查看: 6597|回复: 4
LISP函数功能英文翻译
发表于 2011-9-26 23:39:51 | 显示全部楼层 |阅读模式
http://space.mjtd.com/blog-8218-35.html这篇文章里提到很多常用的LISP函数,但文章全是英文,无法阅读,麻烦哪位功能深厚的大师翻译一下,大家共享资源.谢谢!
发表于 2011-9-27 15:55:20 | 显示全部楼层
对lisp还在了解中   函数备注说明不清,无图表说明 很难译 期待大师的出现 阐述所有函数的用法
[3.3] You may include break functions and debug print into your source
打断函数及调试打印到文档
;;;; code.代码
;;;;[15] How can I pass a variable number of arguments to a lisp function?
LISP函数可变量参数
[16] How can I avoid stack overflows?
怎样避免数据溢出
[20] general Helper functions
DXF  - return the DXF group code of an (entget) list
一般帮助函数,DXF  返回DXF组代码清单
21.6] (vports), VIEWPORT entity, pixel conversion
VPORTS函数:实体窗口,像素转换
Conversion pixel to drawing units
像素转换成图元单位
21.7] Select all visible objects: zoom coordinates
;;; returns a list of the actual viewport corners in WCS
可见实体的选择,在WCS坐标系返回当前窗口实体清单
[21.8] How to write XYZ data of selected objects to a file?
怎样提取选择实体XYZ坐标到文件
;;; CDF - comma delimited string 逗号分隔字符
[22] Block Attributes块属性
;;; ATTELE  - returns entget-list of attribute attname (STRING) in element
Attele 返回块属性清单
;;; ele or nil if not found未找到返回零
23] Polylines多义线
;;; return only some assoc values in the list (for LWPOLYLINE)
返回有效值(可能是所有属性的意思吧)
[24] Circle/Arc Geometry: BULGE conversion, some trigonometry
圆/弧:  弓形变换及三角转换
;;; SEG2CIR - converts a bulged segment (bulge pt1 pt2) of a polyline
;;;   to a circle (ctr rad), the start- and endpoints are known圆起点终点已知
;;;   therefore the angles too: (angle ctr pt1)(angle ctr pt2)因此角度也已知:及pt1、pt2圆心角
;;; returns nil on a straight segment!返回直线段长度(不知道是不是这个意思,没有测试这个函数股价segment应该是指圆弧上起点终点的连线)
 楼主| 发表于 2011-9-27 17:01:05 | 显示全部楼层
辛苦了..谢谢.请继续翻译完.有用的以后就可以用了
发表于 2011-12-15 09:34:39 | 显示全部楼层
;;;; FAQ-CODE.LSP
;;;; Code from the comp.cad.autocad AutoLISP FAQ
;;;; (c) 1991-1997 Reini Urban
;;;; This code may only be redistributed together with the FAQ document.
;;;; The FAQ may be freely redistributed in its entirety without
;;;; modification provided that this copyright notice is not removed. It
;;;; may not be sold for profit or incorporated in commercial documents
;;;; (e.g. published for sale on CD-ROM, floppy disks, books, magazines,
;;;; or other print form) without the prior written permission of the
;;;; copyright holder. Permission is expressly granted for this document
;;;; to be made available for file transfer from installations offering
;;;; unrestricted anonymous file transfer on the Internet and to be
;;;; included into the official AutoCAD FAQ.
;;;; These functions are, if not otherwise stated, (c) 1991-97
;;;; by Reini Urban and may be freely used. If you include some of those
;;;; functions in your code, you have to add a short line if you intend
;;;; to ship source code or a seperate document to your program where to
;;;; find the FAQ and this code.
;;;; This code is provided AS IS without any expressed or implied warranty.
