectionResult acSSPrompt = ed.SelectAll(acSelFtr);
            // 如果提示状态是 OK,对象就被选择了    If the prompt status is OK, objects were selected
            if (acSSPrompt.Status == PromptStatus.OK)
                SelectionSet acSSet = acSSPrompt.Value;
                Application.ShowAlertDialog("Number of objects selected: " +acSSet.Count.ToString());
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    foreach (SelectedObject sobj in acSSet)
                        BlockReference bref = tr.GetObject(sobj.ObjectId, OpenMode.ForRead) as BlockReference;
                        ed.WriteMessage("\n块的名称是: " + bref.Name);
                        ed.WriteMessage("\n块的插入位置是:  "+ bref.Position.ToString());
                        Extents3d exSize = bref.GeometricExtents;
                        Point2d pStart = Point3dToPoint2d(exSize.MinPoint);
                        Point2d pEnd = Point3dToPoint2d(exSize.MaxPoint);
                        ed.WriteMessage("\n块的大小是: 长{0},宽{1}", pEnd.X-pStart.X,pEnd.Y-pStart.Y);
                        ed.WriteMessage("\n块的旋转角度是: " + bref.Rotation * 180 / 3.1415926);
                        int a = Plot(pStart, pEnd, 0, 3);
            else
                Application.ShowAlertDialog("Number of objects selected: 0");
        private int Plot(Point2d pMin, Point2d pMax, int angle, int size)
                //设置布局管理器为当前布局管理器
                LayoutManager layoutMan = LayoutManager.Current;
                //取得当前布局
                Layout currentLayout = tr.GetObject(layoutMan.GetLayoutId(layoutMan.CurrentLayout),
                    OpenMode.ForRead) as Layout;
                //从布局获取打印信息
                PlotInfo pi = new PlotInfo();
                pi.Layout = currentLayout.ObjectId;
                //从布局获取一个PlotSetting的副本
                PlotSettings ps = new PlotSettings(currentLayout.ModelType);
                ps.CopyFrom(currentLayout);
                //升级PlotSetting对象
                PlotSettingsValidator psv = PlotSettingsValidator.Current;
                //设置打印范围
                Extents2d exWin = new Extents2d(pMin, pMax);
                psv.SetPlotWindowArea(ps, exWin);
                psv.SetPlotType(ps,Autodesk.AutoCAD.DatabaseServices.PlotType.Window);
                //设置打印比例,设置为布满图纸
                psv.SetUseStandardScale(ps, true);
                psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
                //设置居中打印
                psv.SetPlotCentered(ps,true);
                //设置打印设备
                ed.WriteMessage("[url=]\\\\work14\\canon_ip1100_series[/url]");
                psv.SetPlotConfigurationName(ps, "[url=]\\\\work14\\canon[/url] ip1100 series", "A4");
                //重写覆盖打印信息
                pi.OverrideSettings = ps;
                //确认打印信息
                PlotInfoValidator piVdr = new PlotInfoValidator();
                piVdr.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;    //允许匹配颜色
                piVdr.Validate(pi);
                //检查打印状态
                if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
                    //开启打印引擎
                    using (PlotEngine pe = PlotFactory.CreatePublishEngine())
                        //通过一个进程对话框追踪打印进程
                        PlotProgressDialog plDialog = new PlotProgressDialog(false, 1, true);
                        using (plDialog)
                            // Define the status messages to display when plotting starts
                            //定义打印开始时显示的状态信息
                            plDialog.set_PlotMsgString(PlotMessageIndex.DialogTitle, "Plot Progress");
                            plDialog.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage, "Cancel Job");
                            plDialog.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage, "Cancel Sheet");
                            plDialog.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption, "Sheet Set Progress");
                            plDialog.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption, "Sheet Progress");
                            // Set the plot progress range
                            //设置打印进程等级
                            plDialog.LowerPlotProgressRange = 0;        //最低等级为0级
                            plDialog.UpperPlotProgressRange = 100;      //最高等级为100级
                            plDialog.PlotProgressPos = 0;
                            // Display the Progress dialog              //显示进程对话框
                            plDialog.OnBeginPlot();
                            plDialog.IsVisible = true;
                            // Start to plot the layout                 //开始打印布局
                            pe.BeginPlot(plDialog, null);
                            // Define the plot output
                            //acPlEng.BeginDocument(pi, acDoc.Name, null, 1, true, "c:\\myplot");
                            // Display information about the current plot
                            //显示当前打印相关信息
                            plDialog.set_PlotMsgString(PlotMessageIndex.Status, "Plotting: " + doc.Name + " - " + currentLayout.LayoutName);
                            // Set the sheet progress range
                            //设置图纸进程等级
                            plDialog.OnBeginSheet();
                            plDialog.LowerSheetProgressRange = 0;
                            plDialog.UpperSheetProgressRange = 100;
                            plDialog.SheetProgressPos = 0;
                            // Plot the first sheet/layout
                            //打印第一个视口
                            try
                                PlotPageInfo ppInfo = new PlotPageInfo();
                                pe.BeginPage(ppInfo, pi, false, "ADASF");  ////这行出问题
                                pe.BeginGenerateGraphics(null);
                                pe.EndGenerateGraphics(null);
                            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                                Application.ShowAlertDialog(ex.Message);
                            // Finish plotting the sheet/layout
                            //完成打印视口
                            pe.EndPage(null);      //这行也出问题
                            plDialog.SheetProgressPos = 100;
                            plDialog.OnEndSheet();
                            // Finish plotting the document
                            //完成文档打印
                            pe.EndDocument(null);
                            // Finish the plot
                            //完成打印操作
                            plDialog.PlotProgressPos = 100;
                            plDialog.OnEndPlot();
                            pe.EndPlot(null);      //这行也出错
            return 0;
        public Point2d Point3dToPoint2d(Point3d p3d)
            Point2d p2d = new Point2d(p3d.X, p3d.Y);
            return p2d;
 楼主| 发表于 2011-10-12 21:31:57 | 显示全部楼层
没有人愿意看看吗?
GMT+8, 2025-6-1 16:27 , Processed in 0.170706 second(s), 23 queries , Gzip On.
