查看: 2251|回复: 3
如何使用Jigs动态旋转实体?
发表于 2011-9-29 08:02:19 | 显示全部楼层 |阅读模式
用了置顶里的方法
public void RotateEntity()
      Document doc =
        Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      Database db = doc.Database;
      // First we prompt for the entity to rotate
      PromptEntityOptions peo =
        new PromptEntityOptions(
          "\nSelect entity to rotate: "
      PromptEntityResult per =
        ed.GetEntity(peo);
      if (per.Status == PromptStatus.OK)
        Transaction tr =
          db.TransactionManager.StartTransaction();
        using (tr)
          DBObject obj =
            tr.GetObject(per.ObjectId, OpenMode.ForRead);
          Entity ent = obj as Entity;
          // Use the origin as the default center
          Point3d rotationPoint = Point3d.Origin;
          // If the entity is a polyline,
          // assume it is rectangular and then
          // set the rotation point as its center
          Polyline pl = obj as Polyline;
          if (pl != null)
            LineSegment3d ps0 =
              pl.GetLineSegmentAt(0);
            LineSegment3d ps1 =
              pl.GetLineSegmentAt(1);
            Vector3d vec =
              ((ps0.EndPoint - ps0.StartPoint) / 2.0) +
              ((ps1.EndPoint - ps1.StartPoint) / 2.0);
            rotationPoint = pl.StartPoint + vec;
          // Get the base rotation angle stored with the
          // entity, if there was one (default is 0.0)
          double baseAngle = GetStoredRotation(obj);
          if (ent != null)
            // Get the current UCS, to pass to the Jig
            Matrix3d ucs =
              ed.CurrentUserCoordinateSystem;
            // Create our jig object
            RotateJig jig =
              new RotateJig(
                ent,
                rotationPoint,
                baseAngle,
                ucs
            PromptResult res = ed.Drag(jig);
            if (res.Status == PromptStatus.OK)
              // Get the overall rotation angle
              // and dispose of the temp clone
              double newAngle = jig.GetRotation();
              jig.GetEntity().Dispose();
              // Rotate the original entity
              Matrix3d trans =
                Matrix3d.Rotation(
                  newAngle - baseAngle,
                  ucs.CoordinateSystem3d.Zaxis,
                  rotationPoint);
              ent.UpgradeOpen();
              ent.TransformBy(trans);
              // Store the new rotation as XData
              SetStoredRotation(ent, newAngle);
          tr.Commit();
但没有动态旋转效果,并且运行到ent.UpgradeOpen() 就退出了,我的实体是一个块图形
 楼主| 发表于 2011-9-29 15:21:04 | 显示全部楼层
没人知道么,谁有成功的例子啊?
 楼主| 发表于 2011-9-29 16:54:14 | 显示全部楼层
问下置顶里Jigs动态旋转实体是跟随鼠标移动而旋转么?
 楼主| 发表于 2011-9-29 17:10:57 | 显示全部楼层
为什么用RECTANG创建的矩形就可以,块图形就不行了呢,求高手帮帮忙啊!!!
GMT+8, 2025-5-3 17:53 , Processed in 0.171099 second(s), 24 queries , Gzip On.