;;;; If you intentionally got this copy without the FAQ, get the FAQ at
;;;;   http://xarch.tu-graz.ac.at/autocad/...q/autolisp.html
;;;; These are some basic AutoLISP functions to make life, faq-writing
;;;; and posting news-answers easier. For more see /autocad/stdlib/
;;;; Last update: 6.Dec 99
;;;; Version 2.2     13.Jul 99                    renamed ssapply to ssmap
;;;; Version 2.0     11.May 98                    fixed: arc2bul, ddecmd, tan
;;;; Version 1.10    22.July 97                   LWPOLYLINE support and fixes
;;;; Version 1.9     26.June 97                   pline-segs, ddecmd, getval
;;;; Version 1.8     15.May 97                    R14 fixes, ssapply
;;;; Version 1.71    7.May 97                     added (dxf)
;;;; [3.3] You may include break functions and debug print into your source
;;;;       code.中断函数和打印你的代码
;;; Debugging functions调试函数
(defun break (s)
  (if *BREAK*
      (princ "BREAK>> (stop with )\nBREAK>> ")
      (princ s)
      (while (/= (setq s (getstring "\nBREAK>> ")) "")
        (print (eval (read s)))
)                                        ;bugfix from v1.3!
(defun dbg-print (s)                        ;accepts atoms and lists接受原子和列表
  (if *DEBUG*
    (if        (listp s)
      (mapcar 'print s)
      (print s)
(defun C:DEBUG () (setq *DEBUG* (not *DEBUG*))) ;switch it on and off
(defun C:BREAK () (setq *BREAK* (not *BREAK*)))
(defun CONT () (setq *BREAK* nil))        ;cont. without any interruption
;;; MY-PRINC  - print a variable number of arguments (of any type)
;;;打印表中各元素;如果不是表,则打印它本身
(defun my-princ        (x)
  ;; simple version, for better stuff look at the SDK2: PRINTF.LLB
  (if (listp x)
    (mapcar 'princ x)
    (princ x)
;;;; [16] How can I avoid stack overflows?
;;; INTLST  - create '(0 1 2 ... n)
;;;产生从0到n的表
(defun intlst (n / l)
  (repeat n
    (setq l (cons (setq n (1- n)) l))
)                                        ;this looks ugly but it works
;;;; [20] general Helper functions
;;; DXF  - return the DXF group code of an (entget) list
;;;示例(setq ele (entget (car (entsel))))拾取直线时(dxf 0 ele)返回"LINE"
(defun dxf (grp ele) (cdr (assoc grp ele)))
;;;; [20.1] List manipulation
;;; CONSP  - a not empty list测试x是否空表,返回T or nil
(defun consp (x) (and x (listp x)))
;;; POSITION - returns the index of the first element in the list,
;;;返回第一个元素在表中的索引号
;;; base 0, or nil if not found
;;;示例(position x '(a b c)) -> nil, (position b '(a b c d)) -> 1
(defun position        (x lst / ret)
  (if (not (zerop (setq ret (length (member x lst)))))
    (- (length lst) ret)
;;; REMOVE - Removes an item from a list (double elements allowed)
;;;从表中去除任何元素
;;;示例(remove 0 '(0 1 (0 1) 3 0)) -> (1 (0 1) 3)
;;;有了这个函数,vl-remove还拿来干什么?
(defun remove (ele lst)                        ; by Serge Volkov
  (apply 'append (subst nil (list ele) (mapcar 'list lst)))
;;; REMOVE-IF - Conditional remove from flat list,
;;; pred requires exactly 1 arg
;;;   (remove-if 'zerop '(0 1 2 3 0)) -> (1 2 3)
;;;   (remove-if 'numberp '(0 (0 1) "")) -> ((0 1) "")
;;;可能vl-remove-if就是这样写出来的吧,不然的话,为什么结果一样呢?
(defun remove-if (pred from)
  (cond
    ((atom from) from)                        ;nil or symbol (return that)
    ((apply pred (list (car from))) (remove-if pred (cdr from)))
    (t (cons (car from) (remove-if pred (cdr from))))
;;; REMOVE-IF-NOT  - keeps all elements to which the predicate applies
;;; say: "keep if", it need not be defined recursively, also like this
(defun remove-if-not (pred lst)                ; by Vladimir Nesterowsky
  (apply 'append
         (mapcar '(lambda (e)
                    (if        (apply pred (list e))
                      (list e)
                 lst
;;; ADJOIN - conses ele to list if not already in list
;;; trick: accepts quoted lists too, such as
;;;元素不在列表中,则加入之
;;;(setq l '(1 2 3))
;;;(adjoin 0 'l)->(0 1 2 3);(adjoin 0 l)->(0 1 2 3)
(defun adjoin (ele lst / tmp)
  (if (= (type lst) 'SYM)
    (setq tmp lst
          lst (eval tmp)
  (setq        lst (cond ((member ele lst) lst)
                  (t (cons ele lst))
  (if tmp
    (set tmp lst)
    lst
;;; ROT1 - put the first element to the end, simple version
;;;第一个元素放到最后
;;;        Say "rotate by one" or "rotate left"
(defun rot1 (lst) (append (cdr lst) (list (car lst))))
;;; BUTLAST - the list without the last element
;;;去除表中最后一个元素的表
(defun butlast (lst)
  (reverse (cdr (reverse lst)))
;;;; [20.2] string predicates
;;; STRINGP  - string predicate: "is s a string?"
;;;判断是否是字符串->T or nil
(defun stringp (s)
  (= (type s) 'STR)
;;; STRING-NOT-EMPTYP  - is str a not empty string?
;;;是否空字符串->T or nil
(defun string-not-emptyp (s)
  (and (stringp s) (/= s ""))
;;; for more list and string manipulation code see
;;; AI_UTILS.LSP or
;;; ftp://xarch.tu-graz.ac.at/pub/autocad/lisp/lisp.lsp and string.lsp
;;; or at http://xarch.tu-graz.ac.at/autocad/...estr/strtok.lsp
;;;; [20.3] symbol->string
;;; SYMBOL-NAME - returns the name of a symbol as string
;;; converts any valid lisp expression to its printed representation
;;;1示例(symbol-name 'a) -> "a";(symbol-name a) -> nil
;;;2示例(symbol-name '(0 1 2 a)) -> "(0 1 2 A)"
;;;我想是read的逆操作,直到遇到vl-prin1-to-string我才算解决,原来早就有了?
(defun symbol-name (sym / f str tmp)
  ;;执行完毕,搜索电脑,没有发现*sym.tmp
  ;;下句产生临时文件的方法是不是与vl-filename-mktemp相同呢?
  (setq tmp "$sym.tmp");temp. filename, should be deleted
  (setq f (open tmp "w"))
  (princ sym f)
  (close f)
  (setq        f   (open tmp "r")
        str (read-line f)
        f   (close f)
  str
;;;; [20.4] AutoCAD entity access
;;; GETVAL  - returns the group value of an entity.
;;; like the wellknown (dxf) function but accepts all kinds of
;;; entity representations (ename, entget list, entsel list)
;;;返回组码,与上面那个dxf相同,不过ele可以是图元,图元表,ensel返回值.
(defun GETVAL (grp ele)                        ;"dxf value" of any ent...
  (cond        ((= (type ele) 'ENAME)                ;ENAME
         (cdr (assoc grp (entget ele)))
        ((not ele) nil)                        ;empty value
        ((not (listp ele)) nil)                ;invalid ele
        ((= (type (car ele)) 'ENAME)        ;entsel-list
         (cdr (assoc grp (entget (car ele))))
        (T (cdr (assoc grp ele)))
)                                        ;entget-list
;;;使用示例如下(gettyp (entsel)) => "LINE"之类
(defun GETTYP (ele)                        ;return type
  (getval 0 ele)
;;; ENTITY  - assure ENAME确保返回值是图元
;;;ele可以是图元,图元表,ensel返回值
;;; convert the entity to type ENAME (to write shorter code)
(defun ENTITY (ele)                        ;convert to element name
  (cond                                        ;accepts the following types:
    ((= (type ele) 'ENAME) ele)                ; ENAME
    ((not (listp ele)) nil)                ; error: no list
    ((= (type (car ele)) 'ENAME) (car ele)) ; entsel-list
    ((cdr (assoc -1 ele)))                ; entget-list or nil
;;;and now just:
;;;见上面 dxf GETVAL,一样的使用法
(defun getval (grp ele)
  (cdr (assoc grp (entget (entity ele))))
;;;示例(istypep ele "TEXT"),is ele a "TEXT"?
(defun istypep (ele typ)                ;check type
  (= (gettyp ele) typ)
;;;示例(istypep ele '("TEXT" "ATTDEF")),is element a "TEXT" or a "ATTDEF"?
(defun ISTYPEP (ele typ)                ;better implementation to accept lists too
  (cond
    ((listp typ) (member (gettyp ele) typ))
    ((stringp typ) (= (gettyp ele) typ));assume typ uppercase, wcmatch is slower but neater
    (T nil)
;;;示例(getpt (entsel))  => ( 0.1 10.0 24)
;;;组码10是对象定位点
(defun GETPT (ele)                        ;return the startpoint of any element
  (getval 10 ele)
)                                        ;group 10
;;;示例(getflag (entsel))
;;;样条曲线SPLINE线闭合返回11;否则8
;;;多段线LWPOLYLINE线闭合返回1;否则0
(defun GETFLAG (ele) (getval 70 ele))        ;same with the entity flag
;;; FLAGSETP  - bitvalue val in flag of element set?
;;; Ex: (flagsetp 1 pline)   => T if closed
;;; Ex: (flagsetp 16 vertex) => T if spline control point
(defun FLAGSETP        (val ele)
  (bitsetp val (getflag ele))
;;; Ex: (bitsetp 4 12) => T   ;bitvalue 4 (=2.Bit) in 12 (=4+8) is set
(defun BITSETP (val flag)
  (= (logand val flag) val)
;;; SSLIST - 选择集=>列表
;;; Note: it's also wise to use ai_ssget, because some ents could be
;;;       on locked layers使用ai_ssget是明智的,因为有些实体在锁定层上
;;; Ex: (sslist (ai_ssget (ssget))) => list of selected unlocked ents
;;; or  (mapcar 'entupd (sslist (ssget "X" '((8 . "TEMP")))))
;;;       - regens all entities on layer TEMP
(defun SSLIST (ss / n lst)
  (if (= 'PICKSET (type ss))
    (repeat (setq n (sslength ss))
      (setq n        (1- n)
            lst        (cons (ssname ss n) lst)
;;; SSMAP - apply a function to each ent in ss, in reversed order
;;; Faster, but not so easy to understand. see [22.2] Datestamp
;;; [renamed from SSAPPLY to SSMAP to match the stdlib name]
;;; Ex: (ssmap 'entupd (ssget))   ; regenerate only some entities
(defun SSMAP (fun ss / n)
      (apply fun (list (ssname ss (setq n (1- n)))))
;;; backwards compatibility alias:
(setq ssapply ssmap)
;;; [21.2] Plot dialog from within Lisp. Using DDE
;;;  R13 code! For R12 use "autocad.dde" as the server name. Then, inside your lisp
;;;  or script, you can do (ddecmd "_plot "). Function DDECMD will return
;;;  nil if something wrong, or the string you passed if successful. The
;;;  string is just like what you type under the command prompt from
;;;  keyboard, so you need put a space or a return, which is "^13" here,
;;;  to end the string.
;;;  Besides, the function is very useful in the following situation: If
;;;  within a lisp, you need call an AutoCAD transparent command like
;;;  LAYER, normally you will use (command "_layer"), but after use this
;;;  line, the lisp own will not be transparent. Using the function, you
;;;  will solve this problem.
;;; [fixed for all releases]
(defun DDECMD (str / tmp acadver ddestr)
  (if (not (boundp 'initiate))
    (cond
      ((= 14 (setq acadver (atoi (getvar "ACADVER"))))
       (setq ddestr "AutoCAD.R14.DDE")
       (arxload "ddelisp")
      ((= 13 acadver)
       (setq ddestr "autocad.r13.dde")
       (xload "ddelisp")
      ((= 12 acadver)
       (setq ddestr "autocad.dde")
       (xload "ddelisp")
      (T (princ "DDE not supported") (exit))
  (if (not (zerop (setq tmp (initiate ddestr "system"))))
      (execute tmp (strcat "[" str "]"))
      (terminate tmp)
      str
;;; Visual Lisp Example:
  (setq vlax:ActiveDocument (vla-get-ActiveDocument (vlax-get-Acad-Object)))
  (setq plt (vla-get-plot vlax:ActiveDocument))   ;=> plot object
  (vla-PlotWindow plt pt1 pt2)                    ; define window (pts in WCS)
  (vla-PlotPreview plt 1)                         ; 0 for partial, 1 for full
  (vla-PlotToDevice plt "Default System Printer") ; if it exists
;;;; [21.3] (entmod) and (entmake) Layers, without (command "_LAYER"...)
;;; This sample routine will create a layer with any name you type:
;;; by Reinaldo Togores
(defun C:MLAY ()
  (setq laynam (getstring "\nLayer name: "))
  (entmake
    (list
      '(0 . "LAYER")
      '(5 . "28")
      '(100 . "AcDbSymbolTableRecord")
      '(100 . "AcDbLayerTableRecord")
      (cons 2 laynam)
      '(70 . 64)
      '(62 . 7)
      '(6 . "CONTINUOUS")
;;;; [21.6] (vports), VIEWPORT entity, pixel conversion
;;; Conversion pixel to drawing units
(defun pix2units (pix)
  (* pix (/ (getvar "VIEWSIZE") (cadr (getvar "SCREENSIZE"))))
;;; Conversion drawing units to pixel
(defun units2pix (units)
  (* units
     (/ (cadr (getvar "SCREENSIZE")) (getvar "VIEWSIZE"))
;;;;[21.7] Select all visible objects: zoom coordinates
(defun zoompts (/ ctr h screen ratio size size_2)
  (setq        ctr    (xy-of (getvar "VIEWCTR")) ;3D -> 2D
        h      (getvar "VIEWSIZE")        ;real
        screen (getvar "SCREENSIZE")        ;2D: Pixel x,y
        ratio  (/ (float (car screen))        ;aspect ratio
                  (cadr screen)
        size   (list (* h ratio) h)        ;screensize in coords
        size_2 (mapcar '/ size '(2.0 2.0))
  (list        (mapcar '- ctr size_2)
        (mapcar '+ ctr size_2)
(defun xy-of (pt) (list (car pt) (cadr pt))) ;assure 2D coords
;;; returns all visible entities as a selection set
;;; one way to define this function
(defun ssall-visible (/ l)
  (ssget "C" (car (setq l (maptrans0-1 (zoompts)))) (cadr l))
;;; or another
(defun ssall-visible-1 ()                ;combine "C" and (p1 p2) to one list
  (apply 'ssget (append '("C") (maptrans0-1 (zoompts))))
;;; map some pts from WCS to UCS, easier with just one argument
(defun maptrans0-1 (pts)
  (mapcar '(lambda (pt) (trans pt 0 1)) pts)
;;;; [21.8] How to write XYZ data of selected objects to a file?
(defun cdf-point (pt)
  (strcat (car pt) ", " (cadr pt) ", " (caddr pt))
;;; SDF - space delimited, may easier be read back in to AutoCAD
(defun sdf-point (pt)
  (strcat (car pt) " " (cadr pt) " " (caddr pt))
;;; convert this SDF format back to a point with
(defun str->point (s)
  (eval (read (strcat "(" s ")")))
;;; Write a XYZ file of all selected objects (SDF see below)
(defun C:XYZ (/ ss fname f)
  (if (and (setq ss (ssget))
           (setq fname (getfiled "Write XYZ to file"
                                 (strcat (getvar "DWGNAME") ".XYZ")
                                 "XYZ"
                                 7
           (setq f (open fname "w"))
    (foreach ele (sslist ss)                ; -> [20.4]
      (foreach pt (getpts ele)                ; -> [23.1]
        (write-line (cdf-point pt) f)
  (if f
    (close f)
;;; => .xyz
;;; 0.45, 12.3, -34.0
;;; For a ASC file (SDF-format) simply change all XYZ to ASC
;;; and cdf-point to sdf-point above.
(defun C:ASC (/ ss fname f)
           (setq fname (getfiled "Write ASC to file"
                                 (strcat (getvar "DWGNAME") ".ASC")
                                 "ASC"
                                 7
        (write-line (sdf-point pt) f)
  (if f
    (close f)
;;;; [22] Block Attributes
(defun attele (ele attname / rslt)
  (if (and (istypep ele "INSERT")
           (= (getval 66 ele) 1)
      (setq ele (entnext (entity ele)))
      (while (and ele (istypep ele "ATTRIB"))
        (if (= (strcase (getval 2 ele)) (strcase attname))
          (setq        rslt (entget ele)
                ele  nil
          )                                ;break the loop
          (setq ele (entnext ele))
  rslt
;;; ATTCHG  - change the attribute value of INSERT ele to new (group 1)
(defun attchg (ele attname new / b)
  (if (setq b (attele ele attname))
    (entmod (subst (cons 1 new) (getval 1 b) b))
;;; Change all DATESTAMP attributes in all inserted PLOT* blocks
(defun C:DATESTAMP ()
  (ssmap
    '(lambda (ele)
       (attchg ele "DATESTAMP" (today))
       (entupd ele)
    (ssget "X" '((0 . "INSERT") (2 . "PLOT*")))
;;; TODAY  - return todays date, could be a DIESEL or this string conversion
;;; with DIESEL it's easier to define it according your format (i.e day of week)
(defun today (/ s)
  (setq s (rtos (getvar "CDATE") 2))        ;gets the julian date
  (strcat (substr s 5 2)
          (substr s 7 2)
          (substr s 3 2)
;;; MAIN-ENTITY - some more helper funcs to get the main entity of any attribute
;;; or vertex
(defun main-entity (ele)
  (setq b (entity b))                        ;force ENAME
  (while (istypep b '("ATTRIB" "ATTDEF" "VERTEX"))
    (setq b (entnext b))
  )                                        ;loop until no more sub-ents
  (if (istypep b '("SEQEND" "ENDBLK"))
    (getval -2 b)                        ;complex entity -> header
    b                                        ;normal entity
;;;; [23] Polylines
(defun GROUP-ONLY (grp lst)
  (mapcar 'cdr
          (remove-if-not '(lambda (pair) (= grp (car pair))) lst)
;;; return the vertex list of a polyline or of any other element
;;; Note that with edlgetent mentioned in [22.1] it's a one-liner
(defun GETPTS (ele / pts)
  (setq ele (entity ele))                ;force type ENAME
  (cond
    ((istypep ele "POLYLINE")
     (while (istypep (setq ele (entnext ele)) "VERTEX")
       ;; omit fit and spline points  (conservative style)
       (if (not (or (flagsetp 1 ele) (flagsetp 8 ele))) ;bugfix!
         (setq pts (cons (trans (getpt ele) ele 0) pts))
       (reverse pts)
    ;; Special case: you have to map it, assoc finds only the first.
    ;; Fix a LWPOLYLINE bug in R14: internally stored as 2d point,
    ;;   (entget) returns fantasy z-values.
    ((istypep ele "LWPOLYLINE")
     (mapcar '(lambda (pt) (trans (list (car pt) (cadr pt) 0.0) ele 0))
             (group-only 10 (entget ele))
    ;; insert here possible other types, such as
    ((istypep ele '("TEXT" "CIRCLE")) (list (getpt ele)))
    ;; more like this (serge's style)
    (T
     (apply 'append
            (mapcar
              '(lambda (n / p)
                 (if (setq p (getval n ele))
                   (list p)
              '(10 11 12 13)
    ;; or like this (conservative style)
    ;;(T (foreach n '(10 11 12 13)
    ;;     (if (setq p (getval n ele)) (setq pts (cons p pts))))
    ;;  pts
;;; This sample converts all selected elements to polylines and
;;;  tries to join as much as possible.
(defun C:JOINPOLY (/ ele ss)
  (foreach ele (sslist (setq ss (ssget))) ;better process lists
    (if        (entget ele)                        ;not already joined
      (cond                                ;(then it would be nil)
        ((istypep ele '("ARC" "LINE"))
         ;; in fact you should check Z of lines and UCS here too
         (command "_PEDIT" ele "_Y" "_J" ss "" "") ; convert and JOIN
        ((and (istypep ele '("POLYLINE" "LWPOLYLINE")) ;bugfix
              (not (flagsetp 1 ele))        ;not closed
              (< (rem (getflag ele) 128) 8)
         )                                ;ignore meshes and such
         (command "_PEDIT" ele "_J" ss "" "") ;ucs check omitted
;;; Sets new polywidth for multiple plines
(defun C:POLYWID (/ wid ele)
  (initget 5)
  (setq wid (getdist "New Polyline Width: ")) ;not negative
  (foreach ele (sslist (ssget '((0 . "*POLYLINE")))) ;only PLINES
    (command "_PEDIT" ele "_W" wid "")
;;; Draws a POLYLINE entity from a list of points (same with SPLINE,
;;;  or LINE), on the actual UCS, with actual OSNAP settings
(defun draw-pline (pts)
  (command "_PLINE")
  (mapcar 'command pts)
  (command "")
(defun draw-spline (pts)
  (command "_SPLINE")
  (mapcar 'command pts)                        ; the pts must be the fitpoints then
  (command "" "" "")
;;; add up the LENGTH of all selected objects, NOISY, you can do the
;;; same with AREAs: simply change the last line to (getvar "AREA")
(defun C:LEN-OF        ()
  (command "_AREA" "_A" "_E")                ;add up objects (R12+13)
  (ssmap 'command (ssget))                ;pass all elements to AutoCAD
  (command "" "")                        ;two returns
  (getvar "PERIMETER")
)                                        ;this is the length
;;; calculates length of a pline, quiet
(defun POLY-LENGTH (poly / seg)
  (apply '+                                ; the sum of all single segment lengths
         (mapcar
           '(lambda (seg)                ;length of one segment
              (if (zerop (car seg))        ;is it straight?
                (distance (cadr seg) (caddr seg)) ; line segment or
                (abs (arclen seg))
            )                                ; curved: -> [24]
           (pline-segs poly)
)                                        ;segment list (bulge p1 p2)
;;; returns all group codes of the complex element
;;; (vertices, attributes) as list, similar to (edlgetent)
(defun CPLX-LIST (grp ele / lst)
  (if (= 1 (getval 66 ele))
    (progn (setq ele (entnext (entity ele)))
           (while (and ele (not (istypep ele "SEQEND")))
             (setq lst (cons (getval grp ele) lst)
                   ele (entnext ele)
           (reverse lst)
;;; PLINE-SEGS  - Creates a segment list for the polyline pname
;;;   as a list of '(bulge p1 p2). A straight line has bulge 0.0
;;; Compute pts in ECS of pname. Accepts LWPOLYLINE's
(defun pline-segs (pname / pts segs)
  (setq        segs
         (mapcar 'list
                 (if (istypep pname "LWPOLYLINE")
                   (group-only 42 (entget pname))
                   (cplx-list 42 pname)
                 (setq pts (getpts pname)) ; ->[23.1]
                 (rot1 pts)
  )                                        ; ->[20.1]
  (if (flagsetp 1 pname)
    segs                                ;closed
    (butlast segs)
)                                        ;open: without the last segment, ->[20.1]
;;; Example:   (a bit optimized for brevity :)
;;; Add up all the lengths of all selected polylines, quiet
;;; To accept also other entities, add those to pline-segs
(defun C:POLYLEN ()
  (apply '+ (ssmap 'poly-length (ssget '((0 . "*POLYLINE")))))
;;;; [24] Circle/Arc Geometry: BULGE conversion, some trigonometry
(defun seg2cir (seg / bulge p1 p2 cot x y rad dummy)
  (if (zerop (car seg))                        ;straight line => invalid circle
    nil
    (setq bulge        (car seg)
          p1        (cadr seg)
          p2        (caddr seg)
          cot        (* 0.5 (- (/ 1.0 bulge) bulge))
          x        (/ (- (+ (car p1) (car p2)) (* (- (cadr p2) (cadr p1)) cot))
                   2.0
          y        (/ (+ (+ (cadr p1) (cadr p2)) (* (- (car p2) (car p1)) cot))
                   2.0
          rad        (distance (list (car p1) (cadr p1)) (list x y))
          dummy        (list (list x y) rad)        ; return this, I hate progn's
;;; ARC2SEG - inverse conversion:
;;; calculates segment (bulge p1 p2) of arc
;;;   with given circle (ctr rad), start-angle, end-angle
;;;   (arc2seg cir (angle (car cir) p1) (angle (car cir) p2)) =>seg
(defun arc2seg (cir ang1 ang2 / p1 p2)
  (setq        p1 (polar (car cir) ang1 (cadr cir))
        p2 (polar (car cir) ang2 (cadr cir))
  (list (arc2bul p1 p2 cir) p1 p2)
;;; ARC2BUL - calculates bulge of arc given the arc points and the
;;;   circle (ctr rad) [fixed by Serge Pashkov]
(defun arc2bul (p1 p2 cir / ang)
  (setq ang (- (angle (car cir) p2) (angle (car cir) p1)))
  (if (minusp ang)
    (setq ang (+ (* 2.0 pi) ang))
  (tan (/ ang 4.0))
;;; BUL2ANG - returns inner angle of arc (bulge)
(defun bul2ang (seg / ctr)
  (- (angle (setq ctr (car (seg2cir seg))) (cadr seg))
     (angle ctr (caddr seg))
;;; ARC2ANG
;;; calculates angle of arc given the chord distance and radius
(defun arc2ang (chord rad)
  (* 2.0
     (atan
       (/ chord
          2.0
          (sqrt        (- (expt rad 2)
                   (expt (/ chord 2.0) 2)
;;; ARCLEN   - length of arc   = radius*angle,
;;; Note: +-, you'll need (abs (arclen seg))
(defun arclen (seg)
  (* (cadr (seg2cir seg))                ; radius
     4.0
     (atan (car seg))
)                                        ; angle = 4*atan(bulge)
(setq *INFINITY* 1.7e308)                ; largest double
(defun tan (z / cosz)                        ; [fixed]
  (if (zerop (setq cosz (cos z)))
    *INFINITY*
    (/ (sin z) cosz)
(defun dtr (ang) (* pi (/ ang 180.0)))        ; degree to radian
(defun rtd (ang) (/ (* ang 180.0) pi))        ; radian to degree
;;;;[26] EED Extended Entity Data: Select, Get and Store
;;; here is how to get the eed list from one element for all regapps
(defun get-eedlist-all (ele)
  (cdadr (assoc -3 (entget (entity ele) '("*"))))
;;; this gets all elements of appnames rname (wildcards allowed)
(defun ssget-app (rname)
  (ssget "X" (list (list -3 (list rname))))
;;; Check any XDATA with:   (entget (car (entsel)) '("*"))
;;; GETXDATA - get all XDATA lists from an element
;;; i.e with XDATA:
;;; (-3  ("HUBU-1" (1000 ."ASSHATCH")(1002 ."{")
;;;                (1070 . 1)(1002 ."}")))
;;; =>(("HUBU-1" (1000 ."ASSHATCH")(1002 ."{")(1070 . 1)(1002 ."}")))
(defun getxdata        (e apnlst)
  (cdr (assoc -3 (entget e apnlst)))
;;; GETXDATA-ALL - all lists without the regapp name
;;; => ((1000 ."ASSHATCH")(1002 ."{")(1070 . 1)(1002 ."}"))
(defun getxdata-all (e apnlst)
  (apply 'append (mapcar 'cdr (getxdata e apnlst)))
(defun PIX2UNITS (pix)
(defun UNITS2PIX (units)
  (* units
发表于 2014-7-6 17:02:57 | 显示全部楼层
好资料……支持下…
GMT+8, 2025-5-20 14:11 , Processed in 0.171512 second(s), 22 queries , Gzip On.
